DLE30!
Old 06-05-2010, 10:16 PM
  #2901
donnspadbauer
My Feedback: (26)
Default RE: NEW DLE30!
Yeah Jody is there a difference? you sell RCexl and 42, right?
Old 06-06-2010, 12:20 AM
  #2902
MKnutson
Go for the single bolt prop hub setup, it's sooo much better to work with. The 30 does'nt need multi bolts, the 3.2 Brison I have has a single bolt and it works fine too!
Mark.
Old 06-06-2010, 01:11 AM
  #2903
jedijody
jedijody's Avatar
ORIGINAL: donnspadbauer
42% is made in USA
Old 06-06-2010, 03:33 AM
  #2904
gen3v8
gen3v8's Avatar
ORIGINAL: captinjohn
gen3v8
Thanks for the reply. I am quite sure it will fly strait up with no problem. The big problem will be keeping the speed down...always using throttle management to the max. What did you use for hindges? I do not know if the stock round CA type that came with it is good or??? That is another reason to keep all out speed within reason. Flutter wrecks things fast! Capt,n
I used the CA hinges. Never had issues if you keep the gaps tight.
Old 06-06-2010, 10:01 AM
  #2905
CAT POwer
My Feedback: (61)
CAT POwer's Avatar
Jody what happend with the Zeus from 42% ? Problems ?
Old 06-06-2010, 10:03 AM
  #2906
karolh
ORIGINAL: Antique
Hey, I have customers who really like the side carb..
Different strokes
Ralph, still waiting to hear from you on the side carb.
Karol
Old 06-06-2010, 01:20 PM
  #2907
jedijody
jedijody's Avatar
ORIGINAL: CAT POwer
Not with every one of them but the incidence ratio was to high, there are other options that do the same thing as the Zeus with out the complexity and all of 42%'s other products are stellar.
Old 06-06-2010, 01:34 PM
  #2908
captinjohn
This may be to simple? Mount a servo that is controlled by a extra channel of your choice so that when you flip a toggle switch or flap trim...the servo arm shuts off the power to the ignition. ( Anyrod push rodcould be used for ignition seperation.) You know the switch you turn on to power your ignition. Capt,n P.S. is there a problem with that idea?
Old 06-06-2010, 03:42 PM
  #2909
Antique
Antique's Avatar
Too easy, John, RCU people LIKE high tech complex thingys..
The "keep it simple stupid" principle is only for us OLD FARTS..[>:]
Old 06-06-2010, 06:11 PM
  #2910
scflyboy
Men,
Someone asked this before but I still want more info. What is a good aerobatic plane for the DLE 30? Who is SAPAC? They have a Extra A330. Never heard of them. How about Seagull Extra 260 180? Any other options?
Thanks men!
Brad
Old 06-06-2010, 07:17 PM
  #2911
cloudancer03
My Feedback: (22)
I am going to fly a seagull extra 260 180 size very soon.I am ordering my dle30 hopefully tommorow.I think it will be great.I hope after this project (knock on wood) to purchase either a velox 68 or sc extra 330 72 inch from ben at 3Dhobby.I own about 6 of his electric 3D;s already and feel they are the best planes on the market! he sells a gas conversion kit for the models and they fly absolutely incredible.. as for other brands extremeflight has a 74 and 88 inch yak 54 that would also be awesome with a dle 30..
did I mention the AJSlick70.andy worked with 3Dhobby and the plane is incredible.I am starting with the seagull as I had it hanging around all last year thinking my satio 180 would power it but seeing these dle 30's I am so excited.I wish I had done it earlier inasmuch as theres a 3D throwndown of sorts in nearby bennington VT this coming weekend.I'll take my viper and 55 inch extra but I dearly wish I had been quicker and got my dle then.
these planes are excellent because of the quality but also the weight to motor at approx 10 pounds means they will fly sick! one of my rc buddies already flies an 89inch 3dhobby shpextra with a 55cc and its according to him hands down the best plane ever at just 16 pounds.
I'll try to post pics in a week or so .but monday my first call is to jedijodi! yippee.
Old 06-06-2010, 07:52 PM
  #2912
Cyberwolf
Cyberwolf's Avatar
This may be to simple? Mount a servo that is controlled by a extra channel of your choice so that when you flip a toggle switch or flap trim...the servo arm shuts off the power to the ignition. ( A nyrod push rod could be used for ignition seperation.) You know the switch you turn on to power your ignition. Capt,n P.S. is there a problem with that idea?
There is nothing wrong with it, except if you have a radio failure,RFI, or a brown out chances are you won't be able to shut the engine off with the radio, whereas with a opto kill installed the engine will be dead in a heartbeat if such a situation happens.
FYI Alot of the older gas plane's and even some glow used the method you have described, worked good as long as there was not any radio or reciever problems.
Old 06-06-2010, 08:13 PM
  #2913
scflyboy
Cloudancer,
Searching the web sites and forums, it looks like the Seagull Extra 260 is a great choice. The specs show a weight of 13#. Is this too heavy? Let us know what jedijody says. Looking forward to hearing more and pics. Good luck and thanks for your help!
Brad
Old 06-06-2010, 08:20 PM
  #2914
trickpony4
My Feedback: (14)
That combo works great. We have a club member that has that exact set-up. The DLE30 is a little power monster~~~
Old 06-06-2010, 08:35 PM
  #2915
Antique
Antique's Avatar
If you have a radio failure all the technology in the world won't save your airplane..No radio, no technology...Might just take less time to hit the ground if the engine is still running...
Old 06-06-2010, 09:03 PM
  #2916
captinjohn
I was thinking the kill button...whatever... would be good on the ground. Looking back though, the guy,s airplane that got away & hit myparked airplaneon the ground ...a kill switch would not have helped. He could not respond that fast...as his engines prop ate away a real big chunck out of my airplane. We remained frriends though. It was a terrific way to meet! Capt,n
Old 06-06-2010, 09:10 PM
  #2917
captinjohn
scflyboy
The Seagull 260 should be good and Pilot makes a good one also for the DLE30. Capt,n
Old 06-06-2010, 09:11 PM
  #2918
kgeb
12lb 13oz power to spare!
Old 06-06-2010, 09:37 PM
  #2919
ipsik
ipsik's Avatar
Look at Pilot-RC  they have very nice 30cc Yak, Extra and Sbach, I have the Yak 54 and an Sbach, both are excellent and availble from Cheif Aircraft and will be about 10 -11lbs ready to fly
Peak Models has many 30cc planes as well
Try Valleyview for some others that are 30cc size.
Seagull planes will fly OK but are not really 3D type.
Old 06-06-2010, 09:45 PM
  #2920
Truckracer
My Feedback: (19)
I've sent this question to Jody but no response yet. Can anyone tell me some measurements from the rear intake 30? I especially need the overall length of the engine from the prop drive flange to the rear of the carb. Also need the measurement from the prop to the back of the mounting lugs. Would like to know the most compact Pitts style muffler available and its overall width. Thanks for any help.
Old 06-06-2010, 10:30 PM
  #2921
captinjohn
ipsik
I stopped in at Chief Aircraft when I was in Florida and seen the planes you talk about. I sure wanted to take one back home with me, but with very limited space in our RV my wife said wait & get one latter. If I kill my G202....I know Chief has the ones to get...for sure. Capt,n
Old 06-06-2010, 10:39 PM
  #2922
Antique
Antique's Avatar
DLE #5450
About 6 1/4 carb bolts to prop mount
add 1/8 with the standoffs, 6 3/8
Old 06-06-2010, 10:54 PM
  #2923
captinjohn
Truckracer
My rear intake DLE30 is not quite 6.300 inch from hub face too rear of carb bolt head. With about .800 inch stand-offs I made the hub face is about 4.750 inch from fire-wall. The shorter than stock stand-off are about 3/8 inch shorter. That makes for a better mount I would say over stock. Capt,n
ID:	1449272   Click image for larger version
Old 06-06-2010, 10:59 PM
  #2924
Phoenex
ORIGINAL: Truckracer
There are pictures like the ones below and a 3D view at the link below.
[link=http://www.dlpower.net/products_view.asp?id=12]DLE-30[/link]
ID:	1449276   Click image for larger version
ID:	1449277   Click image for larger version
Old 06-07-2010, 06:33 AM
  #2925
airega1
My Feedback: (204)
airega1's Avatar
http://<b><u><font color=''#00265e''.../font></u></b>
I'm glad I didn't wait on the rear carb version, my seagull ultimate has to be at 51/4 inches out from the firewall to the nose ring. I just hope I don't have this tilt and stall thing. I got a beautiful Pitts style muffler for 35.00 and it's lighter than the stock muffler, actually when I picked up the box, it felt empty.
