G38 Poor Throttle Response
CO
I've got a new G38 with a C&H electronic ignition that I ran for the first time this afternoon and I'm having a bit of trouble with it. It starts just fine but has very limited throttle response even after it has warmed up. It runs well at about 1/2 throttle but will not respond as I open the throttle and dies if I start to close the throttle. I've reset the low and high end needle valves per the manual but with little effect. I'm scratching my head but not getting anywhere.
Any help is greatly appreciated.
ORIGINAL: crash080
BCCHI
CO
bcchi,
The plug cap is on all the way and the snap ring is in place below the hex. I've opened both needles (L & H) to little effect. I also have to rechoke it every time that I restart it which seems odd.
CO
I've got a new 2000mAh, 4.8v on it and it's fully charged.
I finally got an opportunity to pull the engine out of the plane to check the carb (not enough room to do it in place) and everything looks fine. Guess I'll mount it on the bench this weekend and see what happens.
CO
It sat for about a year from C&H's conversion until I ran it so I was wondering if it possibly had some "varnish" in the porting. I pulled the carb last night and everything is in good shape, installed correctly and clear. The 2000mAh battery is brand new and I've cycled it several times with good capacity. It runs great at the top end so fuel draw doesn't seem to be problem but metering does since it won't run at low throttle settings or idle. If it was running rough or lean I'd be suspicious of the ignition's strength but it is very smooth when running.
