RCGF Engines
Old 05-16-2014, 04:28 PM
  #6201
FOOPED
My Feedback: (8)
Its the same as Zenoah 62cc Engines and will also fit the 45 RCGF EX are the same and last I looked Jteck carries them to.
Old 05-17-2014, 10:56 AM
  #6202
Hawk131
I have a RCGF Blue head 26cc post mount engine, does anyone know which walboro carb I can get that will work with it?
Old 06-24-2014, 03:47 PM
  #6203
ddewey
+1 for Captmicom he overhauled my odd-ball RCGF 26 quickly for a good price; it runs great now. I'm finally uploading pictures of the 60cc RCGF Captmicom offered up for an online raffle at the end of last year. Busy Spring, but finally got my test stand out the other day with the 60 on it. Started like it was a completely broken in engine: Throttle wide open----full choke----popped on the third pull through. Throttle cracked above idle-----ran on the third pull. Pump gas/Stihl dino orange bottle 32:1/ ValleyViewRC 24X9 prop. Checked RPM's after a couple of quick heat cycles and it gave 6510rpm WOT and would idle around 1900rpm. Ran about 5 heat cycles total and never touched a needle---settings as delivered were right on with a clean no hesitation throttle up and a touch fat on the upper end. IR Thermometer around 150-175 deg F running. Don't believe in excessive "break-in" time----I'd rather break-in in the air-----so it's on to mount and fly probably in my GP Giant Aeromaster bipe.
ID:	2008567   Click image for larger version
ID:	2008568   Click image for larger version
Old 07-14-2014, 05:03 PM
  #6204
VeeAte
VeeAte's Avatar
Anyone know where I can get a manual for the non beam mount RCGF 26? I bought one a few years ago and he manual has disappeared from my folder of manuals
Old 07-14-2014, 07:12 PM
  #6205
edge540purple
Hi VeeAte,
Go here for the 26cc Manual.
Regards,
http://www.zjrcgf.com/Download.aspx
Old 07-14-2014, 08:58 PM
  #6206
VeeAte
VeeAte's Avatar
Originally Posted by edge540purple
Hi VeeAte,
Regards,
Thanks for that
Greatly appreciated.
Old 07-14-2014, 08:59 PM
  #6207
VeeAte
VeeAte's Avatar
Does anyone know how to get in contact with AussieSteve?
I noticed he hasn't posted anything for a couple of years.
I used to talk to haunt a few of the same threads on here as him.
Old 07-15-2014, 12:54 AM
  #6208
erieqc
I see him on flying giants mintor thread he's still alive.
Old 07-15-2014, 03:57 AM
  #6209
ahicks
Yes, active in gas engines thread there as well.
Old 07-16-2014, 02:52 AM
  #6210
Lifer
Lifer's Avatar
I am trying to find a gasket set for an RCGF 20cc engine. BP is out of stock and HK doesn't list one. Anybody know of other suppliers?
Old 07-16-2014, 03:38 AM
  #6211
ahicks
http://www.swaerovista.com/
www.amr-rc.com/
Old 07-16-2014, 05:57 AM
  #6212
Lifer
Lifer's Avatar
ahicks,
Thank you for your help. Found nothing on SW Aerovista but AMR has them in stock. I plan to install a Bowman ring.
Old 07-16-2014, 06:05 AM
  #6213
Captmicom
Sorry I do NOT list all the spare parts I stock... I do not have the time.... How ever I am the US repair center for RCGF so call...
Thanx
Old 07-16-2014, 12:04 PM
  #6214
iflyjr
My Feedback: (19)
Keep us posted I just order one myself. RCGF 60
Old 07-16-2014, 12:10 PM
  #6215
Lifer
Lifer's Avatar
After the gasket set arrives, I'll order a ring from Frank Bowman. The engine is fairly new, definitely under-compressed, and hard to start when warm.
I am a BIG fan of Bowman rings and they have been installed in all my DLE's. More compression, quick to seat, and easier starts.
I'll post on the progress as requested.
Old 07-19-2014, 04:16 PM
  #6216
iflyjr
My Feedback: (19)
Well just got my 60cc single today. Overall looks good. I will take some pics. Order it Tuesday got it today. Pretty Quick.
Tim
Old 07-19-2014, 06:40 PM
  #6217
Captmicom
Hi Tim,
That is cool!! Where did you get it from? By the way "SUPER SHOPPERS" I still have some of the New RCGF 60cc Singles from the BIG RCGF 10 year Anniversary sale if you want one. Just PM me and I will hook you up....
Old 07-19-2014, 11:11 PM
  #6218
lean-run
Hi Lifer, just wondering if your 20cc RCGF is a beam mount or one mounted on stand-offs? I have a couple of the beam mounts (dual rings) and they have good compression and start well hot or cold.
Looking for a stand-off mount 20cc ( single ring?), so will be interested in your outcome.
Old 07-20-2014, 01:52 AM
  #6219
Lifer
Lifer's Avatar
Leanrun,
It's the version that uses standoffs. Frank said if it is a 2-ring model that I should only replace the top ring. There will be less drag/heat that way. I won't take the engine apart until I have the gasket set and new ring in hand.
Mine only has modest compression and that is why I plan to go with a Bowman ring. Several times I have made that decision and each time was amazed at the difference in compression and how much easier they are to hand start as a result.
Old 07-20-2014, 03:43 AM
  #6220
Captmicom
Hi Lean Run,
I have them in stock. How many would you like to have? Just give me a call...
Old 07-20-2014, 04:14 AM
  #6221
Captmicom
To all of you RCGF fans News Flash!!!
We are now planning to bring an RCGF engine warehouse right here to the go old USA. I am currently working with RCGF management to make this happen. I will also soon start running the RCGF service center full time as well. There will be an "ALL NEW" web site that will make engine registration and warranty work so much easier. This will also allow for faster delivery of all the great RCGF engines you like so much. As soon as we have all of the new web sites up and running I will share the info with you. If any of you need parts or service at any time in the future just call RCGF service center at 520-732-2200 we will gladly take care of you...
Kind Regards,
Joe
Old 07-20-2014, 04:28 AM
  #6222
TomCrump
TomCrump's Avatar
Kind Regards,
Joe
Great news !
Old 07-24-2014, 04:44 AM
  #6223
45cal
BP Hobbies is always out of stock on the 55cc engine. Any other U.S. Retailer out there? Need one for the "prime cut +20" I'm going to start on
Old 07-24-2014, 05:31 AM
  #6224
ahicks
Read Captmicom's note #6217
Old 07-24-2014, 05:54 AM
  #6225
Captmicom
Hello 45Cal & ahichs,
Thanks Big Al!! I am still trying to get my hands on some of the 10cc engines for us to test. We are still trying to work out Carb issues.
45cal, I am still here.... I stock all of the RCGF engines and have for going on 9 years. I am also the US Service Center for RCGF. That means that you don't need to send it back to China if it needs to be repaired. If you want something just call!
Thank You,
Joe
