.18 Glow-plug question.
Old 11-04-2014 | 02:14 PM
Default .18 Glow-plug question.
I played hell getting my .18 nitro buggy to start today. I pulled the glow-plug and it was lighting fine so I put it back in. I finally got it started but every time I take the glow-plug heater off it dies. Can anyone tell me what the problem is?
Thanks!
Old 11-04-2014 | 02:17 PM
1QwkSport2.5r's Avatar
Either the plug is bad despite lighting up good or the idle mixture is too rich.
Old 11-04-2014 | 02:34 PM
The weird part is it ran fine yesterday and I haven't changed any needle settings. So the plug can be bad even tho its glowing? The glow plug does start the engine, which I thought was its only purpose. I started to worry that I lost compression but if feels normal when you pull the starter rope. I guess I'll try to start it again and lean out the LSN. Thanks for your reply.
Old 11-04-2014 | 04:55 PM
Hey 1Q you nailed it... leaned out the LSN and that did the trick. Thanks for your help.
Old 11-04-2014 | 05:00 PM
If it ran fine yesterday and doesn't run fine today then likely the glow plug is toast. A glow plug can glow nice and bright but the engine may not run for squat without the glow driver clipped on. Change the plug with a new one and try again.
