SYSSA 30CC GAS MADE IN USA
#2301
RE: SYSSA 30CC GAS MADE IN USA
ORIGINAL: Joystick TX
Good news is that my engine came yesterday. Whoo hoo!
Bad news is that I ordered the 5.2” engine option (another what was I thinking moment, I should have asked about that) thinking that the rear of the carb would not be recessed into the firewall and I would only need a small round air hole for the carb. Now that I have the engine, I know that the distance from the front of the hub to the rear of the carb screws is approximately 5-7/8.”
If I use the spacers that I ordered with the engine, I would need to cut a huge hole in the firewall to clear the carb and have a big slot to allow the choke lever to operate. Normally that would not be a big problem, but in my installation the choke lever would fall right in line with the rear of the ¼” firewall on the plane, or engine box, and that is a major problem.
I should have ordered the 6.25” engine option. That would give me about 5/16” clearance from the carb screws on the rear of the engine to the firewall.
It would be very helpful to have a 3-View drawing with the engine dimensions in the manual and on the website.
I use Spektrum DX7 2.4ghz and only have glitching if I hold the radio antenna very close to the fuselage/transmitter. (with digital servos) was your radio in your hand and close to the ignition switch when you had gliching? I can reproduce it on demand if I point the radio at the receiver/switches within 12 inches. I've never had a problem when range checking or flying. Scared the @#^$% out of me first time it happened, then I quickly realized my radio was powered on and in my left hand, too close to the electronics.
#2303
ORIGINAL: cmoulder
Hog78, no they're not the same, but if you're already using the 42% Products I'm sure it is fine. I read good reports on ''EFF-GEE'' () about it, but I first saw the Syssa Ultra IBEC so that's the one I went with. It is made by Tech-Aero, but I don't have the electronics knowledge to explain the differences or why one might be preferable.
Whichever one you use, these devices do save a lot of weight and totally eliminate the possibility of switch-generated interference, with the added benefit of optical kill.
ORIGINAL: Hog78
is the Syssa Ibec the same as the 42% zeus I didnt even know about Syssa's untill after I ordered Vally view the 42% does work good I wonder which is lighter? Got 1/2 gallon of 40:1 dino oil thru her and all is still well. Lately I have been wondering about after the warranty. if I ever have to dissassemble her. Probably never will have to but just wondering about that hub. I hate winter!
The Tech Aero Designs IBEC is quite a neat device. I am using the original prototype in my set-up and the designer is good friend, Ed Alt who owns Tech Aero. I also have had a hand in testing the device with a multitude of radios, on 72 Mhz, FM/PPM, PCM and the latest 2.4 gig DSS and FASST. Current radios work very well with no practical loss in range.
We also tested several older radios, older than 5 years old. Futaba's and JR's top of the line radios from back then also worked fine. But some middle of the road Futaba radios were more susceptible to ignition noise losing as much as 20% in range and in Hitec's case, lost about 50% in range. JR's ABC&W RXs were more immune to such noise. Keep in mind though that without the filtering built into the IBEC, these radios would have lost most if not all of the range they normally would have in a glow application
Ed has explained his electronics to me and they make very good sense to me. The Tech Aero device depends on electronic filtering the return noise (rather than depending on long, twisted wiring with choked ends to provide iffy filtering) from the ignition and practically eliminates it from the circuit. Some Older radio RXs are not quite as immune because even the tiniest of RFI caused them to glitch. Ed tweeked the voltage output from the IBEC to the module such that the module will see about 4.6 V at full load (full revs). He tweeked components using superior electronics to only drop about 0.3V across the IBEC. This all equates to minimizing the amount of current drawn from the battery to power the CDI module. It may very well be the most tested IBEC on the market today, but neither Ed nor I lay claim to such a thing.
The device is very light at around half ounce or so, with the bulk of the weight coming from the wire connectors. Keeping these as short as practical enables minimal weight. I know this is a sport flyers thread and minimizing weight doesn't hold the same stature as it does in competitive circles. In pattern for example, where we have a limit on airborne weight, it's normal to think in terms of 75$ per ounce to lose that ounce from the airframe, when one gets close to the limit
Ed doesn't subscribe to this thread so I took the liberty to discuss this at his behalf
MattK
#2304
My Feedback: (36)
TN
I am using the Zues I havnt weighed it but it seems only a few oz's I use spectrum 7000 and 9303 for tx all that packed into my Sig Mayhem and not a single glitch (and it is tight in there). Cant wait for the Nall!!!
#2305
My Feedback: (24)
TN
ORIGINAL: Hog78
#2306
ORIGINAL: cmoulder
Steve, my spacers (from spare stand-offs) were also too long. However, I used a Dremel cutting wheel to get them to the right length.
I have one of those Dremel drill press rigs, and I set the height of the cut-off wheel and moved the metal stand-off into the wheel while making sure the bottom of the stand-off remained flush with the drill press base. The lengths came out identical.
If you're hard mounting, the maple ply stacks or blocks suggested by w8ye would also work well. Could make some really cool looking stanchions with the maple ply.
I have spacers that are too large and too small.
#2308
The PSP spacers I used are the same diameter as the Syssa standoff at the fire wall side. I used a threaded aluminum sleeve internally to take up the space around the4-40 bolt. (local hardware store for the sleeve) I'll post a picture when I get home..
Congrats on getting the engine!
#2309
ORIGINAL: GLRogers
Joystick
What number was your engine?
Gary
Joystick
Gary
The engine SN 0900336.
#2310
ORIGINAL: MsgtRob
The engine is so light, I found that I need to have 7 3/4" hub to firewall distance to prevent (hopefully) from having to add lead in the nose.
Any word on your engine yet?
#2312
Your installation looks great, that is what I had in mind.
The engine is so light, I found that I need to have 7 3/4'' hub to firewall distance to prevent (hopefully) from having to add lead in the nose.
ORIGINAL: MsgtRob
PSP manufacturing has some good stuff and they ship fast. I used longer stainless steel machine bolts at the fire wall. (A little more weight) I too hate adding lead weight to any plane.
I emailed Todd for status. Thursday he wrotethat he intended to run my engine that day and ship it back. He confirmed the hub key was sheared. I mailed back asking for shipping notification when it ships and summary of maintenance accomplished. I havn't heard anything back.
#2313
TN
My order number was 391 from 8 Jan. If you are trying to calculate how long it takes to get the engine after you order it like a lot of us did, the engine was actually ready about three weeks ago and I had Todd hold up the shipment because I was on the road.
ORIGINAL: GLRogers
Joystick
Gary
Joystick
Gary
#2318
My Feedback: (16)
Looking at the diagrams which came from early on in this thread -
The stand - offs in the diagram appear to be 1 3/4" plus a washer
Looks like it would take a 2" stand - off distance for the carb to clear the fire wall and have a little breathing room?
Edit:
In the post (two below) his dimension is 1.906" to the rear of the carb from the face of the prop flange
Edit:
#2319
TN
ORIGINAL: ghoffman
Looks nice, where did you get it?
http://swrcengines.com/default.aspx
But it was shipped direct from:
http://www.hiflymodels.com/product-2...tid1=2&rid=224
I have not assembled it yet. It is primarily an Aerobatic plane with full 3D and Pattern capabilities. For pattern, is allows you to move the wing up to 2" from front to back. I must admit I do not understand the dynamics of that?
#2320
ORIGINAL: w8ye
[img][/img]
[img][/img]
Thanks for the diagrams.
I noticed that the dimension that I needed, length from the hub to the back of the carb screws, was not on the side view.
The distance from the front of the carb to the back of the screws is 1.906. That plus the distance from the hub to the back of the engine (3.919") is 5.825", or about 5-13/16".
#2321
ORIGINAL: tsyssa
Generally, I check email every hour or so during the week...emailing or calling is the best way to reach me
Just also wanted to give a big thank you to all our customers who helped make the SAP a reality...not to mention a ton of other people!
Hello,
I did know that I had to wait some time when I ordered but I have asked for updates twice and I am not getting any information. Any idea when the Invoicenumer 383 will be shipped?
It would be nice to have it installed by the summerseason
#2322
ORIGINAL: w8ye
The stand - offs in the diagram appear to be 1 3/4'' plus a washer
Looks like it would take a 2'' stand - off distance for the carb to clear the fire wall and have a little breathing room?
Edit:
In the post (two below) his dimension is 1.906'' to the rear of the carb from the face of the prop flange
Edit:
In your edit, 1.906" should be the distance from the front of the carb to the back of the screws on the carb. That was a major missing dimension from the original drawing.
Another useful, but minor, missing dimension is the distance the carb screws stick out from the rear of the carb, which is 0.360”. The standoffs, with washer?, would be 1.768".
The distance from the front of the hub to the rear of the carb screws comes out to 5.825”.
I am using 2.300” standoffs; the 2” standoffs don’t give much breathing room for my installation because I don’t have a hole in the firewall directly behind the carb.
BTW - I may be off a few thousandths of an inch. My equipment is not all that state of the art.
#2323
Break-in and Manual
Hey gang just wanted to double-check on a couple things. I've searched this thread for two issues and came up unclear:
1) The only "manual" available for the SAP 180HP is the RCExel ignition sheets, right? There's no engine manual yet right?
2) There is no "special" oil ratio recommended for break-in. Seems like running at a conventional 40:1 ratio of conventional oil (mineral or synthetic) to (regular) gas is all that is expected, right? If true can anyone see a technical problem with running premium gas?
Thanks . . .
Thanks . . .
#2325
ORIGINAL: MsgtRob
The engine manual is in my post #1710 read and heed.
