K&B .61
Old 10-17-2011 | 03:56 PM
My Feedback: (30)
Default K&B .61
I am cleaning a very well used K&B .61 and I cannot get the piston out. I am using the usual method of taking out the sleeve and pulling the conrod back untill it comes off the shaft, but the rod doesn't pull back far enough. Is there some method specific to this engine that I am forgetting?
Old 10-17-2011 | 04:09 PM
wruggiero's Avatar
Default RE: K&B .61
Try to heat the engine. Could help, Don't forget to use a glove to work on it.
Old 10-17-2011 | 04:10 PM
coriolan's Avatar
Default RE: K&B .61
You need to remove the wrist pin trough the back after removing the access cap(part #25-6191)
http://www.mecoa.com/kb/61/6550-exp.pdf
Then the piston and sleeve can come out, unless you have a brand new spare don't remove the ring from the piston as it will distord and be ruined, here is how to instal new ring:
http://www.mecoa.com/faq/rings/install/install.htm
Old 10-17-2011 | 04:17 PM
My Feedback: (30)
Default RE: K&B .61
How do I get the pin out, I was recently working on an OS 46LA which has the same kind of pin and it had to be tapped out after the piston is out.
Old 10-17-2011 | 04:19 PM
w8ye's Avatar
My Feedback: (16)
Default RE: K&B .61
Use a #6 deck screw
Old 10-17-2011 | 04:27 PM
coriolan's Avatar
Default RE: K&B .61
It pull easily as noted in previuous post with a small screw(don't loose the nylon pads).
Old 10-17-2011 | 04:33 PM
My Feedback: (30)
Default RE: K&B .61
the nylon pad pulled out and ther wrist pin is still in there.
Old 10-17-2011 | 04:34 PM
flyingagin's Avatar
Default RE: K&B .61
ORIGINAL: coriolan
the ring insta link was great info I saved that info as I have a rebuild comming up soon on a Saito
<br type="_moz" />
Old 10-17-2011 | 04:36 PM
coriolan's Avatar
Default RE: K&B .61
The wrist pin is hollow, jam the screw (gently)in it and pull the pin with pliers. A blast of WD-40 might help!
Old 10-17-2011 | 04:57 PM
My Feedback: (30)
Default RE: K&B .61
What kind of fuel did they use in old engines like these? I recognize the smell of the engine but I can't put my finger on it. It smells like diesel and old heavy motor oil. Anyway I can't find a good screw, maybe I'll heat the engine. I will continue trying tomorrow afternoon.
Old 10-17-2011 | 05:00 PM
w8ye's Avatar
My Feedback: (16)
Default RE: K&B .61
A sheet metal screw would work
Old 10-17-2011 | 05:02 PM
w8ye's Avatar
My Feedback: (16)
Default RE: K&B .61
I just ran regular 10% nitro glow fuel in my K&amp; B 61's
Old 10-17-2011 | 06:01 PM
coriolan's Avatar
Default RE: K&B .61
ORIGINAL: rem0.061
The K&B .61 isn't that old, its designer (Clarence Lee) is still with us and active in engines development:
http://www.craftsmanshipmuseum.com/lee.htm
Old 10-17-2011 | 06:21 PM
My Feedback: (8)
Default RE: K&B .61
The origins of the K&B 61 ( the Veco 61) was designed in 1965. That's some 46 years ago. The K&B has had a few design changes over the years. Mr. Lee is still active, so you could get the actual designer to answer the question of fuel specifications.
Old 10-17-2011 | 10:00 PM
proptop's Avatar
My Feedback: (8)
Default RE: K&B .61
The wrist pin probably has varnish / gum on it...or maybe rust...that can cause problems when trying to remove the pin.
Soaking with penetrating oil, and some heat can help...and a lot of patience... (maybe a few carefully chosen *&^%$# words too [:@] )
Old 10-18-2011 | 06:10 AM
blw's Avatar
blw
Default RE: K&B .61
He has been very good about responding to email questions.
Old 10-18-2011 | 03:23 PM
frets24's Avatar
My Feedback: (15)
Default RE: K&B .61
I use a magnet or a magnatized screwdriver. The OS FS120 is the same way. Autozone usually has a small bucket full of telescopic manets and telescopic adjustable mirrors next to the register/checkout. Both of those tools are a steal @ .99c each and are super handy in the model shop.
Old 10-25-2011 | 02:41 PM
My Feedback: (30)
Default RE: K&B .61
I finally got the engine heated and the pin out with the screw, thanks for the help.
Old 10-25-2011 | 05:11 PM
coriolan's Avatar
Default RE: K&B .61
You'll find the K&B .61 is a fine engine still very usable.
Old 10-25-2011 | 06:33 PM
My Feedback: (8)
Default RE: K&B .61
The K&B 61 is still a great engine! When I was discussing its origins, that was only for history. It has stood the test of time IMHO. I am a huge CF Lee fan and I still enjoy using my K&B 61's. They are fantastic power for a 14 oz engine. I hope you enjoy yours as much as I do.
turbo
Old 10-26-2011 | 03:21 AM
My Feedback: (30)
Default RE: K&B .61
I will enjoy it after I put $100 of parts in it, because after I took it apart I saw the extent of the damage from a crash that supposedly never happened. I got the engine off of ebay with an intent of getting a good .61 engine for a low price so I could sell a plane RTF. the description was "Good used KB 61 engine good compresson usual signs of wear no damage." The damage resembles a crash with a dented muffler, scratched head, a bent shaft, and a small cracked ASP carb.
Old 10-26-2011 | 05:27 AM
Default RE: K&B .61
ORIGINAL: rem0.061
I will enjoy it after I put $100 of parts in it, because after I took it apart I saw the extent of the damage from a crash that supposedly never happened. I got the engine off of ebay with an intent of getting a good .61 engine for a low price so I could sell a plane RTF. the description was ''Good used KB 61 engine good compresson usual signs of wear no damage.'' The damage resembles a crash with a dented muffler, scratched head, a bent shaft, and a small cracked ASP carb.
I would not put another $100 into that engine; good ones are available for less.
If you paid by P**P*l, you may have had recourse. Maybe since you have taken it apart that may not be an option?
I would register a complaint so others may not be similarly burned by this seller.
Sincerely, Richard
Old 10-26-2011 | 07:13 AM
blw's Avatar
blw
Default RE: K&B .61
If you haven't bought the parts yet, you may want to buy them from C. Lee at a 10% discount. I think he charges actual shipping, and not the standard $6.99 fee. I recently bought a remote needle valve and carb for a K&B 61 from him that W8YE gave me.
Old 10-26-2011 | 10:22 PM
My Feedback: (8)
Default RE: K&B .61
I would advise you to seriously look at your options as $100 could yield you a NIB .61 engine.
Old 10-27-2011 | 11:19 AM
coriolan's Avatar
Default RE: K&B .61
ORIGINAL: turbo.gst
Like a "High quality" Chinese engine from some obscure ebay trader[8D]
