Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 DLE 20cc Gasser! (Data & Links 1st Post) >
Old 11-23-2010 | 05:20 PM
  #1876
a1pcfixer's Avatar
My Feedback: (7)
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Gutaaaooo,
I've got one exactly like that, for my DL50. Got it
from Troy Built Models, and was called a Silent Beauty.
If you looked down the exhaust pipes, you could
see where the pipes went completely to the other
side of the can, and each pipe has several holes
for exhaust to exit from. More of a true muffler than
what most of our gassers come with stock.
NOT really so silent.
Old 11-23-2010 | 05:32 PM
  #1877
ORIGINAL: jedijody
ORIGINAL: Gutaaaooo
Hey Jody, a while back I bought a pitts style mufler from you guys for the DLE30, and one from Jtec: I liked yours much better. However I can't find it on VVRC anymore, what happend? Will you be making one for the DLE20???
Tks!
Yes, we used have a polished one for the DLE30, they were good but a little restrictive, cost a few hundred RPM. The black ones breath better, we may again go back to the polished ones if we can get them to be less restrictive. We will have polished ones for the DLE20 in the near future, maybe a month.
Jody, can you post a photo of this exhaust on a DLE 30. I want to try to figure out if it would have enough clearence so I do not need too chop my cowl in front...right hand side. Thanks Capt,n
Old 11-23-2010 | 08:36 PM
  #1878
ORIGINAL: jedijody
ORIGINAL: Gutaaaooo
Tks!
Well crap, how am I supposed to convince my wife that I need carbon props and a polished muffler?
And you guys are too funny, I'll ask her if she will buy you all an engine for Xmas. I'll just have to wash the dishes and do the laundry for the rest of my life. So much for flyin', but you all have fun with your new engines!
Old 11-24-2010 | 04:59 AM
  #1879
Well, if you'll have to wash the dishes and do laundry for the rest of your life at least you'll be sleeping in the house
Old 11-24-2010 | 05:22 AM
  #1880
a1pcfixer's Avatar
My Feedback: (7)
ORIGINAL: airborne2.4
Plus, each of us will send him photos of the DLE20cc' his wife gives us for Christmas, and he can sleep contently, surrounded by them![8D]
Old 11-24-2010 | 07:59 AM
  #1881
Hey mesaflyer,
If she'll get the engine I'll give you a hand with the dishes and laundry I'll throw in cooking dinner for a DLE 20 combo. I'm looking at one of these:
http://aero-works.net/store/detail.aspx?ID=336
http://aero-works.net/store/detail.aspx?ID=406
http://www.aero-works.net/store/detail.aspx?ID=426
http://secure.hobbyzone.com/rcplanes...ml?media=image
http://www.3dhobbyshop.com/68-VeloxYellow_p_15302.html
Old 11-24-2010 | 10:14 AM
  #1882
mschulz531's Avatar
Hey mesaflyer,
Hey, we have the same Christmas list! For a DLE-20 combo, my contribution would be the dusting and vacuuming. (:&gt
<br type="_moz" />
Old 11-24-2010 | 10:38 AM
  #1883
My wife said she gets to pick out the plane for Christmas, so I said I am not into Cubs, 172's etc. So I said anything from 3DHS, Pilot, Aztech, Aeroworks, Red Aero, etc. I am really hoping she get the 3DHS 68 inch Velox since I have a -20 ready for it. It looks like the ultimate airframe for the DLE-20. It is about the same weight and wing area as the Ultra Stick I have flying the -20 on for a while now and the power is spectacular as is. I know the Ultra Stick is not that great an airframe, but it was convenient to get the DLE-20 in the air real quick. Kind of like the decent looking girl that was always available versus the super model that you don't have yet.
Old 11-24-2010 | 11:44 AM
  #1884
mschulz531's Avatar
ORIGINAL: ghoffman
I hope you get the Velox as well - that is one sweet looking airframe, and the weight of it is amazingly light! The DLE-20 ought to rip that thing around the sky!
<br type="_moz" />
Old 11-24-2010 | 12:28 PM
  #1885
What is the thread size in the end of the prop shaft?
Thanks Steiny
Old 11-24-2010 | 12:31 PM
  #1886
jedijody's Avatar
The end of the prop shaft/crankshaft is not drilled and tapped for a spinner bolt. The propeller retaining nut thread is 8mm x 1.0
Old 11-24-2010 | 01:01 PM
  #1887
Anyone have thrust numbers for the master airscrew 16x8x3. My Dad and I are putting together a ESM B-25 Mitchell with DLE20's. I want to put 3 blade props on it. Saw back in the thread that there are some guys using this prop but did not see any numbers. Think that this plane would look cool with a 3 blade prop!
Charlie
Old 11-24-2010 | 01:03 PM
  #1888
SpinnerRow's Avatar
What RPM are do you guys have your idle set at? Mine wants to die if I have it at about 1700 or so and suddenly drop the throttle to idle from 4000+ RPM. I may have some more tuning to do but right now the idle mixture is set to where there is just a slight hint of a hesitation if I suddenly crack the throttle open from idle. Setting the high speed is a bit more challenging than a glow engine. I'm using a tach and checking engine temp to see where I'm at with that. This engine only has about 20oz through it so far so I know it will get better. I'm flying it in an Edge this Friday.
Old 11-24-2010 | 02:41 PM
  #1889
w8ye's Avatar
My Feedback: (16)
I like to re-do the high speed according to how it acts in flight
Old 11-24-2010 | 02:43 PM
  #1890
mschulz531's Avatar
ORIGINAL: SpinnerRow
Which Edge are you using as a home for this wonderful engine?
-Mike
Never mind...I looked back and found your earlier post about putting this in the AeroWorks Edge 540T.
That plane has a one piece wing, doesn't it?
<br type="_moz" />
Old 11-24-2010 | 03:03 PM
  #1891
a1pcfixer's Avatar
My Feedback: (7)
montanacharlie
As noted in;
[link=http://www.rcuniverse.com/forum/fb.asp?m=10141136]DLE20cc recap........[/link]
...nobody as yet has any such info.
You gonna be first to post such 3-bladed prop thrust info here?
Old 11-24-2010 | 03:10 PM
  #1892
a1pcfixer's Avatar
My Feedback: (7)
SpinnerRow
Mine is round abouts 1800 rpm at idle.
Take a listen here;
[link=http://www.youtube.com/watch?v=SZRdtZxxQP0]DLE20cc test run.....[/link]
Old 11-24-2010 | 03:12 PM
  #1893
SpinnerRow's Avatar
ORIGINAL: mschulz531
No, it has a wing tube like the big boys. It is a 7-8 year old 60-90 sized Edge 540T with a 64.5" wing.
Old 11-24-2010 | 03:21 PM
  #1894
mschulz531's Avatar
It has a two piece wing? I always thought (from what I could see on the AeroWorks site) that it was a one-piece wing, which disappointed me because I felt it would be much easier to transport if the wing was in 2 pieces. So maybe I will get this one after all!
hmmm...after looking at the Aero-Works web site, I don't see that plane...I see the .60-.90 size Extra 260 and Extra 300, but not the Edge. The only small Edge I see is the .40-.61 Edge, which I'm almost positive has a one piece wing. Does AW still sell the .60-.90 Edge?
Thanks for the info.
-Mike
Old 11-24-2010 | 03:33 PM
  #1895
SpinnerRow's Avatar
Uhhh, no you won't. They quit making them five years ago.
Old 11-24-2010 | 06:47 PM
  #1896
zoaartcc's Avatar
The Aeroworks Edge 540T .46 is a one piece wing.
Dan
Old 11-24-2010 | 07:02 PM
  #1897
ORIGINAL: steinywi
DLE-20 + GP Reactor Bipe + 7 lbs 10oz and a zoar 16X8 prop 8400RPM = a real good time. Maiden soon!
Sooo what happened???
Other than snow??
I recieved my Dle 20 today...
It smells of machine oil, so I am a happy snow shovler....( not sure on that spelling)////
Old 11-24-2010 | 07:12 PM
  #1898
Talking about muffler options:
O.S. 1.20ax I thought this would be a good match, or at least possible; Not even close
(see comparison between 1.20AX header, and DLE20 muffler ports)
It is like a Minni dle 55cc.... perhaps someone could use a shrinking ray, on a dle 55cc header??
Does anyone have a header off a Evolution/MVVS 26cc header?
THis mayyyy. be very close...
I will check some specks online...
I need to have mine piped.....
It will be to loud otherwise...
Old 11-24-2010 | 07:52 PM
  #1899
My Feedback: (12)
I was in my local hobby shop today and they had an old stock Sig Mayhem for $175. I had been looking for a reason to buy one of these DLE 20's and now I have one. The cowl on the Mayhem is very narrow at just over 4". Does anybody know the dimension from the center line to the outside edge of the muffler?
Old 11-24-2010 | 08:16 PM
  #1900
ORIGINAL: seagull extra
I was in my local hobby shop today and they had an old stock Sig Mayham for $175. I had been looking for a reason to buy one of these DLE 20's and now I have one. The cowl on the Mayham is very narrow at just over 4''. Does anybody know the dimension from the center line to the outside edge of the muffler?
Stock muffler dimensions;
2.260" tall @ end caps - 3.800" incl exh pipe
1.100" thick out from exh port of eng
2.050" wide @ end caps
Confirmed weight: 29.2 oz with ign. and muffler
Prop range: 14 x 10 -to- 17 X 6
Engine head is 2 3/16 wide
Soooo looks like the muffler will go through the cowl if the engine is centered on the cowl, unless you can angle the engine somehow so the muffler doesn't hit the cowl.
Ed
