Setting the timing on a 23cc CY
Old 03-09-2008 | 07:43 PM
Default Setting the timing on a 23cc CY
Good Afternoon everybody!!
I have a HobbyPro Ford GT and today while putting around the street, and I do mean putting, the engine started to act like the choke was in the on position. The car will try to fire but I noticed that it was backfiring out of the carb. Upon futher inspection It looks as though a rock or object was sucked into the flywheel housing and some how lodged itself between the flywheel and the Mag leaving a nice gouge in the flywheel before freeing itself to continue on its journey. With the engie wanting to fire yet back firing from the carb I think it some how advanced the timing. Is this plausible? What do I need to do to reset the timing?
thanks in advance!!
Jason
Old 03-09-2008 | 09:33 PM
Default RE: Setting the timing on a 23cc CY
At closer inspection it actually looks as though the crankshaft kept spinning and the flywheel actually stopped for a moment. Does anybody know what the 2 letters on the flywheel stand for. There is an S followed by an N. Guess I'll pull the flywheel and reposition back to TDC. Any other ideas?[:'(]
