Converting a Double Vision to electric...
Trying to decide if this a worthwhile project. I would probably use a Hacker A-80 motor with a Masterspin 170 controller. The point is to use my pile of 6s 5.5AH packs I use for my Align600 heli. With the price of the motor and controller at over $1200, buying new packs would make the project a little rich for my taste lol. Would to 6s 5.5 packs in series run this setup? The specks from Hacker call for 8AH packs (can't even imagine the weight!). Ideas? As you can tell, if it doesn't run on gas or kero I know nothing lol.
Shaun
Shaun
Shaun, If you are talking about the Chip Hyde Double Vision this has been converted before. Although larger than I normally fly the following seems to be an often used set up for 50cc conversions....
12s 5000 and up lipos
100amp HV controller (Various makes)
Hacker A60 18L motor
XAOR 24 x 10 prop.
This should give about 27lbs thrust if your lipos are good ones. Current draw at WOT would be about 75amps.
Dare I say that you will get a lot more info from the giant electric forums on the RC Groups site.
All the best...enjoy your flying/converting...Chris UK.
XAOR 24 x 10 prop.
