Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
 I need help with my geometry setup on elevators >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 08-17-2007 | 07:24 PM
Default I need help with my geometry setup on elevators
I have a Hitec programmer and have to get my linkage to the elevators set first before I program them. I have the elevator servos in the fusalage up front as opposed to the rear since I needed the weight up front. My problem is finding the center point of the servo. Now I know that you have to adjust the pushrod length to get the correct travel on the elevators and the equal throw both sides of center on the servo. Now my pushrods are angled off the servo arm slightly since they exit out the sides of the fueslage at the rear.
OK, say I have the push rods hooked up to the control horns on the elevators and I need 50* of travel. The pushrods by the way are carbon fiber rods and both are about two feet long. Now I have watched the downonthedeck videos using the protractors, but should I first aim to have the servo arm lined up 90* to the servo or the servo arm 90* to the pushrod since they are angled slightly? Where should center be? This is where I am having my problem, on the servo end. How do I know how long to make the pushrod if I don't know where center should be?
Old 08-17-2007 | 10:16 PM
ByLoudDesign's Avatar
Default RE: I need help with my geometry setup on elevators
Ideally you would want both the elevator control horn and the servo arm the same lenght or as close as possible. If they are far off in length this is where you start ending up with unequal throw in the control. For example if the servo are is half the control horn then the servo has to go a lot futher to get the desired number of control surface degree ghange. If you can, at it is not always possible the servo arm and control horn should be parallel with one another and the control rod perpindicular to these arms at 0° of control, this gives you maximum transfer of energy. If you can make a sketch of the application I'll try to set somrthing up for you, I am a CAD drartsman by trade so it would not take long and I would be glad to do it!
Old 08-18-2007 | 12:35 PM
My Feedback: (62)
I'll get a post on here so the thread will go to my inbox.
Can't wait to see the illustration.
