Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Edge 540 27.4% Build
Old 03-20-2014, 04:45 AM
  #776
raptureboy
raptureboy's Avatar
More important is how the incoming air is ducted over the cooling fins. Just like full scale aircraft it is important to have baffles in place in order to force the air over the head and out the bottom. You can cut out the whole bottom of a cowl and still have an overheating issue because the air is just sort of swirling around going nowhere. Search for a guy name Pe Riviers over in the gas engine thread, he has passed away, but his knowledge of proper cooling is excellent.
Originally Posted by box car
Nice big cowl Vincent, you don't want to have a lot of compressed hot air running around in a few mini tordadoes stuck up against the firewall. That only helps reduce the amount of incoming cooling air. Air exit space should be 2 to 3 x the incoming air space. Very nice build__________________
__________________
Old 03-20-2014, 11:03 AM
  #777
box car
[HR][/HR]And more important if air flows too quickly through a cooling plenum it does not have time to collect heat, which is often the case where only a front end guide is used. A plenum, properly constructed slows the airflow, permitting time for the collection of BTU's. The front of the cylinders generally run considerably cooler than the rear, leaving a lot of room for further heat collection as the air flows to and through the cylinder fins to the rear of the cylinder. In effect, in a correcly designed cooling plenum, cool air (relatively) is still introduced to the back of the cylinder. The hottest part of a cylinder is usually right around the exhaust outlet, so capturing that area does a lot all by itself.
[HR][/HR]
Old 03-21-2014, 02:52 AM
  #778
VincentJ
VincentJ's Avatar
Here are a couple of photos I shot of my Edge last night with the wings and tail installed. Not much more building left, then I can get ready for glassing the fuse.
ID:	1980031   Click image for larger version
Old 03-21-2014, 02:57 AM
  #779
TomCrump
TomCrump's Avatar
Beautiful !
Old 03-21-2014, 04:59 AM
  #780
VincentJ
VincentJ's Avatar
Thanks Tom. I weighed the plane as you see it in the last photos, the engine and muffler are under the cowl and the elevator servos and rudder servo are also installed. So far I'm at 11.4 pounds. My target weight is 16 pounds, it will be close...I hope to make it!
Old 03-21-2014, 06:16 AM
  #781
Jim Branaum
That is nice looking. Your target weight is pretty good too.
Old 03-21-2014, 08:16 AM
  #782
raptureboy
raptureboy's Avatar
SWEEEEEEEEET ! NOW YOU NEED TO BUY A TRAILER YOU CAN USE IT TO MOVE WITH ALSO, THATS HOW I WOULD TRY TO SELL THE IDEA TO THE WIFE.
Old 03-21-2014, 12:05 PM
  #783
maekju
maekju's Avatar
Outstanding VJ
Old 03-21-2014, 12:27 PM
  #784
stevegauth30
stevegauth30's Avatar
Sweet. Looks just like an edge. I'll bet you make it with your target weight.
Old 03-21-2014, 01:43 PM
  #785
acerc
acerc's Avatar
+1 to all of the above!!!
Old 03-21-2014, 05:49 PM
  #786
Leroy Gardner
Very nice Vincent, almost forgot how big the rudder is on that plane, should do a nice knifedge if your into that kind of flying.
Leroy
Old 03-27-2014, 05:54 PM
  #787
Leroy Gardner
Vincent hope all is well, I kinda expected to see some glass on the fuselage by now. See you posted on the SW site, just thinking about you.
Leroy
Old 03-27-2014, 06:11 PM
  #788
stevegauth30
Any luck selling the house yet VJ?
Old 03-27-2014, 06:52 PM
  #789
ghoffman
We are still in the midst of Winter. Maybe we will have the first flying day Saturday at a local FBO.
Old 03-28-2014, 02:50 AM
  #790
VincentJ
VincentJ's Avatar
No glass yet Leroy, on top of the kaos that is my life at home, at work I have been prepping/training two of my students for an upcoming national automotive competition in NYC. This has been taking a LOT of my time. My poor Edge has been neglected! I'm lucky to just have the time to check in on your progress and the progress of Robert's creation as well as Kevin's SW!
Steve, no luck as of yet but a lot of window shoppers...
Old 03-28-2014, 02:58 AM
  #791
ghoffman
Vinnie, Matt and I are planning on flying tomorrow at that small airport. If you want to come fly the Spacewalker, call me!
Old 03-29-2014, 07:25 AM
  #792
VincentJ
VincentJ's Avatar
Had a couple of hours to build this morning so I thought I would tackle the throttle servo placement. This location was not the place the plans had called for, I decided to put it here to shorten the throttle cable and have better access. The tray was reinforced with some balsa tri-stock underneath and epoxied into place.
ID:	1982434   Click image for larger version
Old 03-29-2014, 07:44 AM
  #793
stevegauth30
The foam in the center, is that the fuel tank location? Will you have a manual choke or servo operated?
Old 03-29-2014, 01:35 PM
  #794
VincentJ
VincentJ's Avatar
Yes on both counts Steve.
Old 03-29-2014, 01:53 PM
  #795
ghoffman
You can add the foam if you want, but it is not necessary on a gasser. I recommend double sticky Velcro instead.
Old 03-29-2014, 02:07 PM
  #796
Melchizedek
Melchizedek's Avatar
Vincent,
Was just curious. When I was following your SW build you took the same (or similar) trip with a couple of students.
How long have you been taking students to comps and how have you faired over the years if its been multiple times ?
Kevin
Old 03-30-2014, 02:29 AM
  #797
VincentJ
VincentJ's Avatar
Thanks for the tip Gary...
Kevin, I have been entering my students in several competitions for the past 30 years. This event (National Automotive Competition ) in NYC I didn't go to last year but have gone many times over the years, too many to remember exactly maybe around 12 times or so...thanks for asking
http://www.nationalautotech.com/
Old 03-30-2014, 05:01 AM
  #798
Melchizedek
Very prestige's event. Your students must be pumped.
May they do well and make there parents and you proud.
Kevin
Old 03-30-2014, 05:41 AM
  #799
stevegauth30
I've heard that on gasses, but I guess old habits die hard. I still surround my fuel cells with foam ( or at least underneath them).
Old 03-30-2014, 06:04 AM
  #800
Jim Branaum
Yeah, foam is almost a necessity for glow but the only thing to worry about with gas is the tank rubbing a hole in itself. Rather than a "hard" tank installation, I have been using those bubble pack shipping bags wrapped with filament tape on my gas tanks for a decade or more. They provide a strong surface to absorb any movement and a little cushion (not really needed) to the tank. The filament tape helps hold the shape and adds to the 'wear through' resistance.
YMMV
