Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Pull-Pull Set-up
Old 12-04-2005 | 01:43 PM
JoeAirPort's Avatar
My Feedback: (41)
Default RE: Pull-Pull Set-up
I knew someone was going to notice that. That Nelson nut was too long to get the throws I wanted on the elevators (50+ degrees). So I just used the Dubro nut/cone and cut it down. I didn't want the Nelson horn to turn on the bolt so I used the Nelson nut as a lock nut to make sure the horn stays put. Maybe not necessary but I cranked it on there pretty good and that horn will not turn for anything. It was just a last minute idea.
ORIGINAL: DENNIS C
Joeairport why do you have this nelson nut on your control horn i just gotta ask.
Old 12-04-2005 | 02:36 PM
sillyness's Avatar
My Feedback: (25)
I have 2 of the 35% RCBlimpPro tailwheels and I can indeed vouch that they are the best tailwheel I've ever seen. They aren't the ABSOLUTE lightest (a very close second), but then I've broken 4 of the lightest ones (you know which ones I'm talking about). The RCBlimpPro is indeed bullet-proof and I love it.
Anyway, try running that formula I gave you when using the crossed cables... setup a test rig if you want. You'll have no slop. Bless Pythagreas (sp?).
Old 12-04-2005 | 02:45 PM
JoeAirPort's Avatar
My Feedback: (41)
I made a little diagram and checked that math, looks right on. I have only one question, can you get servo arms with any amount of offset? It seems that there are only a few options out there.
ORIGINAL: sillyness
Old 12-04-2005 | 02:57 PM
sillyness's Avatar
My Feedback: (25)
Nelson makes them in any offset you want. He also has them in stock in very small increments (like 1/16" or 1/8"... something like that).
SWB's arms also fit the bill... just make sure if you decide to order an offset arm from SWB that you ask Scott what the design distance from the servo hub to the rudder hingeline is. As long as you can mount your servo close to that dimension you should have a good setup. As a note, the actual offset of SWBs arm are less than the formula gives, but the formula only takes a one dimensional correction into account... the SWB are also slightly shorter, which can also prevent slack. They give you the added benefit of SLIGHT amount of additional torque delivered to the rudder. The setup he used can only be calculated on CAD... I can't figure out a precise way to do it since the cable tension will change slightly through the servo travel... he has a good compromise setup.
Old 12-04-2005 | 07:26 PM
JoeAirPort's Avatar
My Feedback: (41)
Very cool, I learned quite a bit from your posts, thanks.
ORIGINAL: sillyness
Old 12-04-2005 | 07:57 PM
  #31
Shawn,
Thanks for the info. I think I know where you fly if you go out of Morgan Hill. Getting together would be fun.
Pat
JoeAirPort,
If you ever get around to dumping the Dubro horns, going with the RCL70 type ball links from Nelson, JR, and whoever else is making them now eliminates the twisting problem that forced you to use the nutty nuts. I have to agree that the Dubro horns make for a big assist in lining up with the rudder hinge line, though.
Old 12-04-2005 | 08:49 PM
  #32
JoeAirPort's Avatar
My Feedback: (41)
They are the Nelson RCL70's. The nutty nuts were added just to make sure the Nelsons don't turn on the bolt. I've had problems with the Dubro horns turning on the bolt. They were the 91 and under horns but still, I'd prefer they don't turn. This was insurance, it may look goofy but it works.
ORIGINAL: Silversurfer
JoeAirPort,
