Need help with a US 41cc engine
Hello,
I have a US 41 on my Great planes 1/3 scale Pitts. The problem is when I am flying, the engine will skip a beat. This does not happen on the ground and not on every flight. It does not die, just skip. I would be thankful for any suggestions that you may have.
Bob
Bob
ON, CANADA
I agree , . If you just have the carb; opening inside the cowl this can happen . I always put a hole in cowl & have an intake extension , ram air ?witha 45 degree cut to force air into carb; from outside of cowl . Never a problem . If you are just intaking to carb; on inside cowl . all kinds of air happens .
You are both correct, the air intake points at the side of the cowl with no hole in the cowl. I thought there would be enought pressure to force air in. I will cut a hole and see if I can find something to point foward on the carb.
Thank a bunch!
Bob
Thank a bunch!
Bob
Bob,
Inspect you kill switch wiring. If the wire comes in contact with an engine cooling fin, it will burn through the insulation and coil grounding can result.
Bedford
Bedford
I have a solution!!! I had a U.S. 41 on my Giant Aeromaster. The same thing happened to me. Use a velocity stack. Click on this link to order it from Tower Hobbies
