Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Stay tuned, Extreme Aircraft Extra 300 on the way
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 05-21-2006, 12:31 PM
  #626
ICE_MAN
ICE_MAN's Avatar
Default RE: Stay tuned, Extreme Aircraft Extra 300 on the way
Dangit you had to post that link and make me see those CF pants.. Mmmm CF
You're talking about the smaller arm? It say's that it can be used with 0, 3/8's, or 1/4 inch offset.. I assume that you just order the offset you want and bolt it up? What goes underneath it? I see 4 bolts, what are they bolting into?
Old 05-22-2006, 07:14 PM
  #627
KatManDEW
KatManDEW's Avatar
The fiberglass and carbon servo arms connect to a metal servo wheel, which connect to the servo. Below is a pic of my final setup, with metal servo wheel.
Precision Aerobatics doesn't give the complete specs on those arms on that web page, so you might want to contact them. Best bet would be if you could drill your own holes for the pull-pull attachment to the servo arm. That way you could match the offset you need for your rudder control horn offset from the hinge line. I ended up with a 3-1/2 inch wide arm (same as the width of the rudder control horns), and a 0.42 inch offest, and since you have the same plane and control horns, yours should be pretty much the same. I have zero slack at full deflection. I choose an offset that yielded cables just a hair looser at full deflection than at center (didn't want to inadvertantly induce additional, possibly damaging, tension).
There's an article in this month's Fly RC magazine about a 35% Giles from Aviation Models (which happens to have almost EXACTLY the same covering as the Planes Plus version of our Extra), and they supply the Giles with a metal rudder servo arm that meets the criteria we are discussing. I really like that feature.....
It's also interesting that they're flying that 35% Giles, and it looks like it was designed for, one rudder servo..... Different designs of course have different flying characteristics, but this got me to thinking that I have plenty of models that will do knife edge loops until the cows come home, using a rudder servo with considerably less torque than the overall model weight..... This is no doubt due to the leverage involved with the distance from the rudder to the center of gravity.
There's a good article about Ackerman rotary to linear differential here;
http://members.cox.net/bdfelice/Ackerman/ackerman.htm
ID:	465271   Click image for larger version
ID:	465272   Click image for larger version
Old 05-24-2006, 10:03 AM
  #628
budgetdude
budgetdude's Avatar
Kat have you flown that combustion challenged machine yet?
Old 05-24-2006, 10:53 AM
  #629
ThaFlyer
My Feedback: (16)
Is this over kill for the PP 34% Extra?
two 5595 on ea wing
two 5595 on the rudder
one 5595 on ea elev
That is my current setup but I am wondering if I could reduce it to 1 5595 in ea wing and rudder.
Andrew
Old 05-24-2006, 11:30 AM
  #630
KatManDEW
KatManDEW's Avatar
Negatory budgetdude. I just got the new receiver and got it installed late last week, and conditions since then have been far from prime for a maiden of this magnitude
That said, folks should take all my input about this bird with a grain of salt
Old 05-24-2006, 10:09 PM
  #631
budgetdude
budgetdude's Avatar
Kat I am looking forward to hearing what happens when you throw the switch. Thaflyer I think I am getting some rudder blowback on 2 5945's on a 1 roll roller. You could be set if your next plane might be a 40.
Old 05-25-2006, 08:36 AM
  #632
ThaFlyer
My Feedback: (16)
I have one of two of (that I know of) the PP 38% extras that made it to the states. And Im scratch building another 38-39% extra from some Danny Snyder plans. I'm planning on selling one of the two to get me started on a da-150. Anyone interested? The PP 38% has the same scheme as the PP 27%.
BD, are you running a 4.8 or 6v system on the 5945? If it is the 6V then it sounds like I need to stick with the 2 5955's. What about the wings? If I use one 5955 on the wings, then I am haveing a hard time figuring out which servo bay to put it in. Running a 6v system of course.
Old 05-25-2006, 11:59 PM
  #633
budgetdude
budgetdude's Avatar
6V, dont know about the bay.
Old 05-26-2006, 09:48 AM
  #634
ICE_MAN
ICE_MAN's Avatar
WOOHOOO! Just ordered EVERYTHING (almost) to finish my Extra!! The only things I didn't get are a spinner, Because I can live without one.. And a Fuel dot, because the only alum. one besides DA is Rocket City, and they're out of stock at Airwild.. But It's OK cause I can live without it too!
Old 05-30-2006, 06:50 PM
  #635
ICE_MAN
ICE_MAN's Avatar
Well since I'll be about ready for my maiden flight here with-in the next couple of weeks I hope, it's time to figure out what to expect of this thing.. Anything I should do or shouldn't do as far as radio programming? Exponential? Rates? CG? How should I be attempting to fly this bird, speed wise? As in where does it groove along the best for my first few flights? You know all that nervous first flight prep.
Gotta keep this thread goin!!!!
Old 05-31-2006, 06:06 AM
  #636
jeroli27
My Feedback: (9)
There's not much to worry about with this plane, I'm really happy with how it flies. For the maiden flight I had the CG right at 8" back at the fuselage, and it flew good and settled in for really easy landings. For the throws I pretty much just maxed out the throws for high rate and cut them in half for low rates. On expo I usually am at 45-50% on high rate and 35% on low rate. The plane has such a wide flight envelope just fly it how you fell comfortable and you should have any problems. After a dozen flights the only thing I have run across is on the last flight covering on one of the wings started comming off in flight. I was able to land it before it got to any of the open ribs, but most of the leading edge had come off. Just make sure you iron the whole plane and that every thing else is secured well and you shouldn't have any problems with this plane, Other than the covering I am really pleased with the plane.
Old 05-31-2006, 04:28 PM
  #637
budgetdude
budgetdude's Avatar
Ice it will be the easiest plane you have ever flown. There were 3 of these things at the columbus IMAC, 1 in Unlim and 2 sportsman.
Old 06-02-2006, 12:04 AM
  #638
Bob101
Anyone have one they can check the downthrust on the engine. I had to rework my firewall a bit and didn't measure mine first. Seems like the stock one was set at 2 degrees of upthrust which sounds odd....just wanna double check.
Old 06-05-2006, 09:43 AM
  #639
ThaFlyer
My Feedback: (16)
Maiden my Planes Plus 34% Extra this weekend. Nice plane but she had a few tendencies that I will have to work around.
She flew a little nose heavy with a 3w-100 but nothing I can't fix with some extensions battery movement. It also has a unappealing wing rock in harrier and it has a light snap on 3/4 elevator that could get to be a problem. Going to try a couple of DSF fins on the wing tips to see if that help the wing rocking. Will have to get the CG where I want it before I can evaluate the rest. And this thing hovers like you would not believe!
Anybody else seeing the same wing rocking?
Old 06-05-2006, 06:03 PM
  #640
ICE_MAN
ICE_MAN's Avatar
Well I got my 3W fired up and running. I have to replace the foward fuel line due to an air leak somewhere causing bubbles to the carb.. Other than that the 106cs is running awesome. Then I need to tighten my pull-pull cables and balance her. Balance should be 8 inched right? And the plane should be rightside up?
Old 06-05-2006, 10:16 PM
  #641
ThaFlyer
My Feedback: (16)
So what is this plane anyway? 300, 300s, 330, or 330L. Ive heard them all.
Old 06-06-2006, 12:10 AM
  #642
budgetdude
budgetdude's Avatar
I think a 300S because it has a single seat canopy, and a low wing. Look how long it is though, more like a 2M pattern ship than an extra.
Old 06-06-2006, 02:37 PM
  #643
gbrod
I would be real careful buying anything from PLANES PLUS - CARLA KANAK
She has my $1,400 and unfortunately,
a) Did NOT DELIVER the plane she sold me at the Toledo Show
b) has not refunded my $$ as promised on April 16th
c) does not respond to e-mails or phone calls
Happy flying
George Brod
Old 06-06-2006, 04:43 PM
  #644
ICE_MAN
ICE_MAN's Avatar
Sorry to here that George, However there are plenty of people on this forum who have their planes. As of late there has been several threads on the planes plus topic, on both sites I visit. I believe in every one of those threads there's been some kind of mention of a family crisis. Hopefully she'll come through for you.
Now, I got everything working, running properly.. Just need to get it balanced.. The point I'm shooting for is just foward of 8 inches? Do I balance it upright or inverted? Thanks
Old 06-06-2006, 04:55 PM
  #645
Modified
Modified's Avatar
Upright for high wing, inverted for low wing and it doesn't matter for mid wing.
Old 06-06-2006, 05:15 PM
  #646
ICE_MAN
ICE_MAN's Avatar
Cool, It looks like the wing might be slightly lower on this.. I'll try it both ways thanks
Old 06-06-2006, 05:28 PM
  #647
DENNIS C
My Feedback: (99)
DENNIS C's Avatar
ORIGINAL: gbrod
Happy flying
George Brod
You might not either ..i heard she got evicted on june 1st.
Old 06-06-2006, 09:19 PM
  #648
ICE_MAN
ICE_MAN's Avatar
Welp she balances right at 8 inches! The plane came out at 26.5lbs Soaking wet (32 oz. tank)! I fired up the 3W just long enough to get a range check and get it tuned for a good transition. It all went well but it's still failing the range check. I get to like 0 ft antennae down and thats about it.
Old 06-07-2006, 08:20 AM
  #649
ThaFlyer
My Feedback: (16)
Ice, what all do you have in the plane. Mine came out 27.8 dry and a tad nose heavy.
3w 100
27-10 mejzlik (no spinner)
8 hitec 5955's
1 jr 537 throttle
6v nimh 2700mAh
6v nimh 1800mAh
4.8v nimh 2700 mah
32oz tark
3 mip switches
1 jr 9ch PCM RX
Old 06-07-2006, 08:30 AM
  #650
DENNIS C
My Feedback: (99)
DENNIS C's Avatar
ORIGINAL: ICE_MAN
0' feet that dont sound right.....what is your set up.sounds like you have something very wrong even on a short check you should get farther then that.
