DA-50R flameout
Old 01-29-2009 | 04:23 PM
Default DA-50R flameout
Flying my DA-50 today when the unexpected engine flame out occurred.
Question is providing good voltage to the ignition module:
1) is there a procedure to verify the status of the Hall magnetic sensor on the crankshaft via an OHM meter?
2) is it OK to power up the ignition system / plug removed and grounded to engine, spin the crank to confirm spark?
Thanks all!
Old 01-29-2009 | 05:47 PM
RTK's Avatar
RTK
Default RE: DA-50R flameout
2)=Yes, as long as the plug is in the cap.
1)=don't know for sure
Old 01-29-2009 | 06:18 PM
#2) Yes
Old 01-29-2009 | 06:19 PM
Jake Ruddy's Avatar
My Feedback: (40)
It's pretty rare for the sensor to just go like that. Not saying it doesn't happen, but it is rare. You can blow them on many ignitions if you try and check spark without grounding properly.
RTK / Pat answered your questions correctly.
My question would be did you try and start it afterwards?
Have you checked your clunk?
What kind of battery are you using? What is your battery voltage?
Old 01-30-2009 | 07:55 PM
Thanks all..........gotta start some where. As everybody suggested, I started with the simple and cheap first. Following DA's advice, verified volts to the ignition module then spun crank with prop off (of course) no sparky. Rest is history.
What is everybody using to wrap the flex header of the cylinger head Teflon?
