Extreme Flight 88" Yak - Build and Fly
#4378
My Feedback: (63)
RE: Extreme Flight 88" Yak - Build and Fly
ORIGINAL: closetguy
Guy's i got a stupid question,the aileron hinge pins are 8" apart is that close enough?or do need to add one in between them.
ENJOY!
ENJOY!
#4382
NJ
ORIGINAL: Tail Winds
I have a DA50 mounted on 2.5" standoffs and with MTW tuned pipe and no problem with positive CG. The 15 ozs of servo batts are positioned just in front of the fuel tank and ignition batt is at front side of engine box. Holding the black and yellow scheme on the silver line - the nose falls forward. Far from "a very tail heavy Yak ".
Strange how we seem to achieve different results with very similar setups!
ORIGINAL: bgold
I used 3", tried tp get weight as far forward as possible. Useing a KS1060 pipe on
DA-50 makes for a very tail heavy Yak plus you have a little less overlap cowl to hatch and it's
easier to get the hatch on & off with a lot less wear on the hatch.
ORIGINAL: J.F
Hi Guys,
What length standoffs are you using for DA /DL install?
Hi Guys,
I also have the cowl overlap by the required 3/4" past the first former..
What servos are you using in the tail?
Maybe the wood was a little heavier in the tail of yours?
#4383
FL
Donnie, Luis, DBRCA, and fellow Central Florida huckers,
We are having an impromtu fly-in this Saturday, calling it "Huck-day" before Labor Day. A little git together for a little flyin, huckin, eatin, and fun in the sun!. Bring your EF Yaks, any other Yaks, and any giant scale aerobatic, heck if you just want to come and have fun, then do it ! If you are interested PM me and I will send you directions and info!
Happy skies and God Bless!
#4384
Count on Kenn & I on making it Rennie ! Ought to be a greta time. I'm going to see about bringing my YAK for some set up throw pointers and anything else you and the others see fit to comment on. [X(][>:][:-]
Great that the Daytona guys will make it too! Now I know my 30%er SD EXTRA will be the smallest plane out there again!And This Jonathan is some kind of wiz flier too! What a hoot watching such a young n' small tike flying Dad's paycheck around like tomorrow will take care of itsself!
#4385
SC
Rennie for President! Too bad I don't live in Orlando anymore!
Richard. I flew my Ultra R/C Giles 202 with the A123 setup from Ebay and my Spektrum radio that dumped my EF Yak. Didn't get to measure voltage or mah after flying tonight due to an expedited departure from the field related to darkness. I'll do a check later when I have time to observe the charge. No radio issues, though, and that's a good thing. I'll wait a little while before putting it back in my EF, though. Right now I'm happy with the A123's from the Ebay guy. Can't complain.
Doug
Doug
#4388
ORIGINAL: xtraflyr
I also use the 2.5" with the 1060 and header and also didnt have a very tail heavy Yak. I put all the Batteries and regs on the motor box as well as the ignition modual. Mine balanced perfect on the wingtube,it did 3d and IMAC nicely there..
ORIGINAL: bgold
ORIGINAL: J.F
Hi Guys,
Hi Guys,
#4389
My Feedback: (42)
ORIGINAL: djccrn
Doug
Doug
I had let my battery run down to 6.46 volts and then recharged to 6.82 (standard programming) and put just over 2100 mAh back in. So one might fathom two more flights left in it at that voltage. I think that I will stay with a stop at 6.4 volts before going airborne. I lost track this time but think I had put over 10-10-15 min flights on that battery before recharging.
A123's are good for me, I might have to look at running a single A123 on my ignition (G-62 lite) just for comparable capacity and charge times.
Richard
#4390
My Feedback: (42)
ORIGINAL: Flyin Hawaiian
Guys, here is a tast of what you (and I) will be missing.
http://www.youtube.com/watch?v=dOI-EKyrfJk
Richard
#4391
My Feedback: (21)
KY
So, what is the recommened cut-off voltage when charging the A123 cells? I was planning to use my triton closely monitored until I was able to pick up the dedicated charger for these batteries.
#4392
My Feedback: (42)
The manufacturere says to charge them to 3.6 v per cell which would be 7.2 v for the cutoff. I have been running my 2 cell A123 beween 6.7 and 6.8 volts total to keep the voltage similar to what I was getting with my 5 cell Nimh's. If I am not mistaken they can handle up to 4.2 v per cell on ocassion and still go on with a long battery life. Once you get a flight or two in there they quickly will come down to about 6.6 or so and then hang in there flight after flight down to 6.4 for me.
Here is an info page on mfg website
http://www.a123systems.com/newsite/p..._FEB2007-1.pdf
Richard
Richard
#4393
My Feedback: (13)
OH
Guy's not to change the subject because i think i am going with the a123 power, also the more info the better. but i just got the MTW tune pipe from DA,(1060's out of stock) and started to install it, other than being a FREAKING base ball bat. i know it is a little less weight than the KS 1060 and smaller dia. how's the performance on this thing any thoughts good or bad.
ENJOY!
ENJOY!
#4394
Performance is awesome with this on the 88 yak, and 12 inch header i think
its not too peaky and the pullout on the 23x8 is brilliant.
you wont be disapointed.
We've had the 88 yak on a smoke system with this setup and it didnt feel like it had taken on any more weight!
#4396
ORIGINAL: J.F
Hi Guys,
Hi Guys,
- and a few more for the fun of it!
Articulating Pilot & graphics are in its near future!
#4397
My Feedback: (42)
Don't the yaks look more purty by the pool[8D]
Mark I think all that detail work added at least XXX ounces to your plane. Still looks cute chubby! I can't wait to see it fly.
RDB
RDB
#4398
ORIGINAL: rdb127
RDB
RDB
By the water is a nice touch (it actually was the first time assembled totally for establishing CG. Told you I'm getting close!
Still thinking of doing the maiden with you guys in Daytona too! Sorry shame too you can't make the Flyin' Hawaiian's gig this Sat!
#4399
FL
Here is what 2.5" stand offs will look like behind a 5" spinner.
ORIGINAL: J.F
Hi Guys,
Hi Guys,
#4400
My Feedback: (13)
OH
TW,i sure like the louver plate looks great! sense we will never run in to each other i am going to steal that idea from you.just got the MTW pipe installed lastnight,god that thing is long,but i think i may need it for balance.use the DIY header kit from DA works good.could not get any response from ES composites or Mueller header? you know with DA someone always picks the phone up and knows what you need!
ENJOY!
ENJOY!
