MRC .61
Old 10-22-2011 | 12:36 PM
My Feedback: (-1)
Default MRC .61
I just picked up a MRC {model Rectifier Corporation in Austria} .61. Very cool engine with rear induction. It's new in box and never been run but the last owner for some reason removed the rod and piston? Now the rings {two} are missing along with the muffler.
Anyone know of a parts source?? This engine is so cool I don't know if I will use it or sell it, maybe just put in on display. I have never seen one before.
Old 10-22-2011 | 02:54 PM
My Feedback: (264)
Default RE: MRC .61
Can you post a picture of this engine?
Old 10-22-2011 | 07:42 PM
My Feedback: (-1)
Default RE: MRC .61
HP .61RC by MRC
ID:	1677650   Click image for larger version
Old 10-22-2011 | 08:17 PM
My Feedback: (90)
Default RE: MRC .61
it was introduced by HP in 1969 and was designed by paul Bugle. It was also the first engine with schnurle porting offered to the modelling public. It was never a MRC engine but was the us representative for HP at the time. The engine is somewhat rare as it was only offered for a little more then a year and then replaced with a more conventionaal front roter.
Dennis
Old 10-23-2011 | 07:49 AM
My Feedback: (-1)
Default RE: MRC .61
ORIGINAL: dennis
Dennis
Thanks for the info. I may be able to find a set of rings to fit it but I'm sure the muffler is something I will never be able to find. I do have a little HP under the bench and I saw how the muffler fit over the port. Kinda cool.
Old 10-23-2011 | 08:10 AM
earlwb's Avatar
Default RE: MRC .61
Yeah the muffler could be problem because in 1969 they weren't really making mufflers much for any engine brand. So they may have never made any for that engine at the time.
So you will likely have to fabricate something to work.
Frank Bowman makes rings for just about any engine imaginable. If he doesn't make the rings he only needs the piston and liner and he can make up a set for it. Contact him at [email protected]
Current rings that he lists are:
Reproduction Model Engine Rings
Quality at a fair honest price. Making a good ring is a Skill. Making a fine ring is an Art!
Last Revised 1 - 7 -11
I will reproduce nearly any model engine ring. If not available, I’ll need a good piston and cylinder to measure, or send motor. Send return postage, insurance is extra. For orders outside of USA, ask for shipping costs? Priority postage is extra. An order of 10 rings or more, discount of $1.00 off per ring, mixed orders are fine! Ring cost & shipping charges for USA listed below.
Please Note:
If you send me an engine for new rings that I don't currently make there will be No labor charge to do this.
If you send me the stripped down engine block ( Block, piston liner and rod assy.) for rings, that I Do currently make No extra charge.
If you send me a complete engine to disassemble, clean, and install the ring(s) and reassemble there will be a minimum charge of $25.00 per hour. My buisness is making Piston Rings and $25.00 is the minimum amount I would be losing by not making rings and working on your engine insted.
ATTENTION : NEW MEXICO CUSTOMERS WE HAVE TO CHARGE YOU 7.125% TAX, please add the extra tax to your orders.
Standard ring up to .65 engines: $9.00 ea.(1) shipped $13.00, (2) shipped $22.00 (1) .64 (2) $1.28
Standard ring from .66 & up: $10.00 ea.(1) shipped $14.00,(2) shipped $24.00 (1) .71 (2) $1.43
Dykes ring up to .65 engine: $10.00 ea.(1) shipped $14.00,(2) shipped $24.00 (1) .71 (2) $1.43
Dykes ring from .66 & up: $11.00 ea.(1) shipped $15.00,(2) shipped $26.00 (1) .78 (2) $1.57
** I also make special rings to order, ask for prices.**
Ace Twin .64
Aero .35
Aerrow 100 (pin) Quadra
Aerrow 200 (pin) Quadra
Aerovat 65 CC (pin)
Aircom M61 (pin)
Air-O .45
Anderson Spitfire .65
Area 51CC (pin)
Asp .52 4C, .61 (pin), .65 4/C, .80 4/C, .91 4/C
Atomic 60 Don Sohr
Atwood .49, .51, .63
Avion Mercury 1.609
Avistar .60 (pin)
Bantam .16
Bat .19
Bennelli 65 CC (pin) motorcycle
Berilli 36 CC (Pin)
BME 3.5 Twin (pin), 105 (pin), 110 twin (pin)
Brillelli 60 CC (pin)
Brison 2.4 (pin), 3.2 (pin)
Brown Jr. .60 cylinder sizes vary (send Piston & cylinder for proper fit & correct ring)
Brownie .29
Bushwacker 37.7 CC (pin) Sears
Bunch .45, .49
Cameron .15, .19
Cave Cobra
Chung Yang 29CC (pin)
Cleveland Tom Thumb .45
Comer 50CC (pin)
Como .29 (pin), .40 (pin), .51 (pin), .90 (pin)
Contestor D.60
CRRC Pro 26CC (pin), 40 CC (pin), 45 CC (pin)
CS .53 (pin)
Cub Cadet 25CC (pin)
DA 50 CC (pin) (2) different 1.678 Bore, & 1.681 Bore
DL 50 CC (pin)
DLE 20 CC (pin), 30 CC (pin), 55 CC (pin),110 Twin (pin), 170 Twin (pin), 222 4 cylinder (pin)
DME 100 Twin (pin)
Dooling .29, .61, Yellow Jacket
DZY 48 CC Twin (Pin)
Echo 16CC (pin), 21CC (pin), 21.2 CC (pin), 24.4 CC (pin), 30 CC (pin), CS-3000 (pin), 50 CC (pin)
Edco Sky Devil .64 Old or New (RJL) state which one?
Elf Andrea Heine Repo
Enya 3.5 (pin), .30 SS (pin), .35 X (pin), .40 X Dykes (pin), .40 Dykes model 6002, .40 4/C, .45, .45SS (pin), .46 4/C,.49 X (pin), 50SS (pin),.53 4/C, .60 4/C, .60 X (pin), .60 standard, .61 CXLR (pin), .80 X (pin), .80 4/C, .90 4/C, 120 4/C, 120 R 4/C, 1.55 4/C, 240 4/C Twin
ETA .29
EVO 150 Twin (pin)
EVRA 190
Forster .29, .31, .88, .99
Fox 36 Sand Cast (pin), .40 Sch., .45, .50, .59 .047 thick ring and .030, .59 long shaft Ign., .60 Blue Head, .60 Eagle, Fox Hawk
Red Head .60 (pin), .74, .78, 120 Twin (pin), Gas Bore 1.439 ? (pin)
GMS .61 (pin), .61 Dykes (pin), .76 Dykes (pin), 1.20 Dykes (pin)
Hassad Blue Streak .64
HB .21 Dykes,.25 Dykes, .40 PDP Dykes, .40 Black Head (pin), .50 Dykes, .61 (pin), .61 Dykes
Hiller (Car)
Hirobo 36 (pin)
Homelite 25 CC, 30 CC (pin) old .060 thick pin centered (press in ) , 30 CC newer .030 thick (pin), 30 CC new style Off set pin, 33 CC (pin), 38 CC (pin), 40.6 CC Super EZ Chain Saw, Super Mini Chainsaw Dykes (pin), 45 (pin), 50 CC (pin)
Horner 3.7 Twin (pin)
Hornet .19, .60
Howler .60 (pin)
HP .21 4/C Dykes ,.40 (pin) ,.61 R.I. Silver Star (pin), .61 Dykes (pin) Blk Case Gold Hd.
Hurluman 60
Husqvarna 2100 (pin) Chainsaw Pin needs pressed in 1/2 way
Irvine .20 Dykes, .25 Dykes, .36, .40 Pylon Dykes (pin), .40 Standard (pin), .46 MKII Q46 Dykes, .61 Dykes, 150 standard non pin.
JC Evo 28 CC (pin)
Kavan MK 50
KDC Kioritz 21.2 CC (pin), 23.6, 25 CC (pin), 30 CC (pin), 58 CC (pin)
K&B .35 Dykes, .40 Dykes, .40 S Dykes (pin), .61, .61 Dykes (Lee Custom), 1.35 (pin), 1.5 (pin)
Kometa 29
Kraft .61 (pin)
Kratmo 10 CC, 4A Ignition
Laser 61 4/C
Lewis 60
Magnum .52 RFS 4/C, .53 XL 4/C, .61 XL (pin), .61 4/C, 70 4/C, .91 XL 4C, 120 4/C, 120 (pin)
Maloney 100 (pin), 125 (pin)
McCoy .09, .19, .19 Dykes B.H., .21 Dykes Car, .29 all versions, .29 Dykes B.H., .35 Dykes B.H., .36, .40 Dykes B.H., .49, .55, .60, .60 Dykes
McCulloch 15 CC ? (pin) 1.024 Bore, 21 CC (pin), 25 CC (pin) MDB 90 Leaf Blower, 28 CC, 32 CC (pin),
MDL 28 CC (pin)
MDS .78 (pin), 1.48 (pin), 2.18 (pin)
Merco .40, .49, .49 Dykes, .50, .61, .61 Dykes
Micron 60
Moki M .51 (pin), .61 (pin), 1.20 (pin), 1.35 (pin), 1.50 (pin), 1.80 (pin), 2.10 (pin)
MT 42CC (pin), 57 CC (pin)
O&R Industrial Motor 1 HP
OPS Maxi .30 (pin)
OS .20 FS 4C, .26 4C, .28 FH Dykes (pin), .30 fs 4/c, .32 (pin), .37 H (pin), .40 H Dykes, .40H Standard, .40 H (P) Pylon, .40 FS 4/C, .40 SF (pin), .807 bore, .40 SR (pin), .40 FSR .835 Bore (pin), .40SR Dykes (pin), .45 FSR (pin), .45 FSR Dykes (pin),.45 RSR Dykes, .46FX (pin), .46SF (pin), .48 4/C Surpass, Max .50 old, .50 FSR Dykes (pin) ,.50 H (pin), .50 SX & SXH (pin), .52 4/C surpass, .58, Max-H .60, .60 FS 4/C, .60 FSR (pin) .9445 Bore ,.61 SF .9055 Bore (pin), .61 FS 4/C, .61 SX (pin), .61 SXH (pin), .65 RSR (pin), .70 4/C, .75 4/C Surpass, .80 H,.80 Dykes (pin), FS.90 4/C, .91Surpass 4C, .90 FSR (pin), .91 FSR (pin), .91 FX (pin), .91 SX H (pin), 1.08 BX-1 (pin), 120 4/C, 120 twin 4/C, 120 AX (pin), 160 FX (pin), 160 4/C, BGX-1 3500 (pin)
Poulan 25CC (pin), 25 CC Featherlite (pin), 32CC (pin), 35 CC (pin), 42 CC (pin), 42 CC Wildthing (pin), 46 CC (pin), 54 CC (pin), 60 CC (pin)
Profi .40 (pin), .61 (pin), .76 (pin)
Quadra 35 CC , 40 CC (pin), 42 CC (pin), 50 CC (pin), 100CC Aerrow (pin), 150 Twin (pin) , 200 CC Aerrow Twin (pin)
Quick Draw CC (pin)
RCGF 20 CC (pin)
RCS 1.40 (pin)
Ross .60 Dykes (pin), .60 opposed twin Dykes (pin), .61 (pin)
Rossi Speed .60 old, .60 (pin) .021, .61 (pin) .023, .65 (pin) .0235, Speed .65 (pin)
Royal 40 (pin)
Ryobi 26 mm Bore EJ 100 (pin), 31CC (pin) older .064 thick, 31 CC (pin) newer .047 thick
Saito FA .30 4/C, .40 4/C, FA .45 4/C, FA .50 4/C, FA .56 4/C, FA .60 Twin 4/C , FA .65 4/C, 72 4/C, FA .80 4/C, FA 82 4/C, .91 4/C, 100 4/C, 120 4/C, FA125 Golden Knight 4/C, FG 20 125 4/C, 130 TD 4/C Twin, 150 4/C, 180 4/C, 270 4/C Twin, 300 4/C Twin
Sachs 2.0 (pin), 3.2 (pin) offset, 3.2 (pin) centered, 5.8 (pin)
Sap-180 HP 1.2 (pin)
Scott Thunderbird
Sears Weedeater, Bushwacker,18 CC, 21 CC, 25 CC, 25 CC TWC Leaf Blower, 37.7, all pinned, 1966 Allstate Moter Cycle engine made by Puch (pin)
Shindiawa 33 CC (pin)
SIFK 29CC (pin) AKA CY, Chun Yang
Skil chainsaw (pin)
Sky Chief .53
Spe 25.4 (pin), 26 CC (pin), 40CC (pin), 45CC (pin)
Stihl 25.4 (pin), 028 Chain Saw 44 CC (pin), Super 45 (pin), 57 CC (pin), MS 440 Chainsaw 70 CC (pin)
Super Tigre G20.15, G20 .19, G20 X.25, S .29 (pin), G21.29 old, .34 (pin), .40 Bullring, S.40 (pin), G21.40 std., G21 .40 Dykes, G21.46 std. ,S.45 (pin), V.45, X.45 (Pin), G21 .46 wide Dykes, G.46, G .46 Bullring, V 51, G51 (pin) Italian, G51 (pin) China, V.56, V.56 Dykes, V 60 light case .044 or .047 top to bottom measurement, G24 60 Old, G 60 Bluehead, X60 (pin), V.60 wide & narrow Dykes, S.61 (pin), G.71, S.75 (pin), .90 (pin), 2000 (pin), 2300 (pin), 2500 (pin), 3000 (pin) Italian, 3000 (pin) China, 3250 (pin) Italian, 3250 (pin) China, 4500 (pin)
Syncro B-30, Syncro ACE, Syncro ACE Special
Tartan 1.34 (pin), Twin .77 (pin)
Tech 23CC (pin)
Technipower 7 Cylinder radial, B series, 9 cylinder
3MM 53 TOC (pin)
3W 26 CC (pin), 80 CC Boxer Twin (pin)
Thunder Tiger .39 (pin), Pro .50 H (pin), .53 Red Line Heli (pin), .54 4C, .91 FS 4C, 120 Pro (pin)
Toki .40 (pin)
Ueda .45, .61
US 25 CC (pin)
Vlvatam 2.5, 5 CC
Veco .21 Dykes, .50 Dykes, .61, .61 Dykes
Vega 10CC, 91 4/C
Webra .32 Speed Dykes (pin), 35 (pin), 10 ccm, 6.5 (pin), .40, .40 (pin), .40 Dykes (pin), .50 Dykes (pin), 52 (pin), .55C AAR Red Head Heli (pin), .61, .61 (pin), Speed .61 FS (pin), Speed .61 F Dykes (pin), .61 Dykes (pin), Speed 70 (pin), T480 4C, .91 (pin), 91 PS (pin), 120 Dykes (pin), 1.2 LS (pin), 91 (pin) T 4.90, 35 CC? Bully (pin)
Weedeater 18 CC (pin), 21CC (pin), 25CC (pin) 1.358 Bore, 25CC (pin) 1.380 Bore, 22 CC (pin), 32CC (pin)
Weedwacker 25CC (pin)
Westbury Atom III
Yamaha 50CC (pin)
YS .61 Long Stroke (pin), .63 4/C, .80 H (pin) 2C, F.91 AC 4C, .91 2C (pin), 110 4/C, F120 4C
YW 24CC single & 48CC Twin (pin)
ZDZ 40 (pin), 50 NG RV (pin), 60 RV (pin), early 80 RV (pin), later 80 - J model (pin)
ZEN G270 (pin) AKA Chung Yang
Zenoah G20 (Pin), G23 (pin), G26 (pin), G38 (pin), G45 (pin), G62 (pin), GT-80 Twin (pin)
Old 10-23-2011 | 10:03 AM
My Feedback: (-1)
Default RE: MRC .61
That's outstanding, thank you much. I also found a site for HP engines and I may/or may not be able to get a muffler for the engine. I'm not sure what type of rings this engine had but I will give the HP people a call and find out. They state that almost none of the parts of the later engines will fit this one but they do have a few. I may end up selling this one to a collector. It would be a shame to run it and and lower the collector value for someone. Still, as a pilot I love to fool with the old stuff. I bought a lot of old stuff but it is all brand new and never used. I'm testing out an old charger right now and it seems to work perfectly. It's better then my favorite old ACE charger. This was a pretty good pick.
Old 10-23-2011 | 11:14 AM
proptop's Avatar
My Feedback: (8)
Default RE: MRC .61
I think this engine has the same E. stack dimensions as the front I. version?
The muffler has wire spring clips type of attachment (hard to describe ) and slips over the E. stack for alignment.
It uses std. compression rings...Mr. Bowman should be able to hook you up...[8D]
Old 10-23-2011 | 12:57 PM
Kmot's Avatar
My Feedback: (24)
Default RE: MRC .61
Half way down the page:
http://www.craftsmanshipmuseum.com/othereng.htm
Old 10-23-2011 | 01:26 PM
My Feedback: (-1)
Default RE: MRC .61
Very cool K. Wish they would have shown a photo of the rear induction engine. Sure is a long crank shaft between the bearings.
Old 10-23-2011 | 07:03 PM
coriolan's Avatar
Default RE: MRC .61
MECOA has some HP parts which might fit your engine:
https://shop.mecoa.com/shopdisplayproducts.asp?id=122
Old 10-24-2011 | 07:11 PM
Kmot's Avatar
My Feedback: (24)
Default RE: MRC .61
ORIGINAL: Gray Beard
I thought they did?
http://www.craftsmanshipmuseum.com/i...61RintakeA.jpg
http://www.craftsmanshipmuseum.com/i...61RintakeB.jpg
http://www.craftsmanshipmuseum.com/i...61RintakeC.jpg
