Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Carden Extra 35%, servo's
Old 05-27-2002, 02:10 PM
Niall
Default Carden Extra 35%, servo's
I am just about to start building a Carden Extra 300 35% and would hope to put a Da 100 in it. What surprises me is that they suggest using only one servo in each wing. Is this enough or should I put two. This is my first big machine and would appreciate any suggestions.
Old 05-27-2002, 02:19 PM
mglavin
My Feedback: (31)
No problem at all, just use a good quality hi-torque servo... I have had several 33% models with one servo in each wing. It also is dependent on the use. If you intend to make the ailerons larger and beat the model up for 3D a second servo is a viable consideration, but again it is not required. Were presently flying a AW 33% 540T with a DA100, one servo per wing, 3D abuse at 25lbs. flying weight less fuel.
Have Fun
