RCS 44 twin starting problems
ON, CANADA
1 Post
With perhaps 1/2 hour of time on it my new twin is a bear to start particularly from warm.I have checked everything I can imagine,including a new ignition from RCS....no soap,,,,,,It will pop using my usual drill,but refuses to catch.Before it goes back on warranty I'm interested in anyone else,s experience with this engine good or bad........
Thanks............Kevin
AZ
starting twin
Using the following drill mine starts easily hot or cold:
1)Open throttle,close choke and turn on the ignition.
2) crank by hand until it pops.
3) close throttle,open choke.
4) hand crank until it starts- usually in two or three flips.
If it won't start with this drill I would send it back. There might be something wrong with the hall effect pick up.
AZ
ignition
Originally posted by AeroSports
I think it is safer to keep the iginition off when chocking.
ON, CANADA
1 Post
I have always used the ignition on,full choke,flip til it fires etc....method,and RCS reccomend it in the literature that comes with the engine too.
Ialso use a positive restraint device AKA pickle fork to make sure the model doesnt lurch forward.
Incidentally after trying everything I know to get this little b*****d to start when warm,including a replacement carb,and a new module,I reluctantly sent it back to Mr Dooley and Co.,for them to solve.
Im betting on the sensor buried inside the engine.........which I chose not to mess with.....
AZ
starting
When I first got my twin I had trouble starting it. RCS replaced the module and I still had trouble. I removed the sensor from the back of the engine and found some metal shavings on it. I removed the shavings and cleaned out the hole. I have not had any trouble since. I don't know if this was the trouble buit it sure seems like it. RCS didn't like the idea of me removing that sensor.
Banned
My Feedback: (26)
rcs twin
I am very interested in purchasing one of these as it is the perfect size for the GP 1/3 Pitts.
Any major complaints, how about actual wt as compared to stated wt. Power, etc. Have read the above about warm start problems.
Wonder how the metal part got into the pickup in the first place, is it excessive engine wear?
Any other information would be helpful, like RCS new revisions to the original engine, etc.
ON, CANADA
1 Post
Actually I didnt want to send the engine back to RCS but I ran out of ideas.Otherwise I was impressed with it,and even with only half an hour running it was picking up rpm with every run and the idle was notably lower and smoother as I dialed it in.Im still very much looking forward to running this little twin and Im sure RCS will do whats necessary to give me an easy starting engine as these normally are.
Incidentally I was getting >6000 with 40/1 petro oil,a rich setting,and a Zinger 20x10 right out of the box which I consider quite good.......
