crockpot temperature
Old 06-27-2012 | 07:22 AM
Default crockpot temperature
has anyone measured the best temperature?
first time and the one wifey gave me was broken an only works on high so i put a variable transformer on it adjusted to 110 deg F. After 24 hrs the castor was their still, cleaner but still on muffer etc. I then had to scrub it of with a tooth brush is this the way it works or do i need higher temperature do'nt want to turn dark as some say on high setting it does
Thanks rich
Old 06-27-2012 | 07:28 AM
SeamusG's Avatar
Default RE: crockpot temperature
My Goodwill crock pot is set on low. 100% green O'Reilly anti-freeze (glychol based). Overnight. Cylinders & cases wonderfully clean - almost like new condition.
Old 06-27-2012 | 07:33 AM
My Feedback: (66)
i put mine on hi when i do mine seems to go faster than when on low but i will do this when working in the garage and check it every hour or so after the first three
Old 06-27-2012 | 08:57 AM
w8ye's Avatar
My Feedback: (16)
Between 150F and 170F is about right. You don't want it to boil
Old 06-27-2012 | 09:12 AM
Since 165 degrees F. is the lowest recommended temp for cooking meats, I would think the low setting is at least that. As W8YE says, keep it below boiling.
Old 06-27-2012 | 09:35 AM
My little Walmart pot has but one setting - on.  But make sure it is not boiling like the man said.  I always have to use a little elbow grease to finish up the job.  Then I polish mufflers with a buffing wheel and jeweler's rouge.  Come look great.
Old 06-27-2012 | 12:07 PM
blw's Avatar
blw
My cheap one has a low and high setting. I use low.
Old 06-27-2012 | 12:30 PM
OK i see iam to low at 115F i had way to much elbow grease.
prestone was used at 100% my bearings are still red must be rust, an the pin still will not pull out of piston
so you guys think at 175F the wrist pin may come clean on it's own i cannot scrub it
thanks all iam upp the heat[&:]
Old 06-27-2012 | 12:59 PM
Sport_Pilot's Avatar
Yes try more neat. Keep the bearings in theire. If the stain is smooth it is most likely castor varnish.
Old 06-27-2012 | 09:24 PM
JollyPopper's Avatar
Don't condemn the bearings as being rusty yet. Solidified castor will be red to amber inside that engine. More heat in that pot may clean that puppy up.
Old 06-27-2012 | 09:58 PM
My Feedback: (66)
just put it on Hi!
Old 06-28-2012 | 03:46 AM
But don't let it boil and don't breathe the fumes if it does[:'(]
Old 06-28-2012 | 06:22 AM
Thanks all
This mornin it looks a lot better upped to 170f to 180F bearings are cleaner but red thou it turns really smooth so going to see how it runs
not going to screw around with piston an pin since all else looks new. btw it' an OS FS70 an it's all shiney now
rich
