DLE30!
#4126
RE: NEW DLE30!
ORIGINAL: mschulz531
Ditto that...hoping after the end of the year that I'll have enough to get a DLE-30 and a kit to build into a home for it.
ORIGINAL: kerwin50
I'm saving my pennies every day for a DLE 30 don't have a plane picked out yet but I'm looking
http://www.aero-works.net/store/detail.aspx?ID=442
#4127
IL
RE: NEW DLE30!
ORIGINAL: airborne2.4
My eyes are on this for the DLE 30
ORIGINAL: kerwin50
I'm going to build a kit version of the Edge 540 instead.
#4129
IL
RE: NEW DLE30!
ORIGINAL: ed42d-RCU
'I'm going to build a kit version of the Edge 540 instead'
Which kit is that? Could be a nice winter project.
The web site says it requires a 30cc to 50cc engine, so I'm not totally sure the DLE-30 will be enough, but I like the idea of a building a larger plane from a kit instead of buying an ARF. If the DLE-30 won't be enough, perhaps I'll have to get the DLE-50...just not sure yet.
<g>
</g>If anyone knows other kits that would be a good fit for the DLE-30, please let me know.
<g>I notice you are in Buffalo Grove...do you fly at Deer Grove or somewhere else?
My club field is in Ringwood but I fly at Deer Grove from time to time, usually on my way to/from work in Deerfield.
-Mike
</g>
#4131
RE: NEW DLE30!
Have a look at these
http://www.redwingrc.com/planes/sbach.html
http://www.redwingrc.com/planes/mx2.html
#4132
RE: NEW DLE30!
I picked up my Seagull Extra 260 1.80 for pretty cheap on a "grand opening" sale. Think it was $170 CDN or so, so about the same in USD. Shipping made it more expensive, but S&H in the US tends to be cheaper. Good match with the DLE-30.
If you don't have your heart set on building, I bet if you watched for a holiday sale over the next few months (Black Friday, Pre-Xmas, Boxing Day, Post-Xmas, New Years, etc) you might be able to pickup a deal on something similar. Peakmodel.com is another good source for big planes, espc if you get the combo with the DLE30. One of our club members has gotten several 25%+ airframes from there and been really happy with them.
D.
D.
#4133
IL
RE: NEW DLE30!
ORIGINAL: darkith
D.
D.
#4134
IL
RE: NEW DLE30!
#4136
RE: NEW DLE30!
I love ARF's......if I ever build a kit, I don't think I'll fly it
#4137
RE: NEW DLE30!
Piston head carbon build up? As a newbie to gassers I was just wanting to clarify that this is normal with a new engine? With the plug out I can see that a significant amount of hard carbon is builtupon the piston head. So I can only assume there is much more that I can't see too, maybealsoin the ring grooves as well?
It's a new DLE-30 with aNGK CM-6 plug. I now have 2 gal through it using Lawnboy ashless oil at 32:1 as the manual recommends. After periodically checking the plug I could see it was running a little wet, and black with some build up, so this probably indicates a little rich. It also spit black crud forever but is subsiding now.As this is expected after breaking in some, I'venow leaned it a little and it's giving me 7100 or soon a 19x8 Xoar. The plug is now running a dry light brown color. Engine runs great in all phases. I guess the Lawnboy oil could also cause a little build up too. I'm planning to switch to the Stihl Ultra HP next.
I assume all engines get carbon build up to a certain degree in these areas even if not running rich. Just wondering if I should ever worry about cleaning itdown the road or just leaving it be.
#4138
My Feedback: (19)
ID
RE: NEW DLE30!
As posted several times earlier in the thread-lots of people including me have always used or switched to Stihl Ultra in lieu of Lawnboy. Lawnboy does tend to carbon up the engine as does Amsoil.
#4139
RE: NEW DLE30!
ORIGINAL: cmptrguy
#4140
My Feedback: (16)
RE: NEW DLE30!
The Lawnboy is proclaimed to be ashless which should eliminate the gummed up rings?
The oil brand belongs to the Toro lawn equipment Company and is manufactured and canned by Citgo. So it is a name band substance with a pedigree .
Starting back 30 years ago, I used it 32:1 for many years in my chain saws, weed whackers, and model engines and never experienced any engine problem related to oil or the fuel.
I have not used it in the last ten years though.
No comment about Amsoil.
#4141
My Feedback: (22)
FL
RE: NEW DLE30!
if your against the electronic kill switch you can spend about 10bucks and get a dubro kill switch .it can be servo activated and is likely as easy as they can get,
not too many years ago I had one on my giant stinger with a 3w 60.worked fine.
#4142
RE: NEW DLE30!
2 more questions about setting this engine up and then i'm off and running
in first picture i see this little mod to the cover plate in some threads, so is this something i need to do?
the second picture shows the carb as posted by w8ye and the small hole in the choke plate.......should this be soldered up to give the choke more effect?
#4143
RE: NEW DLE30!
ORIGINAL: cloudancer03
#4144
NY
RE: NEW DLE30!
ORIGINAL: summerwind
I never had a problem choking with the hole in the plate. I don't understand the need for the hole, but Walbro makes a lot of carbs and has a reason for it... perhaps to help prevent flooding, or some such, but that is a total guess on my part.
#4146
ON, CANADA
RE: NEW DLE30!
FYI - I installed a 2300Mah A123 battery from WrongWay R/C in my Super Cub, with JR leads for both the RCVR and the Ignition Module. Now instead of two charge ports I have a quality three wire switch for the RCVR inside the cabin and an HD charge/switch for the Ignit. module mounted on the fuse aft of the cowl through which I charge/balance. On my first flight I spent 1/2 hour trying to start the engine before I realized I had accidently pushed the choke lever the wrong way!! Finally I woke up and she started beautifully. A little cold outside so I had to tweak the low end. Flew around for a few minutes before I remembered to turn on the XMTTR timer and then flew for 10 minutes (boy that seemed a long time!) - doing what-ever you can do with a big Cub. Having started with a battery that I had charged up a couple of week ago, I then re-charged it at the field and after all that messing around it still only took 137Mah!! - according to my new FMA Cell Pro Multi4. WOW!
Well this sells me on just one battery for my RCVR and Ignition with a 2.4G radio. It charges up in 15 minutes or less and I have enough capacity to fly a full day - at least! I can charge up and leave the model sitting for a few weeks and still be ready to just grab her and go flying without having to "top it up"! Now just one battery - less weight - less fuss - LOVE IT!
#4148
My Feedback: (22)
FL
RE: NEW DLE30!
there are people swearing they have never encountered a problem.I know a person flying his with a side unit and likes it.but I think the majority of dle30 users are rear carb inducted and evidence suggests it does work better.I ended up with a rear carb and its fine.I had another gasser with a side carb a while back and frankly had no issues but it wasnt a dle..speak with jody at valleyview and he will give you a honest answer!great person to deal with.
#4149
My Feedback: (22)
FL
RE: NEW DLE30!
summerwind the walbro is sensitive to atomsheric pressure and its the float diaphragm under the cover plate that can cause some issues when the air pressure outside the plane flucates significantly.plugging the hole is a good thing and using a film capsule stored inside your fuse can stablize the pressure. there is an excellent tutorial on the web site "Thunderboldt R-C".not only can they explain the situation but they show you how to resolve it very easy and inexpensively.they even have a cheap kit you can buy if your not up making one yourself.
