ASp 61 Plug Problems.
Old 07-28-2003 | 06:43 PM
Default ASp 61 Plug Problems.
Hi All,
I hope that one of you can advise me and help with my problem.
I have an ASP 61 and when I start it with the ASP supplied plug it starts OK but when the battery is removed it almost stops and appears to hunt as if the mixture is very rich but it is not and leaning it out only stops the engine.
At full throttle it does not rev very high and again hunts as if it is rich, but again leaning out makes no difference.
I have tried a OS8 plug and it revs much better and appears to reach full revs (I am using a 11x8 prop) and the mixture jet can be adjusted over quite a good range.
Does this engine require a cold plug or can you tell me what plugs you use and find satisfactory.
Thanks for reading this but I am completly stuck.
Old 07-29-2003 | 02:30 AM
The OS8 is what OS calls a warm plug so it should be fine. I'd guess the original plug might have picked up some contamination form the running in process which is making it act now like a very cold plug so you might as well throw it away. Just because a plug glows with battery connected doesn't mean it's still good.
Old 07-29-2003 | 04:06 AM
is this engine new ????
By your post it seems like it is,,,run 3... 10 oz tanks thru it slightly rich.. after that you should get better settings.
Old 07-29-2003 | 05:17 AM
Flyboy Dave's Avatar
My Feedback: (21)
Try a Fox Miracle plug in it, they work great....
....there's a reason they call them "Miracle"....
