Building the Hangar 9 Cessna 182 Skylane
#1201
RE: Building the Hangar 9 Cessna 182 Skylane
ORIGINAL: fiifiward
Weather was awesome today it could be any better for the first week in Spring. As a result of the nice weather with calm winds, I ventured out to the filed to have my Cessna flown and filmed. I had a seasoned pilot at my local field fly her and put her through a battery of flight tests. Weighing in at just over 26 LBS, I will admit she flew pretty well. My onboard Tach recorded Max RMPS in the region of 7200 and 7400 rpm, not bad for a three blade 16 x 8 prop. I intend to try out a 18 x 6 to see if the rpm's increase a tad bit. For a plane this size, it was able to achieve a top sped of about 85 mphin level flight. I will have a video loaded on youtube shortly. I love this plane.
Below is the link to the video...
http://youtu.be/ic8E24Esn7g
Wow.......26 pounds !![X(] And I thought mine was heavy.
Joe M.
#1202
Thanks Joe, .. This can really take a pay load. I actually think she can fly with 28 lbs as the max...[:-]...
Here's another video from the cockpit..
http://youtu.be/sG9Afnm16ow
#1203
ORIGINAL: JoeMamma
Glad the maiden turned out OK for you ! Isn't she a nice flyer ? Nice video also.
Joe M.
ORIGINAL: fiifiward
Joe M.
#1204
Hi Ron,
These are a set of Hobby Lobby's 1/4 scale Cessna yokes. I used them on my own 182 and they fit perfect http://www.hobby-lobby.com/1_4_scale...ueryId=1132771
Joe M.
Joe M.
#1205
Hi Ron:
Its great to hear from you... How is your Cessna doing? Regarding the 1/4 scale Yokes from Hobby-Lobby, I got me a set and it seemed that it looked a tab bigger on the console. I tried the 1/5 scale Yokes from IFlyTailies and that seem to be a great fit. Trying to work out the jig right now so both yokes will respond to transmitter input. Would be so cool!!
#1207
ORIGINAL: Marco marquez
I'm looking to buy a hanger9 Cessna 182 Skylane if anybody has one for sale let me know pls thank you
I just looked...........I didn't know Horizon had discontinued it. [] They DO still carry some parts for it though.
Joe M.
#1208
I just got a H9 182 from a friend, I didn't like the color scheme so I changed it to this older Cessna scheme. I like it much better. G-38 powered and has a Robart nose strut. Awesome flying model...
#1209
ORIGINAL: airportbum
Wow........she looks great !
I also like your new color scheme.
Mine is already for its second (???) maiden flight.
Late last year during a misjudged landing, I missed the edge of the grass field and just caught the edge of a soybean field. Did quite a bit of damage to the nose gear, firewall and all the supporting wood........no nice clean breaks, just a lot of torn wood.[&o]
Did a major repair during the winter and still have not flown it this year......YET.
Joe M.
#1211
Ijust, TODAY, received a new, unopened , in box "HANGAR9 Cessna 182 Skylane 95"" that Iam opting to immediately sell and saw that you are looking. I had thought Ihad an engine that Iwas going to get a deal on..but Idont want to shell out too much on this. If you are interested in buying the kit i have now, let me know... it is straight from a hobby store i was able to find that had it.
jon
jon
#1213
Hey guys,
my adventurous-self began assembling this last week.. and while it is looking great, there has been those "flawed" instances.. like cracked servo blocks (epoxy corrected) and a wing strut nut being loose and ripped out of the wing when tightend (also epoxy corrected
but, when things dont match instructions, i get really freaked out......I am currently at the hinging the rudder phase, with the rudder torque rod. ~ no where is there any mention about the bushings that are on the rod and how they are to be secured... there are two with two holes each..looking like they are to be screwed in? the instructions reference epoxy, but dont show the bushings pictured. anyone know what im running into? appreciate the help and positive reinforcement
thanks,
jon
thanks,
jon
#1215
RonTins
Hi my name is Ivan and I'm from Mexico
I see that you have camera in your cessna 182... have you flown FPV with it?
I have a cessna 182 too with a complete FPV system even with a yoke to fly it with it...programmed by a friend in Canada... (Force Fly)
I am new in this forum so I would like to share some pics when I fly for fiirst tme FPV...
Hope to see your project completed..
Regards from Mexico
Ivan Machi
Regards from Mexico
Ivan Machi
#1216
Hi Ivan:
I'd like to see the mods you made on yours. Mine is almost complete. I am holding on installing the front windshield until I am sure I can no longer get clear wind screens up front. i am yet to fly it FPV though.
#1218
My Feedback: (9)
NC
Little bit of a late reply, but Airportbum your Cessna is absolutely beautiful. One of the best repainted airframes I have seen. Makes me want to start stripping mine now. The older Cessna schemes have always been my favorites. The newer schemes are downright ugly. I have had a lot of luck with epoxy finishes on Ultracote, what did you use?
Scott
Scott
#1219
Its been a while since I have been on this forum... Anyone interested in buying my Cessna? Complete plane minus the Rx for 500. Or I can include Spektrum rx for 100.00 more. I have had plane since they first came out, but have never had time to fly it. I had at field but failed range check on FM system. I upgraded to 2.4ghz, but don't have the time to go and fly it.
http://houston.craigslist.org/tag/4120905620.html
I will also post this in the for sale area as this forum is for building.
It does needs wing cuffs as a few of them are missing or chipped from me moving several times.
#1222
Anders hi. im building one at the moment with OS160 and on board start. Having a few fitting issues with engine. Start unit touches on cowl at top and carby choke has to protrude cowl too. Do you have any advice and any more pics of your installation with cowl fitted as well.
#1223
#1224
I have the same setup and yes, the carby choke does protrude out of the cowl. I opted to have it installed without the choke. Instead I have a filter in its place. With the filter on, all I had to do was drill out a small hole. Makes for a cleaner look. You can check out my pictures on here. Let me know if you have any questions.
