Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Buiding the 33% Waco YMF-5 Barth Modellbau
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 02-02-2007, 04:41 AM
  #51
redcesar
redcesar's Avatar
Default RE: Buiding pics Waco YMF-5 Barth Modellbau
Yes I now wat you mean I think it is for major adjust on the real Waco , i have also seen it on a lot of pictures.
I have made the stab only removable (see earlier pictures), i think if you made the first sadle adjustable in height you are close to the solution.
Cesar.
ID:	611943   Click image for larger version
ID:	611944   Click image for larger version
ID:	611945   Click image for larger version
ID:	611946   Click image for larger version
Old 02-06-2007, 09:22 AM
  #52
redcesar
redcesar's Avatar
The two fairings on the fuse/wing are put in place and the folie is covering on the fuse.
Cesar
ID:	615006   Click image for larger version
ID:	615007   Click image for larger version
ID:	615008   Click image for larger version
ID:	615009   Click image for larger version
Old 02-08-2007, 02:30 AM
  #53
Alexzzz
Alexzzz's Avatar
I've seen this project in real, and it's going to be a very nice looking plane[8D]
Keep up the good work Ruud!
Greetz.
Old 02-10-2007, 05:45 AM
  #54
redcesar
redcesar's Avatar
Thank you Alex, i will try to keep the spirit up.
I have finished the panels on the fuse. i think that after the paintjob it looks better, the screws are now to much visible.
Cesar.
ID:	617606   Click image for larger version
Old 02-10-2007, 02:46 PM
  #55
BigBoy99
Hi Cesar,
Compliment, your plane looks "GREAT"!!![sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
Which Covering material do you use? And is it easy to handle?
In my opinion the screwheads will get more in the background after painting, same mind like you!
What kind of paint are you planing to use,1K or 2K ?
I have to wait two weeks more, until I will recieve my kit, so told me Peter Barth[]
IĀ“ve gived up my plans, to make the stab pretendable, because of reasons of stability.
WhatĀ“s a Servo is it, in the rear of the cockpit?
Regards
Bernie
Old 02-10-2007, 03:18 PM
  #56
BigBoy99
ORIGINAL: SoCalSal
I used a HiTec 5955 digital that puts out 333oz @ 6 volts. .................. Cost is about $96 U.S. each.
If you have any questions , please let me know and I will try to help.
Steve
Be glad Steve, this Servo costs here in Germany 117ā‚¬, nearly 150 USD !!!!!!!
I will use 4 Hitec HS-645MG, one for every aileron.
Bernie
Old 02-10-2007, 09:32 PM
  #57
SoCalSal
My Feedback: (16)
Well one servo on each will be very good. I'm sorry that the 5955's cost so much in Germany. That just seems unfair to you over in Germany to have to pay almost two times the price for the same thing. there may be a way to order them here in the States and have them shipped to your home for far less than buying them from a German hobby supplier.
Steve
Old 02-11-2007, 05:07 AM
  #58
redcesar
redcesar's Avatar
ORIGINAL: BigBoy99
Regards
Bernie
Hi Bernie,
The covering material is Oratex it is a polyester fabric and it is verry easy to aply.
Look at http://www.oracover.de/xml/frames.xm...ml?node_id=273
I wil use 1K paint, that's a litle bit easyer for me to use. The color i wil be use is RAL 9001. I have not the possibility to spray the the paint so iI wil be use a felt roller.
I hope for you that you not have to waite to long for your Waco, let me now when you recieved it.
The servo's I wil be used are the 645MG and the 755HB for rudder.
You say"not pretendable" okee but for transport it is better to make it removable I think.
Regards,
Cesar.
Old 02-11-2007, 11:15 AM
  #59
BigBoy99
Hi Ruud,
thanks for your quick reply. Oratex is also the material I want to do the covering, I see, I had a good choice
I think. the HS 755HB is a little bit too small for the rudder and elevator. Elevator is the most important rudder in the model,
and if you loose the elevator, you loose the model!!!! I would recommend the HS 5745, for the elevator and the rudder.
It has a power of nearly 19 Kg!!! But this is only my opinion. If anybody else think otherwise.....post!
Or the HS 5955Ā“s, but they are more expansive
I prefer a color, something between RAL 1018 and RAL 1023, IĀ“m a yellow fan.
Chuck sent me the the dwg files for the decals, thanks to him...good fellow[sm=wink_smile.gif] Thanks to him!
Now I wish you for the rest of the weekend best success for your work[sm=wink_smile.gif]
Bernie
Old 02-11-2007, 12:17 PM
  #60
SoCalSal
My Feedback: (16)
Bernie, You say you like yellow?? Here is my Yellow Waco.
Steve
ID:	618651   Click image for larger version
Old 02-11-2007, 12:54 PM
  #61
redcesar
redcesar's Avatar
Hi Bernie
I wil work with 6 V on the servo's. the 755HB is than 13,2 kG.
I wil use for the elevator two servo's, for each flap one servo that's a total of aprox. 21 kG. I dont no if you wil use two servo's on the elevator?
Cesar.
Old 02-11-2007, 01:39 PM
  #62
BigBoy99
Hi Steve,
IT LOOKĀ“S GREAT, compliment !!! [sm=thumbs_up.gif][sm=thumbs_up.gif][sm=thumbs_up.gif]
Is it you, on the photo?
Yes, I like yellƶw, but I prefer more Yellow with red
@cesar
Thats good, itĀ“s a solution, if one servo failure, you have a second on the other flap.
but in this case, I think so, it works like a little aileron and you have to steer against with the ailerons?[sm=confused.gif]
Greeetz to both and all
Bernie
Old 02-11-2007, 09:23 PM
  #63
SoCalSal
My Feedback: (16)
Hello Bernie, yes that is me in the photo.
Old 02-12-2007, 05:45 PM
  #64
redcesar
redcesar's Avatar
I build in the elevator servo's and put the rudder and fairing in place.
Cesar.
ID:	619841   Click image for larger version
ID:	619842   Click image for larger version
ID:	619843   Click image for larger version
Old 02-12-2007, 06:31 PM
  #65
SoCalSal
My Feedback: (16)
You are doing a very very good job on this project. Keep up the good work!!
Old 02-13-2007, 07:27 AM
  #66
BigBoy99
Good job, Cesar!
I enjoy, to look to your pictures, they are very good, to plan the assemble in the mind.
IĀ“m still waiting for my kit.
DonĀ“t stop with the pictures here, itĀ“s a great help for me.
Regards
Bernie
Old 02-24-2007, 04:11 PM
  #67
redcesar
redcesar's Avatar
The headrest is fixed to the fuse.
I am now busy with the cabane struts and the mounting of the upperwing center section, it is a precise work because it sets the angle off the upper wing.
Cesar.
ID:	628821   Click image for larger version
ID:	628822   Click image for larger version
ID:	628823   Click image for larger version
ID:	628824   Click image for larger version
Old 03-04-2007, 01:43 PM
  #68
BigBoy99
Hi Cesar,
do yo know this link? ItĀ“s a report of building a YMF-5 from Barth,
certainly in german, with a lot of pictures.
http://www.rc-network.de/forum/showthread.php?t=36236
Your CD is ready and covered and will be sent tomorrow.
Vriendelijke groeten,
Bernie
Old 03-04-2007, 05:09 PM
  #69
redcesar
redcesar's Avatar
Thank you for the link Bernie, i have read and study it for 2 hours and it give me a lot of extra info.
I am now busy with the N struts.
I have placed the fuse with the nose flat on the ground and put on the wings with the tubes. I have not so much room but this way gives a me a good way to maesure etc.
The angle off the top wing centre section i have already checked and is set on -1 degree.
ID:	634938   Click image for larger version
ID:	634939   Click image for larger version
ID:	634940   Click image for larger version
ID:	634941   Click image for larger version
ID:	634942   Click image for larger version
Old 03-05-2007, 11:44 PM
  #70
BigBoy99
Hi Cesar,
by heaven, itĀ“s not easy, to built in a such small room a Waco 3m[sm=thumbs_up.gif]
Where are you planing the mounting points of fly-wires, outside or inside of the wings/fuse.
Do you use the wires from Gautschi? www.bredavik.se/flyingwire
Regards
Bernie
Old 03-06-2007, 12:20 AM
  #71
GENESIS
Hey guys!
Just finished my 40% Waco powered with a RCS 400cc radial spining a 40-18 prop.
Enjoy the pictures.
Dany
ID:	636110   Click image for larger version
ID:	636111   Click image for larger version
ID:	636112   Click image for larger version
ID:	636113   Click image for larger version
ID:	636114   Click image for larger version
ID:	636115   Click image for larger version
ID:	636116   Click image for larger version
ID:	636118   Click image for larger version
ID:	636119   Click image for larger version
Old 03-06-2007, 09:12 AM
  #72
SoCalSal
My Feedback: (16)
ORIGINAL: GENESIS
Hey guys!
Enjoy the pictures.
Dany
Great looking Waco , I see in the photos that the flying wires are not there. Is this just because you didn't want to rig it up in that snow? or are they just not required on your design?.
Would love to have one but the size, weight and the COST is so far out of the average modlers range it will remain a dream to 99% of most of us average Joe's
Old 03-06-2007, 01:13 PM
  #73
BigBoy99
Hy Dany,
great finish, congratulations! I love this plane(and my woman)!
IĀ“m missing too the flying wires, same first mind like Steve........itĀ“snot so easy to mount them with gloves, ha ha ha
Good job
Regards
Bernie
Old 03-06-2007, 05:13 PM
  #74
redcesar
redcesar's Avatar
ORIGINAL: BigBoy99
I am not mounting The fly-wires inside the wing, i made the mounting points on the same spot were the struts are comming. the two plates.
How, i dont now yet but with a kind of a clip and M3 kwiklinks were I first put out the pin. When i am ready i will show you with some pictures.
I known the wires that you named but it is a little bit expensive.
I think the wire that came with the kit is a little bit to thin, i have one size thicker which i will use.
And Dany, nice pictures off your new Waco, with that engine it will be a real performer....verry nice.
Cesar.
Old 03-16-2007, 01:40 PM
  #75
BigBoy99
Hi Ruud,
whatĀ“s abot news of your Waco?
IĀ“m still waiting for my kit, and this in Germany, the home country of the manufactor......crazy!!!!
In one week I will cancel my order, so I told to Peter Barth.
Perhaps I will build a Boeing PT-17 Stearman 88"( 2,24m), but itĀ“s not a kit.I bought onlyt the plan from Nick Ziroli.
But itĀ“sa lot of work, if you have to built every part by yourself.
Here in Germany we say: The hope is dying at least.....I will wait for one week more. [&o][&o][&o]
Regards
Bernie
If there is anyone in the USA, who knows how to ship a Kit from Genesis to Germany cheep, post!!!!!!
