Another H9 27% Extra 260 question...
Regarding the motor mounts and tank...
Of the H9 ARFs I've done, about half of them had usable motor mounts and tanks; half were not. I see where the issue mounts on this one are slotted aluminum. I'll be using an OS 1.60/Bisson Pitts muffler. Are the kit mounts good, or should I get the GP nylon large mount?
Is there room under the wing tube for a 16-20 ounce DuBro or Sullivan tank? I'm trying to decide whether or not to get a Perry VP-30. If the tank cannot be mounted on the CG, why bother?
TIA...
TIA...
AL
RE: Another H9 27% Extra 260 question...
Steve,
I didn't use the cheesy H9 engine mount, I did use the tank provided in kit and there is plenty of room under the wing tube for the tank.
Frank
Frank
