New SV100cc Twin From United Hobbies
#51
My Feedback: (14)
RE: New SV100cc Twin From United Hobbies
I wonder if what is happening is that the engine manufacturer is selling the parts for complete engines, but not assembling them?
Some of the assembly work appears to be very amateurish, such as using silicone sealing material in a gas/petrol engine.
Perhaps it would be better if they gave us a price break and sent us the parts to assemble, if this is truly the case?
Ed Cregger
Ed Cregger
#52
I would like to know for sure the needle settings of a running V3 engine. Mine doesn't even seems to fire up. I'll dismantle the reed valve...
[&o]
[&o]
#53
Hi Simou
To start the SV100 you really need to choke it well.
By that I mean place your thumb on the intake of the carb and prime the engine until you get fuel coming out (A LOT) don’t panic the thing is that the carb sits quite low from the motor so it takes a while for the fuel to reach the plugs,
I had the same problem when I tried to start mine for the first time.
It always wanted to start but it never got started.
If you really prime it hard it will start.
Best off luck
Best off luck
#54
ty Francis for the reply,
my problem is that a few weeks ago i moved needles from their original position, and now i dont remember the originale setting!
I remember a strange number of turns, far away from 1 1/2 as usual... it was 3-4 turns or so.
So I was asking the setting of a running engine, as rough tuning.
This is not my first gas engine, but it's the first i cant get to start.
ORIGINAL: Francis L M
Hi Simou
Best off luck
Hi Simou
Best off luck
#55
Regarding the Carb setting on my SV100 are us follows,
Lower needle is 1 ¾ turns
High needle is ¾ turns
The only needle I had to touch is the lower one as it was to rich.
The Motor starts after a good prime on the third flick.
Hope this Helps.
Hope this Helps.
#56
I have also changed the spark plugs I did not like the spark it was
Producing the spark plug used is NGK BPMR6F
The motor has improved on the idle and the transition by far.
I have also ordered a new set of NGK
As in my case as shown in the pictures posted, My motor is spilling oil from the thread of the plugs.
#57
My Feedback: (98)
Make sure you choke closes all the way. The carb doesn't know what engine it's on, set it at Francis L M
settings.If it doesn't start flip the engine upside down squirt a little gas into the carb, turn it back rightside up, flip the prop, if it starts your choke isn't fully closed.
#58
Assembled by amateurs
No manual
No written warranty (HELLO...........)
Silicone for sealant
Reeds don't sit flush
Got to file down the bushing
Leaks oil from the plug threads
Made a new set of gaskets
Wow, this engine sounds like a real steal! Although at this point I'm not sure who got taken
No manual
#59
Banned
ORIGINAL: OnTheEdgeWow, this engine sounds like a real steal! Although at this point I'm not sure who got taken
#60
ORIGINAL: OnTheEdge
No manual
No manual
Well said.
-R
#61
While I agree that those issues should not exist, and will do harm in their sales, I look at it from another aspect. For the hour or so that it would take me to disassemble the engine and straighten a few things out that are not faults of the engine but the assembler, I would be saving around $500.00. I could buy a quarter scale or larger ARF from the savings alone.
The really bad part is that not everyone is mechanically inclined enough to do the needed "fixes", and from there the engine will get a bad reputation and probably not stay on the market.
Just my position....
AV8TOR
AV8TOR
#62
That makes perfect senses to me...
On top of that you have that warm fuzzy feeling of accomplishment. You
are the proud new owner of a rebuild, brand new engine. It is installed in
your brand new ARF. You can drive to the feild cofident that the rest of the
engine is built to the same high quality standards that will last for years to
come. You can fly with confidence knowing that the engine will stay running
and not re-kit your brand new ARF.
Someone else had a great idea....
Maybe they should sell use engine KITS... ARS motors, Almost Ready to Start!
Only minor machining required, instruction manual optional.
ORIGINAL: av8tor1977
AV8TOR
AV8TOR
#64
FL
AV8TOR
AV8TOR
#65
MD
ORIGINAL: Mr DJ
My Twin arrived yesterday--think I will send it back...if I can...
Mr DJ
Mr DJ
The reason I believe oil leaked from the plugs because the plugs arrived with no washers.
I wish I had a test stand like his—I think he got it from Grpo or something like that, but I can’t find it here stateside.
Anyways, I’m keepin’ it—may report any sortcomings once I fire it up.
Unforturnaltely, it will be awhile before I fire it up—I finally started building my Yellow Aircraft F-15 Turbine—slowly but surely… But even that will end once my turbine trainer arrives in Apr: Shokjet
http://www.yellowaircraft.com/jets/f15.htm - http://www.troybuiltmodels.com/Shokjet.htm
Mr DJ
#66
This evening it seems nearly to start.... but the CDI has gone..... puff.... blowed up. 5 NIMH 2300 cells not fully charged.
GRRRRR
GRRRRR
#67
My Feedback: (13)
AR
I don't know why people even use 6.0 volt battery packs on these Chinese engines. Ignitions burning up on 6.0 volts ain't new. 4.8 works just a good, and you don't hear of them burning up nearly as much.
#68
Hi.All Consumer
I look that this HH new IGNITION is similar Our company RCEXL.But is not Our company produces.Before is Our company provides.Now not our company with provides.Please note distinguishes
The following is RCEXL some main customers:
CHINA: DL ,3MM ,MT , RCGF , FRL ,HS ,QJ ,........Engines Factory
USA: CH (General agent),
and Other : Torch , BCMA , BME , airhobbies ,COPPERHEAD ,Western Hobbies ,.......
& More than 50 national Sales proxy
Thanks everybody to the RCEXL product deep affection.
English is not very good. Please forgive.
XU LIANG
Company President
HTTP://WWW.RCCDI.COM
MSN:[email protected]
SKYPE ID:RCCDI88
Sales email: [email protected]
Support email: [email protected]
OFFICE TEL:86-579-8287-8074(24hours)
OFFICE FAX:86-579-8213-1230(24hours)
XU LIANG
Company President
SKYPE ID:RCCDI88
#69
The CDI that comes with is motor is rated from 4.8v to 6.0v . My battery pack wasn't fully charged as it had a 45min flight on a 6 servos sailplane, before to plug in the CDI.
#70
All consumers:
Perhaps this CDI design is not very good.
looks like RCEXL ignition .
but not RCCDI manufacture.
asks the consumer to pay attention to the difference.
to see http://www.rcuniverse.com/forum/m_6485295/tm.htm
#71
I'm with Rc cdi on this, the guy from SV (GRPRO), made huge efforts to copy the RCexl Ignition and it's not good!
#73
HI
I was thingking to buy the CDI from ZDZ100
The ZDZ 100 ignition is £130.00, 2 x plugs £12.00 and 2 x plug cups £16.00
I dont know if it's worth it or not.
up to know the motor is running well.
I have never had a twin so i cant tell the diferace.
I have bought a WorldModels 33% Ultimate still not to sure wat to du.
#74
Dose any of you know were can i find a forum of the Ultimate WM33%
I would like to see it.Or du you guys have one or flown it.
