JR 922 RX in A 38%
My Feedback: (21)
JR 922 RX in A 38%
I don't post here too much but I have a question. I am putting together a Great Planes 38% Extra 330S. I have an Emcotech power distribution with built in Voltage regulator and a JR922 RX. What I would like to know is can I run 8 servos through the 922 without the Emcotech? I do not do a lot of 3d stuff just some hover and waterfall and I was told that the 922 has a power bus built in to handle the load. i plane on using A123 Batts for the Rx. All the servos are Hitech 7955 digital.
What do you think
Joe
What do you think
Joe
NH
RE: JR 922 RX in A 38%
I am using the JR 922 with (2) unregulated 3000mah LiPo's driving 6 7955's, 1 7950 (rudder) and 1 5685 (throttle) on a 104 inch AJSlick. The ignition is supplied via the "gear" port on the 922 through a Syssa/Tech-aero IBEC (ignition battery eliminator circuit) which regulates it to 5.3V into the DA-120 ignition. I do fly it hard, full 3D rates, and the AJS has huge control surfaces, and after 59 flights since August, it works great!
NH
No, they work well at 8.2V, no issues. I run a similar, smaller, setup on my Velox with a single 2S 2200 Lipo into Hitec 5665 and 5665's. Not all servos can take the 2S Lipo, but these handle the high voltage very well.
