DA ignition
Old 05-21-2003 | 08:06 PM
Default DA ignition
Can anyone let me know what type of plug it is on a DA ignition pack.
Have not seen them before, but probably end up cutting them off for a futaba style plug.
cheers
rob
Old 05-21-2003 | 09:02 PM
Riverdancer's Avatar
Default DA ignition
Rob,
I believe it's a Hitec / JR end for the hall sensor. The power leads are "universal car" something. I would wire it to match your charger.
Take Care,
Riverdancer
Old 05-21-2003 | 09:28 PM
Default DA ignition
Thats the one. Was after the power lead. Will probably chop it off and fit a jr battery lead. Is this the usual method.
cheers
Rob
Old 05-21-2003 | 10:28 PM
Default DA ignition
The 4.8 volt power lead is connected with an Anderson Power-pole connection. That's what I use on mine - it's heavy duty and can carry a lot of current. Any hobby store can get replacements. I think RadicalRC has them too.
Old 05-22-2003 | 01:28 AM
My Feedback: (31)
Default DA ignition
Some call them SERMOS. Very common to the RC car guys. I'd leave it in place and get a matching plug for the battery/switch. Much more capable of providing the required current for these engine than the messily 2 amp OEM servo connectors many use.
