RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   G26 setup (https://www.rcuniverse.com/forum/gas-engines-142/5083207-g26-setup.html)
Miketc 12-06-2006 03:26 PM
G26 setup
Do you have any photo's to show how you set up a linkage on the throttle?
Mike
L48 12-07-2006 10:22 PM
RE: G26 setup
1 Attachment(s)
This may not be the best way but it worked for me. Doing it this way I kept the origional throttle arm and stop on top of the carb.
captinjohn 12-07-2006 11:26 PM
RE: G26 setup
L48: Is that a regular ignition coil on your G26? What ignition are you running? Thanks Capt,n
Antique 12-08-2006 08:07 AM
RE: G26 setup
1 Attachment(s)
Here's another way.
Miketc 12-08-2006 08:35 AM
RE: G26 setup
Gents, thanks very much, the pics make it very clear on how to set up bell cranks.
When I've completed the set up, I will post some pics of the plane.
Mike:D
L48 12-08-2006 10:15 AM
RE: G26 setup
It is just the stock mag. ignition set up from Zenoh.
Checklst 12-08-2006 01:27 PM
RE: G26 setup
Hear is my setup, I do like antiques bellcrank also.
http://img.photobucket.com/albums/v1...PICT0020-1.jpg
L48 12-08-2006 06:06 PM
RE: G26 setup
Looks like you have your G-26 on a Hangar 9 Ultra Stick Lite also. As you can see by my picture it is a little dirty, it flys alot and is a great plane motor setup. From your picture looks like it is new, if you haven't flown it yet your in for a treat.
Lexmar 12-08-2006 07:41 PM
RE: G26 setup
Hi Flyers!!! Building a GP .60 Stik but with a smaller G20. Did you guys have to reinforce the firewall to accomodate the extra weight and vibration of the gas engines? Thanks.
Checklst 12-08-2006 08:36 PM
RE: G26 setup
L48 she is new almost ready to fly........... and Lexmar I used fairly large triangle stock with 30min epoxy.
L48 12-08-2006 09:11 PM
RE: G26 setup
Yes I reinforced my firewall also. I know a guy that has the same set-up and didn't do anything to his firewall. He hasn't had any problems.
I'll bet that 60 size stick with a G-20 will be a real rocket.
Lexmar 12-08-2006 11:20 PM
RE: G26 setup
I would also like to reinforce the firewall but because the GP stik is an ARF, it may require major surgery to do so. Any suggestions or does anyone know where I can see pictures on how to reinforce? Another question....when assemling your tank, do you use tygon gas line to connect the brass nipple to the clunk? My experience with tygon is that it gets stiff real quick w/c may hinder clunk movement while in flight, what does most people use? Again, thanks very much, this has been very informative, I appreciate all the info.
L48 12-09-2006 01:16 PM
RE: G26 setup
To reinforce the firewall you can do it from the outside if you want to pin the firewall. You can do it by using small tack nails or you can drill and then glue in small hardwood dowls.
As for the fuel line I use the clear yellow line, if it is tygon I cannot say but never had any problems.
I'll send a picture of my 60 Ultra Stick firewall that I pined with tack nails, works very well. I'll send it in my next reply" I have to take a picture of it first.
L48 12-09-2006 01:23 PM
RE: G26 setup
1 Attachment(s)
Here it is.
arobatx 12-11-2006 09:21 AM
RE: G26 setup
Lexmar, use neoprene tubing. http://www2.towerhobbies.com/cgi-bin...&I=LXK824&P=ML Safe for gas and smoke.
It won't harden like the Tygon or others will.
Lexmar 12-11-2006 10:13 PM
RE: G26 setup
Thanks guys,your tips are most helpful,appreciate the help!!!
RTK 12-12-2006 10:57 PM
RE: G26 setup
1 Attachment(s)
One more for you to look at
arobatx 12-13-2006 10:01 AM
RE: G26 setup
1 Attachment(s)
My 26 looks a little different. It's a RCIGN converted 26, but I took it a bit further :)
Miketc 12-13-2006 11:37 AM
RE: G26 setup
RTK, tell me about putting as servo so close to a gas engine with electronic noise.
Is this not asking for problems on electronic feedback to the receiver?
I'm no expert, but all the literature I have read is; "keep the electronics far away from the gas engine."
Mike
Miketc 12-13-2006 11:40 AM
RE: G26 setup
Arobatx, thanks for the pic's on setup and reinforcing the fire wall. Good job, but how about a pic on your throttle set up?
Mike
ORIGINAL: arobatx
RTK 12-13-2006 01:25 PM
RE: G26 setup
I always do a engine on/off range check and the difference has always been less than 10%. To date I have not ever had a problem with feed back or glitches. As long as it range checks you will not have a problem.
You are correct though, more distance is better....
ORIGINAL: Miketc
Mike
arobatx 12-13-2006 02:12 PM
RE: G26 setup
1 Attachment(s)
Miketc,
All I have is a front shot of the engine, but if you look close, you can see the throttle arm (on the top) and the linkage goes straight back into the firewall.
Birddog-RCU 12-13-2006 02:35 PM
RE: G26 setup
1 Attachment(s)
I have several pictures. Sorry they don't go into more detail but maybe they will help.
arobatx 12-13-2006 02:39 PM
RE: G26 setup
hey birddog,
Have you flow the pitts yet? Curious what the all up weight ready to fly is, and what you think of it?
Birddog-RCU 12-13-2006 02:50 PM
RE: G26 setup
It might be difficult to tell by my pictures so... which Pitts? They are both different Pitts models. The S2B or the 12?
