160fx gas Equivalent
My Feedback: (98)
RE: 160fx gas Equivalent
26cc to 30 cc.
Zenoha and 3W make good engines, and then there's this, it's new.
http://www.rcuniverse.com/forum/m_88..._1/key_/tm.htm
IA
ORIGINAL: JEFFHINES73
Hi guy wondering if you could give me a gas Equivalent of a O.S 160 fx any help would be great
thanks
jeff
thanks
jeff
...can you give us an idea of what model you are considering? The wing area and AUW? In my opinion the model has a lot to do with it. Some would do fine on a 26-30cc gasser, and others may need more to fly like you want them to, that is, if you can add the displacement and not compromise acceptable wing loading.
IA
Exactly ...that's why, in my opinion, it depends greatly upon the model choice, and how the owner intends to fly it. I had a Great Planes Ultimate, designed around the OS 1.60fx....it has a modified Zenoah G62 in it
ORIGINAL: arobatx
Sorry guys I should have said what im putting it in . It will be going in a worlds model GS mustang 80.5 inch wingspan 15 pounds , I was told a G26 was way to small for this plane So I got a 42 cc gasser only bad thing about it is its going to hang out in the breeze alote so I was think of getting a 160 fx for it cuz one can never have tomany motors lol
P.S thanks for all the info
My Feedback: (98)
ORIGINAL: Super08
Your vertical won't be very good with those engines.
My Feedback: (22)
OH
I have a Goldberg Obsession that has a 1.60 FX.... bisson pitts muffler.... true turn spinner , Sonictronic onboard glow and a perry pump...it flies nicely with that combo had it less than a yr and have about a gallon ran through it... but I am thinking that for this plane it might need a Gasser or maybe a big 4 stroke like a saito 180 ? I flies nice but not amazing... it's an 80 inch wingspan and an 83" long fuse... about 15 lbs ...
suggestions on what gasser ? or 4 stroke ?
I was looking at DLE30.... RCGF 40.... crrc pro 40 ... but the problem with this plane is that the cowl is so narrow and small.. the 1.60 fills it up.
Also I can't go any bigger than an 18" prop... am running an 18x8 on it now and have grass stains on the tip... so I think I am pushing the edge on that.
Suggestions would be appreciated
My Feedback: (8)
WA
My friend's Saito 180 swung a Mejz 18x8 about 200 rpm less than my OS 1.60 did (8900 vs 8700), but his had that incredible low end torque and certainly accelerated faster.
Bob Pastorello did a build thread about 2 years ago on the Obsession with a DL-50 on it. It was a ton of fun but WAY overpowered and all that torque from too large a prop would make it hard to fly. However put something like an APC 18.5x12 Pattern or 19x11 on it and it would be pretty fun. Probably a bit more power than a YS 1.70DZ.
**edit to correct RPM numbers**
MB, CANADA
Go with the Syssa for tight cowl spacing and power.
I could not find anything outside the world of nitro or electric to cleanly cowl my KMP PC-9 until I found the Syssa. Tried the DLE-30, couldn't even get it into place.
After the sticker shock ( 3 weeks worth lol) I ordered the Syssa. As soon as I got it and saw how clean it cowled, I had no regrets.
This thing is going to fly like its on rails.
Todd at Syssa is extremely helpful. The price of quality service alone is worth the extra $$$ for this awesome little engine.
If I spec'd the correct model your talking about, it specs identical to my KMP PC-9
thanks
jeff
thanks
jeff
