general question about engine stall problem
I have a glow engine that runs for about 3-4 minutes
and then stalls suddenly. There is no obvious cause for this
as it happens in various conditions, i.e., idle or accelerating.
I changed all the hoses and glow plug with no effect. I did notice that the muffler gets filled with fueled though.
Thanks for any help.
Tony
Tony
Sounds like it might be running too lean on the high end needle but more info is needed. What engine, fuel and plug are you using? What plane is it in? What prop are you using?
