Prop size for evolution 46NT
YT, CANADA
I know I am opening (maybe) a can of worms but the article for the 46nt states that it should use a 11x6 prop and turn around 12500. I am kind of short on ground clearance and was thinking of a 10.5 x6 or 7 not sure what it will do to the rpm? Has anyone with this engine used different props and if so what did you find?
My Feedback: (14)
Good morning...I need help from anyone with experience with the Evolution Engine....I have a new one, the Alpha, .45, (not NT) 15 minutes on the engine...I put it up with a lot of after run oil and two days later I had a puddle of oil under the front of the engine on my work bench...Oil is leaking at the prop. I have other engines that I have never noticed an oil leak....Is this a normal problem for engines or evolution engines if they are stored with 15 drops of after run oil?
