H9 33% sukhoi engine location?
My Feedback: (204)
I recently purchased a pristene 33% H9 Sukhoi, it originally had a DA 85 in it, I am now mounting a D&B 5.1 twin cyl. The mount I'm using requires a new motor box, I copied the offset for the right thrust consideration off of the original mounting marks, but the thrust line looks to be about an inch or so above the leading edge of the wing, is this correct? The manual only shows mounting for the DA 85 and not the thrust line.
