Walbro pump question
Old 09-22-2008 | 08:12 AM
WRK
Default Walbro pump question
Any one know for sure if the fuel pump portion of the carb. pumps both on negative and positive crankcase pulses?
Old 09-22-2008 | 08:44 AM
Default RE: Walbro pump question
Built in check valves, one way pump. If it was a bi-directional pump it would pull fuel out after putting it in.
Old 09-22-2008 | 09:08 AM
You can use a spring in the pump and use an external pulse to the intake. AV8TOR can tell you better.
Old 09-22-2008 | 09:30 AM
tkg
It sucks in the fuel on one pulse and pumps it out on the other.
Old 09-22-2008 | 10:30 AM
WRK
Thanks TKG that is what I was looking for.
Old 09-22-2008 | 12:34 PM
JoeAirPort's Avatar
My Feedback: (41)
ORIGINAL: tkg
BINGO !! This is exactly what it does. It's a very cool simple little device. Only one check valve is open at a time, and they volley back and forth duing positive and negative pulses.....that's how it does what tkg said.
See end of page 5 and beginning of page 6 for pump sequence description:
http://wind-drifter.com/technical/Wa...viceManual.pdf
Old 09-22-2008 | 08:54 PM
You could cut the pumping section out of a pumper carb...and use it in line to make sure fuel does not run back to tank. Capt,n
