OS 91FS
Old 05-09-2012 | 12:32 AM
Yay
Default OS 91FS
Hi
My first post on this site,I have a problem with my Os91FS II,its mounted in a Big Stick 60,when I go inverted it riches up,
upright is OK, also if I do a 4 point roll it does the same thing, a normal roll is OK.
Any thoughts?
Yay in OZ
Old 05-09-2012 | 02:11 AM
Default RE: OS 91FS
Hi!
Tank to hight at inverted!
Mount the engine on it's side! And check the tank hight!
Old 05-09-2012 | 03:56 AM
Sport_Pilot's Avatar
Default RE: OS 91FS
Raise the tank it is mounted too low.  Also check muffler pressure the pressure tap may be plugged.  Consider a uniflow setup as this helps especially with leaning out as the fuel burns off.
Old 05-20-2012 | 05:50 PM
Default RE: OS 91FS
They told you what to do but not how. You need to mount the tank so that the centerline of the tank is even with the throttle barrel of the carb. With a lot of four strokes, that is difficult to do since a lot of planes are designed for two strokes where the carb is above the crank line. Like he said, mount the engine in its side will take care of a lot of the problem. When all else fails, you can use a Perry pump to provide constant fuel pressure. I had to do this on my EZ P-51 racer.
