DL 100 Help Needed
Glad I could help,which reminds me, you have some parts you can't use anymore that you paid for. I can swap them out for ones you can use or you can trade them back for part of a carb or.......your'e the customer.</p>
#31
hay jody hope you are feelinf better from surgery look on the prop i havd a zdz 60 is this the same as the zdz 50 prop patteren thanks
#33
My Feedback: (23)
AL
Just a side note:
I found that the carb used on the DA 100 works well on the DL 100. I got one from DA and it had a nice anodized throttle arm and servo ready choke arm. It is a WJ 71.
#36
NJ
ORIGINAL: dreadedone
Just a side note:
Just a side note:
I have no issues with my stock carbs on both of my DL-100's.
I do have two new in the box Walbro SDC-80-1 waiting in case I ever do.
#38
NJ
ORIGINAL: SOLO_48
Can anyone please tell me what best to use on CDI ignition ,a 4.8V or 7.4V with a regulator to 6.0V
I have been using 4.8V, 2500mah NiMh packs on them for years now.
I have done ( numerous times ) six 15 minute flights without any issues at all.
