G38 engine
Old 05-21-2003 | 02:16 AM
Default G38 engine
I have a G38.....list some planes that this engine will work good on. Thanks Capt,n
Old 05-22-2003 | 09:37 AM
Default G38 engine
ziroli mid size p47.- probably most any mid size warbird 70-80 inch that had a radial engine. planes like cubs etc that are bigger maybe up to 18-20 lb would be good too. of course that dpends on your definition of good, and how much you want to spend. to me the g38 would be good where the plane would need nose weight (compared to a glow engine) and good, reliable power.
probably not good for serious aerobatics.
ed
Old 05-22-2003 | 11:03 AM
Default G38 engine
84" version of the Lazy Ace Bipe,Sig 1/3 Spacewalker.
Old 05-22-2003 | 11:36 AM
Default G38....What plane?
Kevin: Thank you for the ideas. That 1/3 spacewalker sounds nice. Won,t be able to get up there this weelend. Too many things planned already, along with some work that has to be done. Keep the Ideas coming guys....Thanks again Capt,n
Old 05-22-2003 | 11:58 AM
Default G38 engine
Yes I consider the big Sig Spacewalker one of the better bargains available in giant kits.This is a contest scale version of a personal light plane which isnt particularly aerobatic and neither is the model.If 3D and unlimited anything is your desire this is not the model for you,IMO.No amount of overpowering is going to overcome the natural flight tendencies of the huge constant chord ironing board of a wing.
Mine is powered by the electronic ignition version of the Quadra 400,which is 38cc displacement,and its a perfect match,which allows all normal aerobatics and then some,but also allows beautiful slow flight and landings to write home about........
Old 05-22-2003 | 12:03 PM
Default Sig Spacewalker
Will it loop , roll and fly inverted??? Thanks John
Old 05-22-2003 | 12:14 PM
Default G38 engine
Mine will with ease.......also do outside maneuvers,semi hover,barrel rolls,immelman and double immelman,gorgeous tail slides,no brainer stall turns,and lovely side slips.It helps if the pilot knows how to use the rudder properly in flight.
Old 05-22-2003 | 06:31 PM
My Feedback: (14)
Default Quite a choice
G38 - well just about any plane that can handle a 4.4 lb engine. If it's a high wing loaded aerobat then keep it under 14 lb all up. If it's a low wing loaded floater like a cub then keep it under 20 lb ready to go. There are a huge variety of 1/4 scale planes that fit those specifications
Old 05-22-2003 | 10:55 PM
Default G38 engine
Works well in SIG cubs also.
Old 05-23-2003 | 02:11 AM
Default Cub
1/4 scale or 1/3 scale for G38 engine? Captin
Old 05-23-2003 | 01:35 PM
Default G38 engine
1/4 scale cub. My buddy has a 1/4 scale clipped wing version (SIG) with a G38. Yes it's overpowered, but it sounds really good on a low flyby with the power pulled back. Very scale looking and sounding. Weighs in @17.5lbs. Not very light, but handles the wing well.
Old 05-30-2003 | 07:47 AM
Default G38 engine
I put my G38 on an Ultra Stick 120 with VERY little modification. I didn't have to add any "dead" weight to balance it and it comes out just under 14lbs.
Old 05-30-2003 | 12:35 PM
Tmoth4's Avatar
Default G38 engine
I just put a G38 in this 20 lb., 100" span Chipmunk. I can't believe how well it hauls it around! It does all the scale aerobatics I want.
Jim
Old 05-30-2003 | 02:06 PM
Default G38 engine
HOLY COW! That thing looks REAL. What kind of pump are you using?
-Kevin
Old 05-30-2003 | 02:48 PM
Tmoth4's Avatar
Default G38 engine
It's got the TME smoke pump, using Bennett's smoke oil.
Old 05-30-2003 | 11:05 PM
Default G38 powered planes
These are all good planes for the G38 engine. Thanks Guys...and keep them coming...more choices the better. Captinjohn
Old 05-31-2003 | 01:06 PM
My Feedback: (12)
Default G38 engine
Try a Ryan's Rebel. All up flying weight is 13 lbs. Cost is minimal.
Ryan
Old 05-31-2003 | 02:08 PM
Default Plane
Where do you buy a Ryans Rebel Kit or plane? Thanks Capt,n
Old 05-31-2003 | 03:02 PM
Default sig
everyone in my club has at least one g38 in a sig fourstar 120. only mods are beefed up gear and servos in tail.
they will do every move in the book and a few that arent in any books..hahaha.
Old 06-01-2003 | 01:08 AM
Default Re: Cub
I have a SIG 1/3 scale J-3 with a G-23. With the G38 it will be too nose heavy and you will need to add weight on the tail.
Old 06-01-2003 | 01:19 AM
mstroh3961's Avatar
Default Re: Plane
Where do you buy a Ryan's Rebel Kit or plane? Thanks Capt,n
Hi the Ryan's Rebel is a Scratch built plane. Plans are available from RCM. By the way That was the designer who posted earlier!
Regards
Mark
Old 06-02-2003 | 11:27 AM
My Feedback: (12)
Default G38 engine
captinjohn,
Ryan's Rebel was featured in the December 2002 issue of RCM. The article included the materials list. You can buy the plans from them. Gear can be purchased from TNT Landing Gear. Let me know if you need any additional info.
Old 06-02-2003 | 11:11 PM
My Feedback: (37)
Default G38 engine
Doesn't the new G-26 put out more power than the G-38 weight less and come in a smaller package. I have been thinking about a G-38 but get turned off when comparing it to the other Zenoah engines, it weights almost as much as the G-45 without the power. I am just getting started getting into gas.
Old 06-03-2003 | 02:17 AM
Ed
Default G38 engine
The G-38 is just a sweet and reliable engine. You will find very few people that have harsh words for the G-38.
Old 06-03-2003 | 02:46 AM
Default G38 engine
I got one and I think I may put a ignition by RCIGN1 and drill holes in the fins and anything else I can do to make it light. That steel prop hub and shaft got to go also. Captinjohn
