Prop Question
Old 09-04-2003 | 02:05 AM
Default Prop Question
I'm currently running a Saito 45 with an 11-6 prop I would like to switch to a 10" prop for more ground clearance but I'm not sure what pitch to use. Does anyone have any ideas?
Old 09-04-2003 | 02:11 AM
Richard L.'s Avatar
My Feedback: (24)
Try a 10x7.
Old 09-04-2003 | 02:52 AM
Razor-RCU's Avatar
My Feedback: (50)
Default yup
Go down in diameter (1) and go up (1) in pitch
11x6, 10x7, 9x8 etc.
Whaddya flyin'?
Have fun-
Old 09-04-2003 | 06:05 AM
DarZeelon's Avatar
Default Wrong!
If you want to retain the same propeller load on the engine, which as I understand is your basic question, you must add 2 to the pitch for each inch you subtract in diameter.
An 11x6 will be equal in load to a 10x8, or to a 12x4.
You can use the Reivers thrust calculator to demonstrate it to yourself. All three props will spin around the same RPM, on a given output (HP) level.
