RE: mintor engines
Thanks Karol. Do you have great flying weather all year around in Jamaica?
RE: mintor engines
ORIGINAL: karolh I am wondering just how accurate is the RC exl tach, as when bench running my Mintor 22cc it is registering 8,100 rpm spinning a Falcon 17x6 wood prop. How does this figure compare to what you guys are getting. Karol i'm getting similar results |
RE: mintor engines
Ernie,
Yes, we do have year round flying weather here except for when a tropical storm or hurricane comes a calling and sometimes during the month of March when it can get extremely windy.;) TimBle, The M22 is proving to be a real sweetheart of an engine with it's ease of starting, great transition and it runs ever so smoothly. Karol |
RE: mintor engines
good to hear that. It's a real gem in this size class.
RE: mintor engines
Does anyone make a header pipe for the mintor yet? I might want to put a tuned pipe or canister on it.
Thanks, Ernie |
RE: mintor engines
ORIGINAL: Ernie Misner Does anyone make a header pipe for the mintor yet? I might want to put a tuned pipe or canister on it. Thanks, Ernie |
RE: mintor engines
The adaptor sounds interesting. Perhaps someone will offer a header before too long for the 22cc. If I get this engine I know eventually I'll want to put that nice carbon fiber tuned and muffled pipe on it. It's expensive though but what can you do.....
Thanks, Ernie Misner |
RE: mintor engines
ORIGINAL: MTK ORIGINAL: Ernie Misner Does anyone make a header pipe for the mintor yet? I might want to put a tuned pipe or canister on it. Thanks, Ernie |
RE: mintor engines
OK, a new problem. Buddy of mine has a 22cc mintor in a BUSA Eindeker, that crashed on second flight. (reason unknown) Crank was bent. I offered to try and straighten and when I opened it up, found the crankpin had a rear keeper, behind the rod. I am unable to remove it, to work on the crank. I did try a heatgun, no joy. Any ideas? red
RE: mintor engines
Check with Dennis at Top Dawg Aviation, he might be able to help you.
Karol |
RE: mintor engines
ORIGINAL: coralcape OK, a new problem. Buddy of mine has a 22cc mintor in a BUSA Eindeker, that crashed on second flight. (reason unknown) Crank was bent. I offered to try and straighten and when I opened it up, found the crankpin had a rear keeper, behind the rod. I am unable to remove it, to work on the crank. I did try a heatgun, no joy. Any ideas? red |
RE: mintor engines
Let us know how that keeper comes off, it must be a press fit. Nice that they have needle bearings on the rod. What about the wrist pin?
RE: mintor engines
Contacted Top Dawg. Awaiting answer. red
RE: mintor engines
it is SUnday......
RE: mintor engines
It's been a week and no response from Topdawg. Will try to persuade the keeper to come off. For someone who asked, the engine does have pin bearings on both ends of rod. red
RE: mintor engines
1 Attachment(s)
Coralcape, This is a simular crank assembly. My guess is the rod and needle bearings are placed on the crahkpin...then the pin is pressed into the crank throw. It my be possible to press the pin out of the throw. Do some more research first. Best Regards Capt,n
RE: mintor engines
A way to straiten a crank is as follows. Drill a hole the size the shaft and ream it so the crank slips into it with a snug fit. This "hole" must be on a flat metal plate so you can use a dial indicater to see what way the crank is bent. The hole must be drilled exactly strait into the metal plate and cannot lean to one side. Tap the big end of crank in the direction to straiten it. Check all way around the shaft as you tap it with a heavy brass hammer until it reads as strait as possible. I would shoot for .001 - .003 that should be good I would think. Test this method on a crank out of a weed eater or what ever. Capt,n
RE: mintor engines
So what's the verdict on the Mintor rpms compared to the DLE with the same prop?
Thanks, Ernie |
RE: mintor engines
I do nto know the RPM data...do not even own a tack. I did read the Mintor 22 had more power than the DLE. Capt,n
RE: mintor engines
Header for 22, 33, 38 cc. Other types of headers are offered as well as cans type mufflers. Area 51 stuff.
http://www.vulcanhobbies.co.uk/minto...e-1-2095-p.asp |
RE: mintor engines
ORIGINAL: coralcape It's been a week and no response from Topdawg. Will try to persuade the keeper to come off. For someone who asked, the engine does have pin bearings on both ends of rod. red <br type="_moz" /> |
RE: mintor engines
ORIGINAL: turbo.gst Header for 22, 33, 38 cc. Other types of headers are offered as well as cans type mufflers. Area 51 stuff. http://www.vulcanhobbies.co.uk/minto...e-1-2095-p.asp A rather tricky prospect with aluminium <br type="_moz" /> |
RE: mintor engines
Thanks Capt. That keeper looks exactly like it. When I get it off, I'll use my lathe as guide. Test, remove, tap and do it again 'til good. Good to hear explanation for no response. Thanks, red
RE: mintor engines
Antique (Ralph) is the person who told me how to straiten a crank. If my explanation was not right on I hope Antique would explain it...he is the master of this kind of stuff and machining also. He probably forgot more than most people know. He has explained about engines for many years, helping with engine problems. I like the way he does it too....short without writing a book!
RE: mintor engines
Perhaps that keeper is not meant to come off and the whole crank pin could be pressed out instead?
| All times are GMT -8. The time now is 04:27 AM. |
