Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Pushrods setups?
Old 12-27-2011 | 12:52 PM
My Feedback: (81)
Default Pushrods setups?
Does anyone have any pictures on how to hook up pushrods on a giant scale airplane? I am hooking up the ailerons servos on a 1/4 scale Gee Bee Y. From the servo to the control horn it is about 4 1/2 inches. I am use to using easy connectors and a clevis on my smaller planes but dont want to do that on this plane.
Old 12-27-2011 | 02:22 PM
Default RE: Pushrods setups?
Du-Bro 440 ball links are your best bet. 4 1/2 inches is quite short so no real need for composite or hardwood dowel. Use a ball link on each end and you'll be fine.
Old 12-27-2011 | 03:14 PM
SunDevilPilot's Avatar
Here is a picture of the linkage I used on my 29% Edge 540. Carbon rod, Titanium ends, and Dubro HD Ball Links. LInkage has been bulletproof for the several years the plane has been in service.
SunDevilPilot<br type="_moz" />
Old 12-27-2011 | 03:56 PM
Zippi's Avatar
My Feedback: (10)
SunDevilPilot has a very good setup. If your on a limited buget you can use 4-40 all thread rod and slide it inside a CF tube and lock it in with 4-40 nuts on each end. Use 4-40 ball links on both ends.
Old 12-27-2011 | 04:01 PM
My Feedback: (81)
Where do you get the carbon fiber tube? And what is the best way to run the other surfaces which are about 18 inches long?
Old 12-27-2011 | 08:46 PM
http://www.abellhobby.com/Pro-Series...cfprkbdpro.htm
Other options also available, gonna pick some up myself.
Old 12-28-2011 | 05:47 AM
wxman2's Avatar
My Feedback: (52)
ORIGINAL: dasquirrelisme
I have been using the Central Hobbies CF pushrods:
http://www.centralhobbies.com/contro...e/pushrod.html
Old 12-28-2011 | 06:20 AM
Mine are from central hobbies. <div>
</div><div>SunDevilPilot</div>
Old 12-28-2011 | 06:32 AM
My Feedback: (81)
Do the cf rods need braced?
Old 12-28-2011 | 04:56 PM
I like Abell's design better than Central, the rod ends fit over the c/f pudhrod, helps to eliminate rod splitting from any side loading. As bracing goes, it's never a bad idea, not shure if you need it, depends on the load.
Old 12-28-2011 | 05:09 PM
My Feedback: (81)
I like all those but what I dont understand is how to come out of the fuse. Do I have to come out with the whole rod or is there a way just to have a 4-40 rod come out? it would probably be about 5 inches outside of the fuse.
