Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
27% Cessna 421 Twin Turbo Prop
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 11-28-2008, 04:14 PM
  #201
Joulesbee
Default RE: 27% Cessna 421 Twin Turbo Prop
Ron, so pleased you are making progress and that both turbo-props are in. Really looking forward to seeing some video of this in action.
Joules
Old 11-28-2008, 08:12 PM
  #202
slevin1
My Feedback: (23)
Ron,
I have followed the build since the beginning & the plane looks awesome!!! Your shop by the way is STELLAR!!!! A modelers dream!! I know this is a bit off topic but could you include some interior shots of just the shop as well as details as to who built it, types of electrical, heating & cooling systems set up. Does it get cold in the winter & hot in the summer in the shop? Size of the shop?
Saul
Old 11-28-2008, 08:16 PM
  #203
slevin1
My Feedback: (23)
Buzz,
Have you started back up on your Cessna yet?
Saul
Old 12-11-2008, 05:12 PM
  #204
Wren Turbines USA
My Feedback: (39)
Flaps now installed using 4 JR 8411 servos and a matchbox
Old 12-11-2008, 05:13 PM
  #205
Wren Turbines USA
My Feedback: (39)
Pic of the wing
Old 12-11-2008, 05:24 PM
  #206
Wren Turbines USA
My Feedback: (39)
Motor nacelles now ready for final shaping and glass.
Old 12-11-2008, 06:24 PM
  #207
gooseF22
gooseF22's Avatar
looking good buddy!!
Old 12-12-2008, 10:45 AM
  #208
avionics
avionics's Avatar
This is mouth watering Ron !!!
Old 12-12-2008, 11:35 AM
  #209
slevin1
My Feedback: (23)
VERY VERY COOL!!!!!! Ron, please take the plane with you to Joe Nall 2009. I want to see this baby fly!!!
Old 12-21-2008, 09:41 AM
  #210
avionics
avionics's Avatar
Ron;
Is the wing one piece or you planning to make it in to sections?.
Regards
Reza
Old 12-25-2008, 09:51 PM
  #211
slevin1
My Feedback: (23)
I know this is a bit off the topic of the thread, but I had to share this. Check out this build thread
http://www.rcuniverse.com/forum/m_8061081/tm.htm
Saul
Old 12-26-2008, 11:21 AM
  #212
Wren Turbines USA
My Feedback: (39)
Avionics,
Per post #80, it is a three piece wing, designed so that the plane can be transported with the center section assembled. This will minimize the assembly time at the field, requiring only to plug in the outer wing panels and connecting the servo leads....
I have been busy assembling the new Wren 160 motors at the shop, but will take some time during the next week to work on the plane some more and post pics.
Happy New year to all...
cheers,
Old 12-27-2008, 01:45 AM
  #213
avionics
avionics's Avatar
Ron;
Many thanks for the reply. one more question, How do you Sync the turbines?.
Cheers
Happy New Year to everyone
Old 01-06-2009, 07:20 AM
  #214
Wren Turbines USA
My Feedback: (39)
Fuse now attached to the center section. Four hardwood dowels thru the side structure, with an aluminum insert. Carbon fiber reinforcement will be applied next.
As for the engines being synchronized, with the propeller shafts being free spinning in relation to the gas generator...this is not really an issue.
ID:	1104715   Click image for larger version
ID:	1104716   Click image for larger version
Old 01-06-2009, 04:50 PM
  #215
heraldoboldrin
ron
you will use 4 servos for the ailerons... 2 each side..?? it is possible to use ony one servo for each side??
Old 01-11-2009, 08:52 AM
  #216
Wren Turbines USA
My Feedback: (39)
Finally sits on the gear, I only had to add one battery pack to the nose to compensate for the long tail. Nacelles are being final fitted and will be covered with a layer of carbon fiber, then Aeropoxied into place. It now looks as though it may make it to the IMAA Festival!!
Heraldo, I am using one JR 8611 on each aileron, and 4 JR 8411A servos on the flaps... incorporating a matchbox.
Cheers,
ID:	1108301   Click image for larger version
ID:	1108302   Click image for larger version
Old 01-12-2009, 09:07 AM
  #217
avionics
avionics's Avatar
This beauty is coming to life EXCELLENT JOB!!!
Ron how much Dihedral did you give to the stabliser?
Old 01-13-2009, 07:42 AM
  #218
slevin1
My Feedback: (23)
SHE LOOKS SWEEEEEEEEEEEEETTTTTT!!!!!!
Old 01-14-2009, 01:52 PM
  #219
Wren Turbines USA
My Feedback: (39)
I just received from Gary Mueller of Jet Tech...the fuel cell for the twin motors. One tank with dual feeds and one large vent and one inlet for fueling and de-fueling. Made from Kevlar and designed to mount in the center section of the wing on the center of gravity!!! Beautiful work from this company.....and very fast service....The tank design was discussed on Wednesday of last week and one week later I have it!! 160 ounces plus a pair of BVM UAT hopper tanks for an additional 8 ounces..so 168 total fuel on board with a burn rate of 7 ounces per minute at full throttle ( more likely be flown at 1/2 to 3/4 throttle). So flights of 8 to 9 minutes with good reserves....
Jet-tech LLC
715-272-1917
cheers!!
Oh and the question regarding dihedral...1.5 inches at each tip....
ID:	1110738   Click image for larger version
ID:	1110739   Click image for larger version
Old 01-16-2009, 03:23 PM
  #220
samjlee87
This is amazing! Keep up the great work Ron!
Old 01-30-2009, 07:09 AM
  #221
Wren Turbines USA
My Feedback: (39)
Engine nacelles now in place, next will be several coats of carbon fiber to reinforce the center section, prior to sheeting, Once the nacelles are glassed, I'll cut the access hatches in the top to allow me to service the turbines....Firewalls are set at zero-zero...and I have a gyro installed for the rudder.
ID:	1122967   Click image for larger version
Old 01-30-2009, 07:11 AM
  #222
Wren Turbines USA
My Feedback: (39)
Window frame components now glassed and primed. Front side window frames painted. Windshield frame fairing work underway.
ID:	1122969   Click image for larger version
ID:	1122970   Click image for larger version
Old 02-06-2009, 05:33 PM
  #223
geh3
My Feedback: (84)
geh3's Avatar
AWSOME
how much do you project it will weigh? THANKS
Old 02-14-2009, 03:55 PM
  #224
heraldoboldrin
Do you think that i will need to use some degree right in the twin engines because the torque of the engine.. ??
Old 02-15-2009, 02:32 AM
  #225
2engsout
Ron, this is an incredible project...I'm impressed.....you have the most scale Cessna control yokes I have ever seen...Where can I get a pair of those ?? I used the ones from Hobby Lobby for my scratchbuilt 24% Cessna 414 Chancellor. Mine actually look more like the ones for the Titan. Rick
