RCGF Engines
#4451
RE: RCGF Engines
ORIGINAL: Tired Old Man
Not to step on Gas R/C Hobby Engines toes, but I've found that Permatex Anaerobic Sealer works very well for a well fit machined case half application. Easy to locate in most auto parts stores.
Apply in a very thin layer to only one side of the case half. One of the benefits of this type of sealer is that it does not completely harden, and any spill over that breaks away inside the case is easily passed through the engne to exit the exhaust without generating any interference or component damage.
Of course make sure that the edge of the case has been well cleaned to remove any residual oil before the application of the sealer.
Case screw torque to 40 inch pounds max. Same torque with the cylinder and carb screws.
It it had a high idle, probarly leaking air betveen the two halfs.
Thomas
#4452
My Feedback: (52)
RE: RCGF Engines
Gas R/C Hobby Engines,
How well are you stocked on parts? I have the one of the first 100's and could use two sets of rings. I also have a later upgraded rear induction 100 nib that I'm likely going to part with. Too many engines in the shop and need to make some shelf space.
Jim is in Bijing working with the RCGF factory to see about some small changes in some of the engine designs. I am hoping to make them more user freindly.
Is it alright if I email you monday abouit the rings and 100 engine?
#4453
RE: RCGF Engines
T.O.M.
Thanks, I'll shorten this one, I can do that with out getting near the reeds. It looks like I can knock off about 1/4" - 3/8" < total length of the engine> and that is enough for most of the 1.20 size planes that I have looked at and won't have to cut the firewall. If it starts running bad, I'll just get a new one stock length.
Andy
Andy
#4454
My Feedback: (52)
RE: RCGF Engines
#4456
1 Post
RE: RCGF Engines
ORIGINAL: gasrchobbyengines
I am the only one working today so it will be monday before I can get out and be able check the stock on the rings. I carry alot of parts, alot of them it seems I never use. I will also see if I can use another 100 for stock.
Aren't you formerly cman_25? It was a good nick. Why change it?
I hope Jim does well in China ... they are in Zhejiang, not Beijing. The problem we had with any dealings with them was that the only English speaking person there was Catherine Tsang. (The same as often posts here as JohnnyB). Does Jim speak Cantonese or Mandarin?
I wish Jim the best of luck in dealing with the factory. Hopefully, his powers of persuation are better than Piston's and Aussiesteve's [sm=thumbup.gif]
#4457
RE: RCGF Engines
The purpose of the brass inserts in the early heads was to enable the use of a 10mm spark plug, aka CM-6. The early heads were intended to use a 5/8 plug and the insert was a simple reducer. Their use did raise the height of the plug electrode in the heads but it generally didn't have much of a performance impact. Those that had a desperate desire to obtain the same electrode depth only needed to cut away the crush washer on a CM-6 and install an 010" soft steel shim washer.
The only reason to have used a CM-6 was to lower and narrow the plug to plug distance on the twins, and lower the plug height on the singles. Unfortunately the ignitions used between the two plug types was, and is not interchangable.
RC Gas,
Monday is fine but I probably won't reply until Tuesday when I get back to the shop. Travel between now and then. The new 100 has had the hub re-drilled and tapped to correct a timing issue. Typical of every Chinese engine out there, so I figure only one shop makes hubs for everyone in the area.....
RC Gas,
#4458
FL
RE: RCGF Engines
Hey gasrchobbyengines....
Please keep us informed of the changes that your distributor Jim from Agape is making with RCGF.
Not that I am cynical when it comes to anyone wanting to work with RCGF, but aussiesteve and T.O.M. and I did a lot of work on their 100cc engine about a year and a half ago. After RCGF followed through with the changes and if the engine was assembled correctly, the engine would start and run with little issue. The changes made were actually quite dramatic, so perche ... you need to get the upgraded components and that old 100cc will be renewed and it will run a hell of lot better too.
So the the curiosity of the changes that are being made now is high with a lot of us.
Hey AjsToyz - start with the 1/4", and take the plastic off the reed side. It should be easier to ensure a better seal too. Can you do me a small favor too.. When you look at the insulator block look sideways the top and bottom. RCGF had a molding issue early on, whereas the mating surfaces where warped. It created a situation for air leaks. I replaced a ton of blocks due to that situation. It will NOT be too hard to see. The easy way that we removed the uneven surfaces was to hand sand them on a flat surface.
Cheers
Henry
Cheers
Henry
#4459
My Feedback: (52)
RE: RCGF Engines
ORIGINAL: Piston
Hey AjsToyz - start with the 1/4'', and take the plastic off the reed side. It should be easier to ensure a better seal too. Can you do me a small favor too.. When you look at the insulator block look sideways the top and bottom. RCGF had a molding issue early on, whereas the mating surfaces where warped. It created a situation for air leaks. I replaced a ton of blocks due to that situation. It will NOT be too hard to see. The easy way that we removed the uneven surfaces was to hand sand them on a flat surface.
Cheers
Henry
Cheers
Henry
Right now I mainly deal with the smaller engines, I like to convert smaller planes over from nitro to gas. It is a hobby that turned into a JOB. Oh well it is something I enjoy doing.
I am looking forward to working with everybody to make this a better hobby where we can all have more fun! I am open to sharing my ideas and I am willing to help when help is needed.
Thanks!! And HAPPY FLYING!!!
#4460
RE: RCGF Engines
Henry,
Mine starts easy ,I don't think there is a warp issue but I will let you know. I'll have to check that side, there is a recessed area so the reeds do not get blocked or restricted.
Andy
Andy
#4463
RE: RCGF Engines
ORIGINAL: barry wetherell
HI, guy's is the RCGF 26, the same motor as the RCG 26 ??? which also comes out of China
A.A. Barry
A.A. Barry
According to the box they come in (very articulate printing), the manual with them and the overall appearance of the two engines (including the same machining anomalies) - Yes - they are the same engine.
#4464
RE: RCGF Engines
Henry,
What ever the material is they use for carb insulator blocks shrinks BAD !! I took a good look at it and where the material is the thickest,its very concave. I will do the sanding thing with a flat wood block to get a better seal. That is funny though, was not having any complaints starting it. It starts easier then two other engines I have.
Andy
Andy
#4465
FL
RE: RCGF Engines
Hey Barry
Aussiesteve is absolutely correct.... the one thing you should be aware of is that these engines are for the Asian market only. RCGF told me this a while ago. They do not sell their first run engines to Chinese companies that sell on-line outside of China. Both he and I have many emails from the factory attesting to this.
That said, both aussiesteve and I have seen these type of engines - buy at your own peril. Warranty and service are at your risk. All may not be what it really seems!!!
Hey AJsToyz - The reason you did not see any leakage is that you had a good seal with the gasket. Unfortunately many others have not. Most of the time the problem became apparent when the user oriented the carb in another position. The gaskets would not seal in the new orientation and you had air leaks.
Yes, simply sanding and/or applying liquid gasket would resolve the air leak problem too. But we told the factory to fix the problem from their end.
And T.O.M. you are most certainly correct about the 100cc engine. When the engine was set up correctly it did run well.
Cheers
Henry
Cheers
Henry
#4466
RE: RCGF Engines
ORIGINAL: aussiesteve
A.A. Barry
A.A. Barry
Thomas
#4467
RE: RCGF Engines
ORIGINAL: perche
Realy? so why is the plug pointing up on the rcg, and to the side on the rcgf?
Thomas
A.A. Barry
A.A. Barry
Thomas
#4469
RE: RCGF Engines
ORIGINAL: perche
ORIGINAL: perche
Thomas
A.A. Barry
A.A. Barry
Thomas
#4471
1 Post
RE: RCGF Engines
ORIGINAL: Piston
ORIGINAL: Super08
If you look closely in the picture of the RCG it says RCGF on the ignition....
Seriously, this is confusing for consumers to say the least. I have had people question me about this and tell me I'm overcharging for RCGF and refer to the pricing of RCG from HobbyKing.
What can you say to those people when the engine looks pretty much the same and even theignition (which isn't made by them anyway) has the RCGF logo printed on them and the box is pretty much the same too?
These are cheaper because they are missing the "F" ?
#4472
RE: RCGF Engines
True, the ignition is made by Rcexl. RCGF has had alot of different versions of the 26 and they also make different versions for different markets so it gets confusing to say the least. Also there are allot of manufactures that make clones of other engines to add to the confusion. Many of the cylinders used on the engines are shared by many engine manufactures. The cylinder used on the old 26 with the slanted fins was also used by SPE, MT, FTL and others. Bearings, pistons and crankshafts as well. Abot the only difference between them was the crankcase and ignitions. Some of them like SPE would shave the fins down on the exhaust side of the engine to save weight.
#4473
RE: RCGF Engines
ORIGINAL: apalsson
The difference between the export quality ones and the cheaper chinese domestic quality ones are that the local ones are missing the F ?
These are cheaper because they are missing the ''F'' ?
I tell my customers to take a second look at the rcg engines.
ORIGINAL: Piston
ORIGINAL: Super08
#4474
RE: RCGF Engines
Guys, apart from the plug angle, the crancase is diferent, case though bolts in from the ft, Rcgf bolts through from rear,mount lugs in different positions, looks like a different motor all together, to me
Barry
Barry
#4475
RE: RCGF Engines
All this talk of non-genuine and inferior quality must be hurting the company that actually produces these engines?
As a consumer I know it has turned me off ever buying another RCGF branded anything.
