Precision Aerobatics 35% Extra 330L Build and review
#501
WA
RE: Precision Aerobatics 35% Extra 330L Build and review
Good evening Guys,
Here is the latest addition to the E-flightline Hobby giant aerobatic electric planes.
This airframe will replace our 33% YAK and we are going to get it dialed in for the Tuscon Shoot Out
Here are the specs:
Airframe
Extra 330L
Wingspan 106.4"
wing area 2128
Power system
Neu 2215 2y
Neu 6.7:1 gearbox
Castle Creation HV-110 ESC
Tanic 12s2p 10,000mah
Tenn. Prop (custom made) 30x20
(8) 8611A JR servos
(2) Fromeco 6v regulators and switches
(2) JR PCM receivers and matchboxes
(2) Tanic 2s 2200 receiver battery packs
Static power output:
Amp draw 126.4 amps
~ prop RPM: 4100
~ thrust: 55lbs
~ watts: 6000 peak
Here are some pix and a link to the new video that Kyle did during a noon time demo at the Pacific Coast Freestyle Championships.
www.e-flightline.com/movie.htm
If you have any questions please let me know.
Splash
Here are the specs:
Airframe
Extra 330L
Wingspan 106.4"
wing area 2128
Power system
Neu 2215 2y
Neu 6.7:1 gearbox
(8) 8611A JR servos
Amp draw 126.4 amps
~ prop RPM: 4100
~ thrust: 55lbs
~ watts: 6000 peak
Splash
#502
Outstanding flight performance and that was their first flight on the Extra!!
Well done to E-flight line team.
Unbelievable what these guys can do with electric gear [>:]
Shaun
Precision Aerobatics Team
Shaun
#503
GA
Mine is on the way [sm=bananahead.gif] Get ready guys, I'm sure I will be asking everyone questions during the build.
#505
My Feedback: (19)
Guys, getting ready to sell mine. Making room for a Comp ARF 260 and need the dough. Very little time on it. The new wings are still in the box. 3W 106 toc, Chip Hyde pipes, Hitec 5955 and 5945 servos. Awesome plane but I have to let it go. Will take some pictures and list it tonight.
#507
Been a while since Ive checked the forum, been a while since Ive worked on the Extra, but I have moved from Australia to New Zealand so Ive been busy. I've nearly finished the build, just some last final details to work out. Should have it flying in the next week or two. By the way have you seen the 35% pilots PA have on their website?? Awesome. Plane cant fly without a pilot..
JP
JP
#508
Damn the electrified Extra flies good........may be partly the pilot, definately a good vid though, worth downloading!!
Jason
Jason
#509
ORIGINAL: Cobri
Splash
Splash
Splash - what an great video! really show what this plane (and this pilot) is capable of ! Kudos to Kyle
666
#510
ORIGINAL: 666
666
ORIGINAL: Cobri
Splash
Splash
666
As far as I know they are working on another vid after they changed a bit the CG
so this one should be better than before
We'll wait and see
Shaun
#511
Hey guys... I am finishing my much delayed PA330, and looking for some help on locating the exits for the pull pull cables for the rudder. I'm pretty sure I have seen it this forum before, but can't seem to spot it right now. Photo's and measurements would be really helpful!
Lloyd
IMAC 2266
Lloyd
IMAC 2266
#513
Gotta run them crossed from what I can tell. If i run them straight, they will have a lot of cable outside the fuse.... Using a CF servo arm the same width as the CF horns on the rudder. Is there a manual or drawings that I missed somewhere?
#514
I am running them parallel no probs. This is a better way of setting up a pull-pull system.
Check your email. We’ll get you more details about the setup
Shaun
Shaun
#515
Lloyd, I too am finishing my much delayed Extra. Now all that is left is to rig up new wings and we are readfy for the air...
FYI I ran my pull pull crossed with no excessive slacking when full rudder. If your servo horn is offset this works well, if not, like Shaun says, parrallel is geometrically better.
jason
jason
#516
I originally was planning on crossed, but straight doesn't make much difference for the exit location. What I am concerned about is that there isn't any balsa etc to go through, just covering, at the exit points. I want to make sure I haven't missed something... I am considering putting some balsa in, reaching in blind... so that I can use it for exit supports..... Where do you see the cables exiting the fuse? I can measure from the end of the fuse side forward, excluding the tapered area for the double tapered rudder, and measure up from the bottom of the side at the point of exit...
#517
Lloyd,
Some printed data is on your way
Now about those exists don’t worry about not having a plate there since the cables should be friction free with no obstructions. The covering is stiff (especially over the black strap which creates doublers).
Shaun
Shaun
#518
We uploaded a new video of the Extra 330
Download the "PA Extra" vid on this link
http://www.precisionaerobatics.com/p...spx?prodID=110
Shaun
Shaun
#519
ORIGINAL: Precision Aerobatics
Shaun
Shaun
#520
Hi Guys
Got my PA330 yesterday......bloody beautiful!!!!
Best wood ARF I have seen. The wing bags, carbon tubes and carbon hardware is beautiful. Every little detail is thought of. Good job PA!!
Buzz
Buzz
#521
ORIGINAL: Buzz Lightyear
Hi Guys
Buzz
Hi Guys
Buzz
Thanks a lot mate
I am sure you will also enjoy flying this model soon
Shaun
#522
Well Guys,
Today was the big day! My big Extra was finally finished and took to the air today. What a bird!! Mine was set up with a ZDZ 80cc with a canister. As the ZDZ is quite a bit lighter than other motor options I added 27mm to the front end and moved the rudder servo tray forward one bay. With batteries and smoker up front, the CG was perfect, and maiden flight required no pitch trim at all. On low rates this thing is a big ***** cat that anyone can fly, then crank on the high rates and she transforms into a monster, even with an 80cc. The thing just floats and floats on landing, shes so lightly loaded. Had three flights and Im in love with it! Now I can see what you other blokes were raving about!!!!!!!!
Jason
Jason
#524
What would be better on this plane? a 80cc single, or a 100cc twin?? Also would maybe a 3W 85 Twin work good enough on this??
#525
ORIGINAL: Mikewaller1
100cc twin. Of course other engines will be good too BUT there are advantages and disadvantages with this option.
With single engine you would need to work out the CG, and with 80cc twin you will get the same weight of a 100cc with less torque so I wouldn’t recommend it.
Jason went with the 80cc single engine and that will work well (with some effort on the CG adjustments and lightest gear)
Obviously the plane will fly awesome with super low wing loading.
If you already have in your possession the 3W85 twin I would say yes, go ahead and give it a go with the lightest gear you can find, but if not and you need to buy one get yourself a DA100 or the new 3W106 comp and you will have a big smile on your face at the flying field
Shaun
