Firewall Servo Mount
My Feedback: (40)
FL
I need to mount the throtle servo on the firewall, as well as the electronic ignition module. The receiver is buried far back in the plane. I'm assuming this is not a problem as long as I don't use metal to metal from the servo to the carb.
Comments...
Dennis
Comments...
Dennis
ORIGINAL: DennisS
Comments...
Dennis
Comments...
Dennis
GA
depends on the engine.
I have done firewall mounts many time.
servo on one side of the engine box, ignition on the other...
assuming it is a quality engine with shielded ignition, should be fine..
always range check...
the 12" rule is good, but more for older magneto engines or older, non-shielded engines....
