RC Guys Super Decathlon coming
#1226
RE: RC Guys Super Decathlon coming
Hey Jeff
I think I saw your there ready to be shipped out on friday the 15 (If you ordered it already). Dan is a very nice guy gave me a bit of a tour around his shop checked out the other models he sell and lots of blimp stuff. Wish I had more time to spend there.
I have mine at home now and I gotta tell ya im not used to the giant scale stuff thats for sure. Damn this thing is big (I love it!!!!). I can't wait to assemble!!!
Brad
Brad
#1227
Is anyone using the SPE 40cc engine and if they are does the carb and muffler fit unsder the cowel?? they don't have very good dimensions on there website.
Brad
#1228
GA
Brad,
I have an SPE-43 in mine and it fits completely under the cowl. One point though, when I hooked up the ignition, I discovered the metal boot rubs one place on the cowl so I would recommend fitting the cowl with the ignition boot in place.
Jeff
Jeff
#1231
Well found a good deal on a FG-36 decided to go with that. I would much rather a four stroke engine anyways for them scale flybys!!
#1233
My Feedback: (9)
Okay...now time to balance this plane....
First let me say i'm using Futaba S3010's in the elevator and ailerons and a Hitech 6045MG for the pull-pull rudder. Also 3004's for throttle and smoke valve. The question I have is which battery should I use? A set of Sanyo batteries in 6 volt Nic Cad or 4.8 volt Hydrimax in 3600 mAh (heavy!! [X(]) If I use the lighter but stronger 6 volt I'll have to add a few more ounces to the tail. With the 4.8 v heavier battery it's less power but will last a looong time between charges. Plus I can shed the dead weight in the tail to make it balance at 4 1/8''. Weight of the plane is not reallyy the issue...it's a matter of which of these batteries will be better for this plane given it's servo arrangement.
#1234
#1235
My Feedback: (9)
ORIGINAL: bradleyban
http://<b><font size=''2'' color=''#...l41</font></b>
What engine are you running?? Seems that your plane is a little nose heavy?
#1237
Hello! I just flew my Super Decathlon last Sunday 7th in Brazil!
Powered by DA50 with smoke!
See my video on
http://www.youtube.com/watch?v=PazYUfzYe_Y
Let's fly so!
Ricardo.
See my video on
Let's fly so!
Ricardo.
#1239
Awsome video Ricardo. Holy weh it looks like its in fast foward on the flyby. That DA 50 really hauls ass on that plane!!!
#1240
My Feedback: (123)
MS
Ricardo, I am going to install a DA50 in mine as well. Any close up pics of your install and how about balancing? What length standoff's do I need? Thanks and awesome airplane you have there!
Ken
Ken
#1241
My Feedback: (68)
ORIGINAL: rfialko
See my video on
Let's fly so!
Ricardo.
See my video on
Let's fly so!
Ricardo.
great video Ricardo! I love how the DA50 fits entirely under the cowl. Nice fit and finish. Great power, looks like it pulls it like a train
matt
#1242
Hello! See some DA50 instalation pictures (hope it helps!)
I just kept 2 batteries of 6V 5 cells under de wing, also the smoke fuel tank.
Ignition 4,8V 4 cells batterie and the ignition together with the mail fuel tank.
That's it! The plane is about 30 degrees nose down when you fix your fingers 1/3 from the wing face wind to check the CG.
It flies a lot and my first landing was without engine! So the CG is OK for sure! Perfect!
DA50 has less weight than many other smaller engines.
Ricardo.
Ricardo.
#1244
Hello!
Today I'll start posting some pictures of the progress on my Decathlon.
It will be powered by a ASP 180 Four Stroke.
Now I'm working to add some details on it.
First of all I decided to modify the upper window. Now it's square(like the real airplane) and removable.
I hope the pictures helps those who are working on the SD too.
Thanks!
Thanks!
#1247
VA
Hey guys
Just completed mine. (Don't ask, LOL)
It's RTF, but in balancing I find that I'm going to have to add 6oz to the TAIL to get it to balance. I've got an OSMax 160 2stroke up front, OS Metal mount, slimeline Pitts muffler and needed 1/4 inch plywood spacer to get the proper firewall to prophub clearance. (Pic of engine install attached.)
Anyone else had to add tial weight to balance? Doesn't sound real normal to me.
