Wendell Hostetler Piper Cub
Hello Guys,
I´m building a Piper Cub J3 from Wendell Hostetler´s plans and I would like to put a RCGF 32cc on it? I would like to know if this one will be good for this plane and what prop I need to usem that motor makes 3.9Hp.
Anyone build this plane? Mr Wendell recomends Quadra 40 or 50cc, I´ve try to put a newer version 50cc gasse like DA or DLE on this plane, but it does not fit in the cowl.
Thanks and best regards
Gaiotto
BC, CANADA
RE: Wendell Hostetler Piper Cub
If you got extra cash, put the new saito twin 57cc 4 stroke gasoline in there, you could swing a big prop at low rpm and have the heads stick out the cowl
BC, CANADA
I asume the new DLE 30 may make as much or more power than the old Q40 and it should fit in there completely. Would a saito 220 on gasoline be feasable? nicer sound than a chainsaw motor crackling away.
Able to swing a 20x8, so this may work
http://www.horizonhobby.com/Products...G36#quickSpecs
