PRECISION AEROBATICS EDGE540T
#501
RE: PRECISION AEROBATICS EDGE540T
Hey markinhedland,
I see you got enough space at the front yard to fly the Katana Mini so work is no excuse mate
P.S Nice photo!
Good luck with the maiden mate
Shaun
Precision Aerobatics Team
P.S Nice photo!
Shaun
#503
yeh i know Shaun, 8 weeks on 6 days off fly in fly out, is a poor excuse!!!!!! might b enough room 4 you compentent 3d pilots but i am trying. any surgestions 4 DVD'S on aircraft /radio set-up 4 3d flying?????? just updated my profile with a couple more pic's if anyones interested
#507
ORIGINAL: mm
hello,
can someone tell me the wing area ?
thank you
stephane
hello,
thank you
stephane
#508
markinhedland
Where in the hell do you work 8 weeks on 6 days off, that's one of the worst swings I have heard of !!!!
#509
Maidened the Edge today between rain shower's.
Mounting the battery up the front was correct for CofG.
Very nice easy flying, only needed couple of clicks of up and she was flying down the strip hands off.
Put a couple of tanks through the DA50, will need a little bit of tuning at higher revs.
Don
Don
#510
Don, Congrats buddy, the Da Has planty of power...though my da was running rich at top end after the third flight i was leaning it out Little bit by little bit, as long as u got a good transition dont touch the Low end needle
i think u will love it, last w/e. we had the edge doing Awesome things, on max throws we had it doing rolling circles, rolling quicker than a blink of an eye.
ur pics look great also....
#511
yeh !! it's a bit of a tough swing-- my choice---work for a contractor- best way to earn big$$$$$$ quick-- want to get another EDGE-(purple this time)- always need to plan the next plane!!!!! LOVE PURPLE!!!!
#512
Thanks Aussie, once I run her in and tuner her up I think she will be sweet.
Have not had too many planes that spend most of their time on 1/2 throttle or below and perform excellently.
Im gunna love this bird.....
Don
Don
#513
Well, Mark as I said 8 weeks is a ******* of a swing, hope the bucks are BIG!
We have a lot of guys working construction and 4/1 swing is a long time let alone 8/1....
Lets hope the next plane is Purple and you get some time to fly it.
Don
Don
#514
back in town for awhile i hope!!! now working on fitting the EDGE out. is anyone useing a JR 9X11 in there EDGE??? could you post your set-up!!
#515
mark, hey there nice too meet you, im using the the jr 9x, its all pretty much straight forward, i used a 9 channel reciever and plugged every servo into their own channel......
#517
hey, i just used what ever is said in the instrustions, i used the flight mode switch, Low Rates, High rates, 3d rates.
#518
yeh thanks Aussie, i've been reading back through the forum pages- you had problems with c/g ? i've mounted the DA to suit my cowl mounting holes, assembled the intire airframe and seem to be able to mount all my necessary gear evenly around the c/g------my c/g looks good so far-- mid PA surgested range!!! gee PA make this EASYYYYY!! i'm pretty new to RC UNIVERSE, not very "PC" tech minded!!can i e-mail you direct???? my e-mail address is [email protected] i will charge the camera batteries tonight & try to post some pics Mark
#520
haveing problems with my camera, think it's about time for a new one. Don , do you live in port kennedy w/a just south of rockingham? mark
#523
Yes it is a shame there is no tunnel for a canister...
I had the recomended in-cowl wrap-around muffler origonaly but it was way too noisy so the only other alternative was to fit a canister, I now have a Pifa canister which is mounted on the underside of the fuse. It is big and needs a long manifold pipe but does quiten it down a hell of alot and also produces more power.
I've been flying mine now for about 8/9 months and it is still a pleasure, looks good in the sky, power to weight is good and will fly slow too, no tip stall, vertical is unlimeted and great for 3D, only downfall I can comment on is the undercarriage is soft and the tail wheel axle wire broke after a few flights which was not that bad as the tail sat too high on the ground and made taxi-ing difficult and easy to tip on its nose so I now have a tail-skid instead which is fine for stearing.
Hey Baldeagle Iam looking for another model to use my MVVS 58 on, any ideas, needs to do 3D/aero's about 90" (2250mm) span max, needs to fit in a estate car and available in the UK ?
Ian
Ian
#524
Still waiting to maiden my Edge540. Got it to the field a week or so ago but it was way too windy to consider a first flight. Since then work and a few other things have got in the way.
Had some trouble starting the motor to start with (SPE40, my first gasser) but seem to have got the hang of it now.
If I can't get out this Sunday gonna take a day of next week.
Terry
Terry
#525
ORIGINAL: glofuel
Ian
Ian
I have mine in a QQ 85" Yak so much power its untrue, I modded it to take a cannister, but the new 86" QQ Yak has a cannister tunnel built in, I inported this myself direct from QQ, Molly at QQ made the whole thing very easy, and even paying all the correct taxes I saved over £100.00 on the UK price.
Mike
