.80 XF + tuned pipe ?
WV
Hello!
I am replacing a ST .60 and tuned pipe with my reliable .80XF. Plane is a Dirty Birdy 60 and I have a header I purchased originally years ago for my .60 XF-III. Since the crankcase is the same on the .80 and the holes match up, is there a problem associated with this plan?
Also, since the header I have is extremely long compared with the header on the ST, can you give me a starting point for the proper length?
Any help you can give me also about tuning techniques would be much appreciated! Thanks in advance!
Mark
Mark
Is the header an Enya header? I have the original paperwork that came with the Enya tuned exhausts. In this, it gives the correct lengths. I could fax this to you, I don't have it on my computer. These are for the .60 though, so yo might want to increase the lengths a little.
WV
Tim,
Thanks for the reply and the help. I believe the header is NOT an Enya original. Bought it several years ago at a LHS. Couldn't remember the mfg to save my life.
The help with the lengths would be great. I can use them to start and as you said, leave them longer to adjust for.
No need for the original spec sheet. Just a ball-park length would be great!
Thanks again,
Mark
Thanks again,
Mark
