What prop for OS .46 FX?
Old 07-29-2003 | 01:36 AM
Nik's Avatar
Nik
My Feedback: (12)
Default What prop for OS .46 FX?
Hey,
I got a broken in os .46 fx, and a new pattern plane for it will come tommrow! Anyways: What would be the most efficient prop to use in a pattern plane (Weight 5.5 lb)?
12.25x3.75 <- People at my club say the prop would be way to big for the .46 FX
11x7
11x6
10x8
10x6
Thanks!
Old 07-29-2003 | 03:31 AM
check the thread i started for Thunder Tiger Pro.46.
i think the props should be the same....
cheers.
Old 07-29-2003 | 05:48 AM
http://rcuniverse.com/showthread.php?s=&threadid=199865
this is the link.
goodluck.
Old 07-29-2003 | 09:47 AM
DarZeelon's Avatar
Default Proper prop...
The "best" prop is depends on your plane and what you do with it.
If you fly a GP Patriot, with a high RPM tuned exhaust system and hope for 110-120 MPH in level flight, you may want to use a 9x8, or even an 8.5x9 pylon racing prop.
If you have a sport plane, an 11x6, or an 11.5x6 would be your bet.
It depends on the type of pattern ship that you have.
I personally recommend the Bolly 11.5x6, for all around flying. It gives you good speed AND great thrust. I use it with my WM T-34 and it pulls it straight up and out of sight.
RPM is at 12,200, with a Tower muffler.
Old 07-29-2003 | 10:28 AM
Check the following link
http://www.bolly.com.au/book/
This is "The Bolly Book" written by the owner of Bolly Props.
It contains all one wants to know, (plus a lot one probably didn't know) about Prop design, suitability and choice.
It also explodes a few popular myths.
Old 07-29-2003 | 11:52 AM
I'd start with a 10/6 and go from there.
Max
Old 07-29-2003 | 04:01 PM
Bax
We'd suggest that a 10 x 6 prop is too small for the O.S. Max .46 FX engine. O.S. suggests the smallest prop be a 10.5 x 6. We usually run a 10 x 7 or 8 prop, or an 11 x 6 or 7. Any of those sizes turn out well for general sport use.
Of course, if you're tuning your engine/airframe combination for specific performance, then you'll wind up with different props.
Basically, prop the engine for mid-to-high-12,000's when the model's on the ground. If your engine turns that RPM and flies the model the way you want it, then you have the "correct" propeller.
Old 07-29-2003 | 04:45 PM
My Feedback: (31)
11.5 x 4 apc
http://members.cox.net/krayzc/
Old 07-29-2003 | 05:32 PM
Nik's Avatar
Nik
My Feedback: (12)
Thanks for the replys guys!
Old 07-29-2003 | 07:50 PM
IronCross's Avatar
an APC 11 X 6 seems to work best for me for pattern flying with that weight plane. Lots of torque.
Old 07-29-2003 | 07:57 PM
rslstft's Avatar
My Feedback: (10)
I have to agree with IronCross. I've tried a couple of different size props with my .46FX and it really seems to like the 11x6 the best
Old 07-29-2003 | 08:52 PM
Normally ,I would agree, but the original post said it was to be used in a pattern type plane, hence my suggestion to use a 10/6. You don't need that much torque, but I suppose these O.S. engines can't turn the revs I'm used to. Frankly, 12,000 or so is pathetic for an engine of that price
Max
Old 07-29-2003 | 09:42 PM
IronCross's Avatar
Strange, my OS works great with a 11 X 6 and pattern. You want revs for pattern ?. Interesting. Now pylon racing is another story. The OS will hit an easy 15 to 16K with a APC 9.5 X 7 prop. Lots of that going on around here.
