Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Buiding the 33% Waco YMF-5 Barth Modellbau
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 08-19-2007, 02:22 PM
  #301
BigBoy99
Default RE: Buiding pics Waco YMF-5 Barth Modellbau
Hi guys,
this week I was busy with the fairings of the landing gear, at the pics 1-3 you can see the wooden underconstruction of the fairing.
Next two is paste in the fairings, next is paste in the transitions fuse-gear, than a few pics of transition fuse-wings.
I´m planning, to make the front half covering with ABS(Plastic) plates, and the rear half conventional cover with fabric.
That´s origin like the photo-set I get, I think it´s the Super-Version of the Waco.
Next week is delivery term of the engine.......finally! My greatest sorrow is, that I´m to heavy on the tail because of my modications.
Without engine now I have 2377g load on the tail-wheel. Today I placed some weights in the front of the plane with exactly the weight
of the engine including ignition, and the balancer says 2012g! I´m happy
On the last pic you can see the whole fuselage, the lighter is to compare the size of the plane.
@redcesar
when you next time travel to Austria, visit me, I´m living only 30km distance to the border to Austria!
Regards
Bernie
ID:	745177   Click image for larger version
ID:	745178   Click image for larger version
ID:	745179   Click image for larger version
ID:	745180   Click image for larger version
ID:	745181   Click image for larger version
ID:	745182   Click image for larger version
ID:	745183   Click image for larger version
ID:	745185   Click image for larger version
ID:	745186   Click image for larger version
ID:	745187   Click image for larger version
Old 08-24-2007, 02:56 PM
  #302
BigBoy99
Hi all,
today was christmas, eastern and birthday together, the engine arrived finally.
I ordered a 215, but Airworld couldn´t deliver it, so they made me the offer, to take the 250 for 150€ more,
and I did it, I know, endless power, but I will risk it.
Regards
Bernie
ID:	748676   Click image for larger version
ID:	748677   Click image for larger version
ID:	748678   Click image for larger version
ID:	748679   Click image for larger version
Old 08-25-2007, 12:51 AM
  #303
Alexzzz
Alexzzz's Avatar
Yeah, definetely a very nice engine
Greetz.
Old 08-25-2007, 02:22 AM
  #304
redcesar
redcesar's Avatar
Nice looking engine Bernie, congrats!
Are you put it first on a test stand to get familiar with the engine?
A friend of my has bought the same engine so over about a month I can look for it in real.
Regards,
Cesar.
PS I tested yesterday the modified landing gear and it go's a lot bether less jumpy on the landings.
Old 08-25-2007, 07:23 AM
  #305
SoCalSal
My Feedback: (16)
Bernie.your gonna love that engine. You will find yourself starting it on days you can't or won't be flying just to hear the thing run. I have the 215 in my Waco ( way over kil power) but you just fly with 1/3 power and everything is fine. You can almost do verticals with it wound up all the way. My friend Kris in Holland has just ordered the same motor. I'm now thinking about the 250 for my Big Stearman project I'm building now.
Anyhow Bernie........CONGRATS!!!!! You are now a happy camper as we say on this side of the pond.
Steve
Old 08-25-2007, 03:21 PM
  #306
BigBoy99
Hi guys,
today I made the brackets for the cowling, they are made of 2X3mm plywood, 5 pieces around the cowl. Why 5? The engine has 5 cylinders,
and I thought it looks better for the symetry. At first I thought, that´s a little bit too soft, but glued together, they are very stabil.
see herefore the first 3 pics, at the next 3 pics you can see the cowl fixed on the brackets. Now I have a leeway of 2 cm, to adjust the cooling outlet.
The last pic is a front view with the cowl.
@redcesar
Yes Ruud, I will test the engine before it will be ready installed. It needs 4-5 hours, until the engine is ready to fly, I´ll try, to make a video of it.
@SoCalSal
That´s the reason, because I took the RCS, you don´t must fly with full power, it will be very silent......but with enough reserve
Regards
Bernie
ID:	749437   Click image for larger version
ID:	749438   Click image for larger version
ID:	749439   Click image for larger version
ID:	749440   Click image for larger version
ID:	749441   Click image for larger version
ID:	749442   Click image for larger version
ID:	749443   Click image for larger version
Old 09-02-2007, 12:38 PM
  #307
BigBoy99
Hi all,
here an update of building the Waco, the rear fuselage is covered with oratex. A wonderful material, easy to work with it.
From the cockpit forward the fuse is covered with ABS(polystyrol) plates. I have to drill a lot of holes for the screws.
Yesterday I recieved my mounting dome for the engine, a friend of me made it for me, thanks to him, it looks good!. Now I could adapt it to the firewall.
I built in a side trust uf 2,5° and down trust of 2°, recommended of Peter Barth for the RCS 250.
Now the engine has a distance firewall-propellerplate of 25cm(10 inches) which I need for the cowling, and I´m glad now, to have enough load in the
tail. The balancer say´s now a load of 1960 gramm on the tail wheel! [sm=thumbs_up.gif]
Regards
Bernie
ID:	755212   Click image for larger version
ID:	755213   Click image for larger version
ID:	755214   Click image for larger version
ID:	755215   Click image for larger version
ID:	755216   Click image for larger version
Old 09-02-2007, 01:47 PM
  #308
redcesar
redcesar's Avatar
Hi Bernie
Nice dome you have designed Bernie . I have send the pics to my friend here in Rotterdam, he recieves his Moki this week and build it on a Stearman. Maybe a good idea for him also.
Are you put the plywood first on the fuse and then the abs plates or only the abs plates?
Yesterday I had a few landings on the spot. I became now a litle bit more familliar with the Waco and it is indeed so as described, you can land the Waco with a litle bit headwind on a few metres. It works not every time but it still go's better.
Regards,
Cesar.
Old 09-02-2007, 02:51 PM
  #309
BigBoy99
Hi Ruud,
I use only ABS plates, 0,75mm thick. They are fixed with PU glue, and will be screwed by 1,4x10 mm screws......you know,
there are a lot of...puuuh! For this I glued a lot Spruce pieces in th fuse, to have grip with the screws.
In the front the ABS will be only screwed, by this way I have access to the area behind the firewall.
In the upper front area I had to make some strengthenings, I could´nt believe, only 2 10x12mm spruce stringers and in the
lower front area 4mm plywood should hold a 15 HP engine?
When I´m ready with the fuse side and upper section, I will make perhaps the modification of the gear suspension,
and then cover the lower fuse section also with ABS.
Regards
Bernie
Old 09-03-2007, 06:36 AM
  #310
SoCalSal
My Feedback: (16)
I WANT ONE OF THOSE....make mine for the 215 O.K. I'll pay in U.S. or Euros, or Beer!!!!! Just let me know..
Steve
Old 09-03-2007, 06:46 AM
  #311
Alexzzz
Alexzzz's Avatar
ORIGINAL: SoCalSal
Steve
You could participate in the auction of this one; http://cgi.ebay.de/Grossmodell-Waco-...QQcmdZViewItem
Old 09-03-2007, 07:06 AM
  #312
SoCalSal
My Feedback: (16)
Alexzz...I want the engine mount that Bernie had made for his 250 radial.not a Waco, I have one of those.
Steve
Old 09-03-2007, 07:09 AM
  #313
Alexzzz
Alexzzz's Avatar
Ahhhhh ok, I thought the whole plane
Old 09-03-2007, 08:40 AM
  #314
redcesar
redcesar's Avatar
ORIGINAL: BigBoy99
Hi Ruud,
Hi Bernie,
Maybe an idea, if you place the plywood first (not overlapping each other) you give the fuse in the front a lot more strength and you have a solid base to put the ABS plates on.
When i have done the job (see page 47) I put double sided adhesive foil on the the ABS plates and put them on the plywood and then placed the screws in place like you said.
Regards,
Ruud.
Old 09-03-2007, 01:46 PM
  #315
BigBoy99
Hi Steve,
I didn´t made the dome by my self, a friend of me made it for me. For this dome he needs a raw aluminum
block of 3 kg!!! He made a second for his P 47 1/4,4, but a little bit longer. Because of this reason I could get
the first version.
He is an exellent model builder and I can learn a lot of from him. If You want, I will ask him to make a dome for you?
But it´s not cheap, these parts have it´s price!
See here a few pictures of his work, the pics of the landing gear are from his P47.
Regards
Bernie
ID:	756030   Click image for larger version
ID:	756031   Click image for larger version
ID:	756032   Click image for larger version
ID:	756033   Click image for larger version
ID:	756034   Click image for larger version
ID:	756035   Click image for larger version
Old 09-03-2007, 06:38 PM
  #316
SoCalSal
My Feedback: (16)
Hi, I would love to have one of them. But your friend may not have the time to do such a job again. I would be happy to pay for one if I knew how much it would cost. But if he does not have time I can understand that. I can make a mounting ring for my 215 out of plywood just like I did on my Waco.they don't look as nice but they work.
Steve
Old 09-12-2007, 03:10 PM
  #317
BigBoy99
Hi guys,
it´s a fewdays a go, I wrote something here. I hope it´s interesting for you all.....the resonance could be better.
This days I made the hatch behind the cockpit, the motor installing is finished and the firewall is epoxied in,
and the fairings at the tailplane are ready.
@steve
It looks not good for your mount dome, my friend is very busy, sorry.
What a Stearman you are Building? (Size, Constructor etc.)
Regards
Bernie
ID:	761751   Click image for larger version
ID:	761752   Click image for larger version
ID:	761753   Click image for larger version
ID:	761754   Click image for larger version
ID:	761755   Click image for larger version
ID:	761756   Click image for larger version
ID:	761757   Click image for larger version
Old 09-17-2007, 11:50 AM
  #318
BigBoy99
Hello to all,
The RCS 250 has a little cooling problem, so say other pilots with this engine on board.
Because of this reason I made some baffles of alu tin, 0,3mm strong and formed it to a
half taper. The airflow between the cylinders goes a lot unused through the cowl, and now
this space is closed, the air is flowing very near to the cylinders.
see self:
Regards
Bernie
ID:	764572   Click image for larger version
ID:	764573   Click image for larger version
ID:	764574   Click image for larger version
ID:	764575   Click image for larger version
ID:	764576   Click image for larger version
Old 09-17-2007, 12:41 PM
  #319
ByLoudDesign
ByLoudDesign's Avatar
Most excellent! It is fun to watch your work, storing all this in a brain cell that I hope don't die!
Old 09-17-2007, 01:00 PM
  #320
redcesar
redcesar's Avatar
Hi Bernie,
It is the first time I see such solution for more efective radial engine cooling and I think it is verry effective. Have you seen that somewhere in real?
Regards,
Cesar.
Old 09-17-2007, 01:07 PM
  #321
skylarkmk1
skylarkmk1's Avatar
Bernie,
Looking Good!! Just paint the baffles a gloss black and should you add a dummy Carburator Intake at the bottom between the lower cylinders, it will look even better. P1 Front shot of YMF Classic NC 14081. P2 Close up of Carburator Intake on another Jacobs engine. P4 is another view of the Carb Intake.
Cesar,
It is done in a similar manner on many fully cowled radials as seen in P3, Just a simple sheet metal baffle that fits between and above the cyliders. Not all engines have them.
ID:	764673   Click image for larger version
ID:	764674   Click image for larger version
ID:	764675   Click image for larger version
Old 09-17-2007, 01:14 PM
  #322
BigBoy99
ORIGINAL: redcesar
Hi Bernie,
Regards,
Cesar.
Hi Ruud,
no, that´s my own construction. At first I would make it with Rohacell, it´s a kind of 12mm foam material and heat resistant, but the airstream with
this "thin" material is very turbulent after the cylinders. For this solution I made a template of paperboard, see the pic.
By the present solution it´s more laminar and more efectiv.
Regards Bernie
Old 09-17-2007, 01:25 PM
  #323
BigBoy99
Hi John,
that´s my next problem. I need really a carburator intake, because the carb of the RCS 250 is sensitv against heat.
You can see it, after the flight the engine is hot and will not start again, until the carb is getting cold. I must find a way,
to bring fresh and cool air during the flight to the carb. And it must have a separable connection to the cowl, tho remove it.
Bernie
PS.: From where, by the hell, do you get these excellent pics [sm=confused.gif]
Old 09-17-2007, 01:37 PM
  #324
skylarkmk1
skylarkmk1's Avatar
Bernie,
I am not familar with the 250, but a lot of the guys with big planes and motors draw the carb air from the cockpit area where it is not heated by the engine and is out of the air flow turbulance. If you make a scale type intake as I posted above, you may be able to use a silicon exhaust tube as a connector between the engine carb and the intake ductwork. I would be concerned about having too much RAM air coming in the front and possibly leaning out the engine.
So in summary you have 3 choices;
1. Leave things as they are.
2. Duct air from the cockpit (just behind the firewall actually)
3. Make a functional scale intake.
I did add a couple more pictures above.
Old 09-17-2007, 01:54 PM
  #325
redcesar
redcesar's Avatar
Hi Bernie
That litle cooling problem were you talked about, is that only with 250 or also with the 215?
I can imagine that the 250 with more power than the 215 in the same housing as the 215 have more heat dissipatie.
I have send the pictures to a friend of mine, He have also a Moki 250, it be good for him to.
I put an air intake filter from a ZDZ 160 cc on the carb and that came out behind the firewall in a calm environment where is no air flow turbulance.
I also solder a litle tube on the lid of the carb were the litle hole is in and connect it with a hose also behind the firewall. It's prevent presure differ on the membrane of the carb.
Regards,
Cesar.
